Acceleration!!!!!!!!!!!!!??????????
Old Apr 11, 2002 | 11:59 AM
cridom's Avatar
this is my car and i want her to be faster in the acceleration what can i do????? i dont wanna spen a lot of money its just a city car
to race stangs only
please help me
1991 z28 5.7L v8 245 hp all stock lowered springs
350 tpi
Attached Thumbnails Acceleration!!!!!!!!!!!!!??????????-sin-t-tulo-1
Old Apr 11, 2002 | 01:47 PM
Stroked-Z's Avatar
First off, nice car.
Secondly, swap in some 3.73's and get yourself some good, sticky rear tires to help it hook.
What kind of $$$ are you looking to play around with?
Old Apr 11, 2002 | 03:29 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Port and polish the intake and plenum. Cold air induction. Good aftermarket headers and exhaust.
Loose the windshield sticker
Old Apr 11, 2002 | 05:26 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
A chip never hurts.
Old Apr 11, 2002 | 05:32 PM
iroc22's Avatar
Full exhaust from headers back, u will see a huge difference. Think about replacing those cats too with some high flow ones.
nesluopetan's Avatar
Depending on how much $$ you got, first thing always to do is K&N, HEADERS & EXHAUST. then do gears.. those mods will help a TON!
Old Apr 11, 2002 | 05:43 PM
cridom's Avatar
whats the diff between 305 tpi or 350 tpi?
Old Apr 11, 2002 | 05:50 PM
cridom's Avatar
what would it cost decent headers and exhaust separate?
Old Apr 11, 2002 | 10:55 PM
RICHRAD's Avatar
45 tpi ............ Usually don't do that, oh well, really though , the difference is cylinder/ piston bore and sizing I think.
Old Apr 11, 2002 | 10:58 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
exhaust and higher stall converter would be a great start.
Old Apr 11, 2002 | 10:59 PM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
the 305 has smaller cylinder bore,smaller heads,pretty much smaller everything,except for the intake is the same on the 305 and 350 tpi i think.Definetely get the full exhaust and maybe port your runners/plenum or buy new ones...youll see a huge difference there,since the stock intake was designed for the 305,then get the 3.73's,and youll be beating mustangs.Go to summitracing.com or jegs.com to get some ideas on pricing.
Old Apr 11, 2002 | 11:32 PM
iroc22's Avatar
If you have the G92 5-speed 305, then not a whole lot. The injectors have a higher lb/hr rating and a 1.84 intake valve, 58cc chamber heads and thats about it between the two engines. 230hp compared to 245hp thats about 15hp difference for the cubic inch difference. If you dont have the G92 305, its got mostly parts from the 305 TBI; except the heads are wayyy better.
Old Apr 11, 2002 | 11:49 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I agree, plus some gears, depends on how long you race for if it's 1/4mile don't get 3:73s, 3:42s will work best with TPI.
Full exhaust headers and a cat-back, being on a budget, headers Edelbrock $300, exhaust Hooker cat-back $200 (sound clip is in the signature), gears and a TC.
Right there you'll knock well over a 1 second off your time, which would be low 13s. That's what you'll need to keep up with Stangs. The newer ones GTs run 14.2 stock, and around where I live good luck on finding a stock 80s style one, most are in the high 13s.
By the way, I love your car.
Old Apr 12, 2002 | 01:18 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Lose the "i've got a huge *****, I swear!" sticker, those are so gay
Old Apr 12, 2002 | 02:27 AM
come on guys, chill out on the sticker issue.. its his car, not yours. If he likes it, then thats all that matters. Thats why there is opinions out there, everyone has them.. cridom did not come here posting a subject that says " LIKE MY STICKER? " he is asking how to go faster, we need to stick to the point here.. he likes the sticker, good for him... thats my 02
nate
Old Apr 12, 2002 | 06:48 AM
cridom's Avatar
i like the sticker so stop it with that
i just realized that its a 305 tpi what can i do to make it 350? is there too much diff?
thanks
Old Apr 12, 2002 | 08:15 AM
Car: 99 Formula
Axle/Gears: 342
thanks
You'd have to get a different motor, being on a budget like you are, you can still get that 305 to run decent times.
