How difficult is an in-car cam swap?
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I don't want to pull my motor if I don't have to. Can you just remove the radiator, or does the condenser have to go too? If the condenser has to be moved, can it be moved over a little, or do you have to remove the freon and take the condenser out of the car? Are there any other "surprises?"
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
It is not difficult. If you have AC, the condensor WILL have to be removed, and you will have to discharge the AC system.
Other than that, no real suprises I can think of right now.
Car: 99 Formula
Axle/Gears: 342
Be prepared to bend the support bars in front of the radiator, it's not that hard though, just a little to slide the cam completely out.
You'll need a harmonic balancer puller, I rented one. Be sure to put a rag in the distributor hole cause you don't want anything falling down in there.
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Car: 99 Formula
Axle/Gears: 342
Originally posted by iroc22
Have fun dropping the oil pan with the cross member
Car: 99 Formula
Axle/Gears: 342
If you want oil leaking from the timing cover...oh and it would be hard to take off the timing cover with it on too
Car: Junk
I'd say screw it and just yank the cover off without lowering the pan, because with some "custom" trimming of the cover, you can re-install it with some RTV and it won't leak, if you put enough RTV on the corners and modify the front seal slightly. But if you want to be really professional (cough!), LOWER the pan, don't remove it...just take all the front bolts almost all the way off, and loosen the back bolts so that you can kinda push the front of the pan down about 3/8inch, which should help big time. Honestly tho you can get away with yanking the cover off and stuffing it full of RTV when you put it back on, although some people won't like........just don't tell em!:nono:
Chris
Chris
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
I saw Jegs sells a timing cover that doesn't lip down into the oil pan. It says it just bolts to the front of the motor and is easily removed. If I use this, does anybody know if the seal on the oil pan will leak? I'm not really sure if this cover would seal it or not.
Car: 99 Formula
Axle/Gears: 342
Yeah! Shortcuts!
Whatever happened to doing it right the first time?
Yeah! Shortcuts!
Car: '87 Camaro LT
Engine: 355 L98
it took me maybe an extra half hour to loosen all the oil pan bolts and starter bolts (to get to the oil pan bolts) with the engine in so i could get my timing cover back on. it's really not too hard with a 1/4" ratchet.
Car: 99 Formula
Axle/Gears: 342
theshackle
Mar 5, 2017 06:37 PM
