Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
whitesmoke
Old May 1, 2002 | 10:29 PM
92RSMuscle's Avatar
whitesmoke
hey
i have an automatic 92 RS
i was wondering about white smoking the tires...how do i do it, and will it mess up my engine or tires or anything?
mike
Old May 1, 2002 | 10:41 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
What is white smoking?
Any time you burn tires you're putting stress on the car, especially power braking.
And obviously it's going to shorten the life of the tires.
Though I hear if you put bleach on the tires, you'll get some nice smoke, haven't tried it yet though.
Old May 1, 2002 | 10:49 PM
idrag2's Avatar
How to smoke your tires in a auto.......Put it in 1st and hold the brake, punch the gas and there you go, wait till the smoke good and let off the brake. Notice I said 1st if you put it in drive then there is a chance of braking something, because it goes from gear to gear and if your in 2nd or 3rd and it gets tracion all at once you could break a sprag in the tranny.....SPEAKING FROM EXPERIENCE.
Old May 1, 2002 | 11:22 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
personally, i wouldnt use bleach on your tires. sure, it gives off HUGE clouds of beautiful, beautiful white smoke but holy $hit does it give you a headache...SPEAKING FROM EXPERIENCE . try oil on your tires. works good, with no headaches
Old May 1, 2002 | 11:28 PM
VampireHunterC's Avatar
I read somewhere that you can drill a small hole in your wheel well, run some rubber line to a washer pump and resivour that you install in your trunk. Wire it up with a switch. Flip the switch and you get water on your tires. Spin away.
A friend of mine used to pour hydralic fluid on his tires to make them smoke.
Old May 2, 2002 | 12:15 AM
Paul_Hughes_87 T/A's Avatar
Car: Chrysler 300c
Engine: 5.7L Hemi
Transmission: 5spd auto
Axle/Gears: 2.89
i heard if you mix kool aid with brake fluid and coat the tires with it you will get smoke the same color as the kool aid never tried it so dont quote me on it
Old May 2, 2002 | 12:55 AM
HrdRockA4305's Avatar
Haha colored smoke... I wonder if you get that with Scorcher T/As! I've seriously only done this 3 or 4 times in the car... with 130,500 miles last I looked, I don't know how much abuse the poor 700R4 can take.
Thats what bugs me about the closest 1/4 mile track (still 96 miles away). You can't drive around the water box. At all. So even us guys running radial street tires gotta drive through it and do a burnout to get the dang water back off. Fun, but I still worry about breakin stuff. Oh well, if the auto blows, I'm puttin a 5 speed in and thats all there is to it.
Old May 2, 2002 | 11:00 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Or a TH350 j/k (maybe?)
Old May 3, 2002 | 11:15 PM
89Irocz23's Avatar
My dad told me once he pissed on his tires and smoked them cause he heard it would smoke yellow. he tried it and said it worked but stank so bad....lmao
Old May 3, 2002 | 11:40 PM
92superram's Avatar
If you use that wet tire shine stuff, and get some on the tread, it'll give you a nice white cloud.
Old May 4, 2002 | 04:23 AM
SkyWarrior's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
I have a lot of miles on mine, but I'll still smokem for anybody who wants a little! (I have gone through a tranny though!, can't tell ifit's cause I'm too hard on it, but probably.)
92RSMuscle
Aug 1, 2002 08:45 AM