Old Apr 12, 2002 | 11:44 AM
jobryan26's Avatar
With some mods you can run with a Mustang I have. I raced a guy at work 2 nights ago with a 95 Mustang GT 5-speed and beat him in the 1/4 but after that he had me. Good thing we were only running a 1/4. First thing is to completely tune it up. Get new Plugs, Wires, Cap, Rotor, Aftermarket Ignition Coil, Change all the fluids. Then check IAC and TPS Adjustments. Then modify or get a new Air Intake like a K&N filter and then start working on the exhaust.
Old Apr 12, 2002 | 12:58 PM
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Forgive me if I am wrong, but from some of your questions, it sounds like you are new to this. If anything we say is something you have never heard of, or just can't figure out, just ask. If you don't feel like posting it on the board, you can always send a personal message (PM) to someone.
Mod for mod a 350 will go faster than a 305, but that doesn't mean that you shouldn't stick with what you have. Engine swaps are big $$ (if you pay someone) or time intensive if you do it yourself. Also, a lot of parts are interchangeable, so you can reuse them if you decide to change from 305 to 350 later on.
Old Apr 12, 2002 | 01:27 PM
Car: 99 Formula
Axle/Gears: 342
I agree with everything you just said. I wouldn't be ashamed to ask anything on this board, I'm far from an expert on stuff, and I'm not afraid to ask a question, that's the only way I'll learn.
Old Apr 16, 2002 | 07:55 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Engine: Forged 350 with D-1SC
I have a 1991 TA 305 w/ 5 speed. Is this also true for my car?
Old Apr 17, 2002 | 05:38 PM
iroc22's Avatar
Should be.
Check your Service Parts Identification Label in your armrest/glovebox for "G92"
Old Apr 24, 2002 | 10:27 PM
mypontiac's Avatar
Car: 1991 Conv. TA
I don't have any labels in my glovebox/armrest. Any other way to determine this????
VIN # at a web site or through the dealer????
Old Apr 24, 2002 | 10:30 PM
Car: 99 Formula
Axle/Gears: 342
Do you have a lock box compartment in your hatch area, there should be a rpo sheet in there.
Old Apr 24, 2002 | 10:39 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Don't think so Mark. I have a 91' TA convertible. There is a well under the trunk, but no locking panels. Not sure where else to look.
The car is a 305 with 5 speed. It has a single cat since it is a convertible.
Old Apr 24, 2002 | 11:27 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
You could always go the nitrous route. Fairly cheap unless you are emptying the bottle every night. The civic boys swear by it, so it must be good!
Rob
Attached Thumbnails Acceleration!!!!!!!!!!!!!??????????-dafreeze-says-civics-wit
Old Apr 24, 2002 | 11:56 PM
mypontiac's Avatar
Car: 1991 Conv. TA
Actually I'd prefer the Vortech supercharger.
Put out the $$$ but it is always there!!!!!
Old May 1, 2002 | 02:08 PM
cridom's Avatar
Thanks for all guys !
Itook the sticker out cuz it looked like kinda ordinary.
i have only a few more questions, my car is kinda getting slower i dunno y but the rpms are getting high very slow like its not accelerating as much as before what could this be?
is it hard to install a hooker cat-back?is that the one with 2 pipes with 4 exits? is it hard to install headers? and how do i replace my left fan?(i have 2)
thanks
im getting headers, hooker cat-back,4 gen seats (lthr),4th gen center console,sfcs,and megashifter soon!!!!!!!!!!!!!!!!!!!!
Pac J
May 17, 2020 10:44 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ULTM8Z
Sep 16, 2015 09:15 AM
