305 TPI how fast are they
Car: 1992 Z-28 Camaro
Engine: LB9 305 TPI
I wanna really buy a 87 iroc 350 but there pretty tuff to find. What will a stock 87 tpi 305 run in the 1/4. Im thinkin about gettin one and i dont want to make a mistake.
Car: 88 IROC Convertible
Transmission: Raptor 700
a 305 in good running order should run mid 15's with decent traction. with headers adn exhaust i'm guessing you'd gain around .1-.2 seconds off your ET which isn't bad at all. if you could get one with the 5-speed, stock for stock they're almost as good as the 350 auto's.
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
Originally posted by 84z ricecooker
what about a 350 with a stick
yeah, if they made them
damn weak t-5's
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
dont forget about the gears. 89+ you could get the g92 where you get 3:45s and dual cats, i got 3:08s and a single cat
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
the g92 had a 3.45 right...well i dont see much of a difference between a 3.45 and a 3.42...the gu6 rpo.....what exaclty did the g92 represent....i know my car doesnt have the g92 rpo but i run with 350's
Car: 2001 Formula
Engine: LS2
If you're interested in speed I say go for the 350. The g92 305 will keep up with a 350 but thats stock. A couple of mods here and there and the 350 will take it no problem. If you don't really care about speed then go for the g92 as they are not that common.
my 305 stock ran a 15.3 at 89mph. then i put a cone air filter and ported my plentum and ran a 15.1 with a little wheel but still managed to get a 2.1 60ft so you should be in the low 15s with an auto and prolly high 14s with stick
Re: 305 TPI how fast are they
If you really want a IROC 350, just wait til you find one. Don't settle on something you don't want just because you want a car.
Originally posted by wes2k3
I have to disagree. I have been looking for a thirdgen forever, I have now lowered myself to buying a V6 car because here in Illinios you have to look real hard to find a car that isn't rusty. I just need a good body.
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
the g92s have 225 hp, cause of the dual cats and the same cam as the 350?(not sure on that). to find the g92 rpo code, on 89-91.5 it should be in the center console, on 91.5-92 it should be in the little compartment in the hatch. cant rush finding a car, took me 7 monthes
Oh, and dude, I waited 2 years for the right black/350/posi/4 wheel disc Iroc-Z, and I know how frustrating it can be because I thought about just getting a 305 also, since that was all I could find, but believe me its much better to wait for exactly what you want. If you just need transportation that's different, but when you want a really specific car, its better to wait for the right one.
I have both an 89 305/5 speed 3.08 gear converted to speed density with hypertech chip and a 87 350 auto, 3.27 gear pretty much stock but the K&N's. The 87 wins hands down. I have no quarter times to back up the claim but trust me I know my cars. Quote from a fiend of mine after riding in the 87 and then a few weeks later in the 89. "This car gets up a little quicker because of the stick huh?" Then I punched it in first and ran it out to third. "It doesn't quite give me the butterflies in the stomach that the red one does." One point to remember when shopping for G92 cars is there was no G92 with the 350 in 87 cause all 350 cars in 87 had the Borg Warner 9 bolt with 3.27 gears. In 88 and up I believe you had to specify G92 to get the 3.27 gears.
Rich
Rich
Sanjay
Aug 12, 2015 03:41 PM
