Someone please run my setup through desktop dyno
Old Mar 31, 2002 | 12:23 AM
primer84z's Avatar
305
flowtech shortie headers 1 1/2
vortec heads milled .045 10:1 compression
XE262 comp cam
edelbrock rpm vortec intake
edelbrock 600 carb
mallory high performance hei distributor vac. advance
t5
3.73 posi
Old Mar 31, 2002 | 12:57 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
here is your power graph
hehe messed up on the first one so here it is again
Attached Thumbnails Someone please run my setup through desktop dyno-graph.jpg
Old Mar 31, 2002 | 01:00 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
now your dyno table
Attached Thumbnails Someone please run my setup through desktop dyno-table.jpg
Old Mar 31, 2002 | 01:04 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Here it is.
Attached Thumbnails Someone please run my setup through desktop dyno-resize-resize-screen.jpg
Old Mar 31, 2002 | 01:05 AM
Engine: 305-4v
An embarassment of riches, eh?
Old Mar 31, 2002 | 01:14 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
and a g raph to show you your volumetric eff
and manifold pressure
Attached Thumbnails Someone please run my setup through desktop dyno-eff.jpg
Old Mar 31, 2002 | 10:45 AM
Joshua Leslie's Avatar
350 horsepower...
one of the car mags. did this exact same setup about a year ago, and they only got 275
Old Mar 31, 2002 | 12:39 PM
primer84z's Avatar
Thanks alot guys. i think i need to go buy one of those. with your experience, how accurate are they compared to a real chasis dyno?
Old Mar 31, 2002 | 12:59 PM
rhuarc30's Avatar
Well, it's only as accurate as the info you feed it. It also assumes that your tuning is perfect, perfect a/f ratio, timing, coolant temp, no detonation. But if you give it all the right info, and your tuning is right on I've run several comparisons to engines I know the actual dyno numbers on and it's error factor runs about 5% on the hp and 8% on torque. The tq numbers are usually a little high, and the hp numbers a little low, but it does go the other way a fair amount to.
Old Mar 31, 2002 | 02:01 PM
primer84z's Avatar
is there where i can get a free demo of it or something i want to try it before i buy it. seems to be more valuable than gtech.
Old Mar 31, 2002 | 05:31 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
anyone running D.T.D. on windows XP????? Hate compatibility issues!!!
Old Mar 31, 2002 | 08:07 PM
rezinn's Avatar
Yeah, I am. It works fine in xp. Try running in win98 compatability mode if you've got problems.
MustangBeater20
Oct 29, 2022 09:20 PM
Fast355
Dec 2, 2016 06:33 PM
Street Lethal
Aug 13, 2015 08:28 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
