TexasLT1 vs. pasky vs. calereeves
For the past few days pasky and I have been doing a CC306 cam swap on his car. His mods are now:
'95 LT1
TB airfoil
CC306
Proform 1.6 rockers
Cloyes Double Roller timing set
CVR electric water pump
SLP 1-5/8" headers
T-56 with 3.42 gears
I've got:
'95 LT1
LT4 heads, Hotcam, Intake
30# injectors
52 mm TB with airfoil
Proform 1.6 rockers
Hedman 1-5/8" headers with custom 2-1/2" y-pipe and Mccord 3" electric cutout
T-5 with 3.42 gears
Nittos
calereeves has a '78 Trans Am with a BBC 462 swap, TH400 with 3500 stall, 3.73 gears, custom 3" true duals. Best run before was a 12.1 @ 113 but we think the previous convertor was ballooned since the first run.
First race:
-TexasLT1 vs pasky
Started from a dead stop with my cutout closed, I hooked, pasky didn't and I pulled about 2 lengths on him through first gear. As we hit second he began pulling up on me. By the time we shut it down at about the 1000' mark he was at my door and very slowly pulling on me.
Victor: TexasLT1
Second race:
-TexasLT1 vs pasky
Due to pasky's severe traction problems, we started from a 15 mph roll. I opened my cutout this time as we decided to go for the full 1/4 mile. At the launch, I jumped at least a full length on him, but through second gear he pulled back up on me. From the start of third gear and all the way to the top of fourth gear, he stayed glued to my door and never moved. We topped out at 130 and he was still at my door. At that point we shut it down.
Victor: neither, I won the race, but my transmission was stuck in 4th gear until I pulled over, shut the car down, and let it cool down for a minute. I'm still having problems with it getting stuck in 4th just driving around.
Third race:
-pasky vs calereeves
After dynoing only 325 at the wheels on Wednesday, calereeves found out that his torque convertor that was supposed to be a 4000 stall had totally ballooned and had become about a 6000 stall. After getting it rebuilt as a 3500, the car feels totally different and pulls much harder. Starting at a 25 roll, the two cars were side-by-side through first gear. However, it quickly ended when calereeves hit second gear. As pasky shifted into 3rd gear, calereeves had about 6 lengths on him and was pulling hard. We believe his previous best of 12.1 was also on the ballooned convertor, so we are anxious to get new times. With slicks and skinnies, we're very confident it is an 11 second car.
Victor: calereeves by a LOT
Video of races 2 and 3 will be posted in the next few days
Despite my tranny problems, it turned out to be a very fun night. As the saying goes, "the **** talking stops when the gas pedal drops." Better luck next time pasky
'95 LT1
TB airfoil
CC306
Proform 1.6 rockers
SLP 1-5/8" headers
I've got:
'95 LT1
30# injectors
Proform 1.6 rockers
T-5 with 3.42 gears
Nittos
First race:
-TexasLT1 vs pasky
Victor: TexasLT1
Second race:
-TexasLT1 vs pasky
Third race:
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Originally posted by r3pp3r
Shouldn't your car be faster than pasky's given your respective engines?
Originally posted by pasky
Not when you got a gigantic cam like I do. Mine also seems to be one hell of a strong motor. The electric waterpump frees up 10 rwhp. Th cam is gigantic and makes power all the way to 6500 rpm and only drops 7hp at 6800.
intake duration: 232
exhaust duration: 244
Intake lift: .510
Exhaust lift: .540
With the 1.6 roller rockers im at .540/.570 lift.
Come get you some
Intake lift: .510
Exhaust lift: .540
Come get you some
. Trending Topics
Another factor is the T-56 first gear ratio. Its not as steep as the T-5's gear ratio. For me its like having 3.23's in a normal t-5. It was still a lot of fun. That was one hell of a race the second time.
Intake lift: .510
Exhaust lift: .540
Come get you some
Intake lift: .510
Exhaust lift: .540
Come get you some
. If I remember right its .510/.540 lift, 230/244 duration on either a 110 or 112 LSA (cant remember which).
Even with the LT4 setup on the other LT1 I would have thought the CC306 car would have pulled ahead on the top end for sure...
How's the T5 doing with that kind of power and DRs?
I do pull over him up top, I begin to walk away from him, I still have 25# injectors on and my lifter on my #7 cylinder is collapsing. But im not gonna make an excuse, I chose to race with what I had. Next mods im going to do is an electric cut out and 30# injectors.
Simply put, incredible. I have beat the absolute **** out of my car. After this race was the first time I've ever had problems with the transmission, and I've been racing on drag radials for almost a year now. At the track I was doing 4K clutch dumps on the launch and shifting hard at 6100, only complaints I ever got out of the transmission was a slight grind going into 2nd.
Hahaha, that gives me a sense of accomplishment .
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Man I want to see that video. This guy wouldnt happen to be the black T/A with huge hood scoop and fat A$$ tires would it? If so that car is baaaaaddd. Man I want to swap a T-5 into my car.
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
hey pasky, get some 3.73's or 4.10's with that t-56 and a good sticky set of drag radials and I bet Texas Lt1 won't like the rematch.
No clue, but his hp curve is so fricken flat. It starts at like 317 and goes to 325. That was a mustang dyno. He has tons of torque with that big block but that hp is so ridiculous. I don't think he dynoed with the 3500 stall. Not sure. He took me for a ride while I was up there and wow....I want a big block in a thirdgen now.
that is one flat power curve...lol..
heh, you could say that. It started at 321, went up to 325. Alot of that had to do with the convertor, but it is still a rediculously flat power curve, which explains why it doesn't have the same seat of the pants feel as my car, similar to the way LS1's feel.
Car: 89 Camaro RS
Originally posted by TexasLT1
That was indeed a badass T/A, as soon as I saw him pulling into the parking lot I was walking towards it. If you went to the Christmas meet last year my brother's car was the then-white '78 T/A that was parked on the end. Now its metallic silver with a pearl blue Air Force hood bird and a BBC 462 under the hood with Cragar wheels. I think he was out with his girlfriend Saturday night since she was going back to school yesterday, so he didn't go to the meet. I didn't get a chance to talk to the guy that had the black one, but I told my brother about the car and he thinks he knows who it is; supposedly has a pretty mean 427 under the hood.
Car: 89 Camaro RS
That would have been cool if you did know the guy I want to see that car at one of our meets. And no I didnt see your brothers car before because this last meet was the first one Ive attended after trying to make two others and missing them. But I plan on attending plenty more and hopefully doing the group dyno thing. Man we need to all head out to the track for the next meet so we can show everyone some real thirgens instead of the slow a$$ stereotypes everyone is used to seeing.
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
FINALLY got the videos of the races. Quality is down a little as it was sort of foggy that night, plus the quality from a digital camera just isn't that great, but you get the idea. Also, I'd turn the volume up on the first one definitely
TexasLT1 vs pasky
pasky vs calereeves
From now on I hope to get better video, as I wasn't too impressed with how these turned out, plus cameraman that can actually hold it steady
TexasLT1 vs pasky
pasky vs calereeves
Car: 1999 Z28
Transmission: A4
damn that 2nd gen RUNS!!!!!!
both of your lt1 cars sound incredible. Pay for my plane ticket, i can hold a camera still!!!!! I will even detail your car while im at it
