HELP!!! prestone leaking into oil...
Old Apr 7, 2002 | 04:17 PM
TransAm86's Avatar
I have a very big amount of prestone leaking inside the engine, mixing with the oil. I thought my heads were craked so I got them checked, the guy at the machine shop said they were ok... All the gaskets are new, intake has well. So I thought maybe my block might be cracked, so I changed my short block, all new gaskets, and its still leaking.
This is getting very depressing, I haven't ran my car for two years due to that problem, and the fact that I don't really have some cash and a place to work on my car..
What could it be??????????????
Nik
Old Apr 7, 2002 | 04:25 PM
JT 85 TA 305's Avatar
I had the same problem with my engine EXCEPT you said your head gaskets are new and mine were original still at 112,000 mi. I ran an additive called "bars leak" or something like that through the coolant and it patched my gaskets up. Sorry if I got your hopes up but that worked for me.
Old Apr 7, 2002 | 04:32 PM
TransAm86's Avatar
also i didn't have to run the engine... just by cranking it, it leaked???
Old Apr 7, 2002 | 04:34 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
If the heads or the block deck are warped, it won't matter if the heads and block aren't cracked. The gaskets won't seal properly with warped heads or block decks and this will cause the problem you're having. Also, a cracked intake can cause this problem too.
Old Apr 7, 2002 | 04:37 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
You have an oil cooler?
Old Apr 7, 2002 | 04:39 PM
TransAm86's Avatar
86TPItransam: the heads have been decked before intalation and the block has well.. I tryed 2 blocks!
EngineBoy: No I dont have an oil cooler
Nik
Old Apr 7, 2002 | 04:48 PM
Nik
Then your intake is possibly cracked.
Old Apr 7, 2002 | 04:53 PM
TransAm86's Avatar
Its new.. never used edelbrock performer RPM
Old Apr 7, 2002 | 05:00 PM
TransAm86's Avatar
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
