car keeps on running AFTER the key is out
Old Mar 25, 2002 | 11:04 AM
89ROC's Avatar
I just bought an 84 anniversary TA. It originally came with a 305/Auto. But has been converted to a NON-electronic carbed 327, and 5-speed. When I go to turn the car off and take the key out, the ignition cylinder turns and the key comes right out, yet the car keeps on running. What could be causing this weird problem?!?
Where do I start?
thanx
Old Mar 25, 2002 | 11:23 AM
TransAm's Avatar
From: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
https://www.thirdgen.org/techbb2/sho...threadid=91242
Old Mar 25, 2002 | 11:33 AM
89ROC's Avatar
Ok, my car is not doing that. It doesn't "diesel" at all.
The problem with mine is that it never shuts off, it just keeps running normally. It's the same before and after the key is removed.
Old Mar 25, 2002 | 11:56 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
must be a short circuit some where
Old Mar 25, 2002 | 12:10 PM
Fast3rdGen's Avatar
does it have an msd ignition? they have a "run-on" problem that creates feed back to the ingnition through the alternator charging wire. they come with a diode you can solder inline to stop it. mine had that same problem.
Old Mar 25, 2002 | 12:15 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I'm having basically the exact same problem. Check out my post "HELP! car wont die and tach goes crazy". I really have no idea whats going on.
Old Mar 25, 2002 | 12:26 PM
89ROC's Avatar
No MSD ignition. I'm thinking it must be a wiring problem, though.
When the key is turned off, doesn't it basically just shut the spark off? The ignition switch is what controls that, right?
Maybe she needs a new ignition switch...
Old Mar 25, 2002 | 08:37 PM
Vader's Avatar
Sorry about the size, but maybe a sticking switch or a linkage adjustment:
Old Mar 25, 2002 | 11:52 PM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
I was playing with my wires one day and found two huge harnesses in the driver/firewall corner, inside the engine bay. Play with those. I think that if they were not connected, then the engine would run, and if they were connected the engine would stop. All of the wires were really torn up. I had to do the quick electrical tape fix, but plan on replacing my entire wiring harness if I ever do an engine swap.
Later,
Jesse
*edit* sorry, I'm really tired, so I might not make much sense.
Old Mar 26, 2002 | 09:09 AM
Damon's Avatar
The ignition cylinder itself is often the problem. My brother's 85 Z-28 jsut started doing the same thing. New cylinder and it's fixed.
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
