need ET estimate
Car: 91 Z28
Transmission: 4l60e
need ET estimate
ok guys im planning on getting a 350 and would like to know what i would be running with the following mods
HSR (Holly Strealth Ram)
Hooker Super Comp Headers
LT4 Hotcam
2800 stall converter
custom chip work
125 shot of nitrous
i was also thinking about porting the heads
i was thinkin around mid 12's with traction
LT4 Hotcam
custom chip work
125 shot of nitrous
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You should see high 12's on motor alone and low 13's all day long. That combo will put aroud 330 to the wheels. With spray you should be deep into the 12's.
Car: 91 Z28
Transmission: 4l60e
yea that what i was figuring around low 13's on the motor and mid to low 12's on spray. even my hp guess was around 330 so with the spray ill be pushing around 450. im also going to be getting the heads ported and its getting bored .030 over to a 355 and getting port and polished.
lol i hope i run into that mustang again "that runs 12's" so i can show him what a true 12 second car looks like
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Car: 91 Z28
Transmission: 4l60e
well the HSR adds at peak around 40-60 hp also the heads are going to be reworked and ported, just that would produce more than 280hp
oh and by the way this will be on the 350 not my 305 that is currently in the car, also take into account that all the mods that are on my 305 will be swapped over. altough i will have to go with a diff spark plug cuz ive heard bad things about running platinum spark plugs with nitrous
Car: 1991 Camaro Z28
Engine: TPI 5.7 L
Transmission: 4L60 w/Vigilante 2,400 Stall
Axle/Gears: Girdled 10 bolt/3.23's
I'd have to agree with Shifty! Easily low 13's-high 12's on engine and low 12's-possibly high 11's on spray! Dyno numbers can be deceiving. Dynojet or Mustang? SAE Corrected or not? I dyno'd 253 RWHP and 362 RWTQ uncorrected on a Dynojet and sig numbers on a SAE corrected Dynojet. Is the 350 going to be a L98 or something else?
Car: '90 RS
Engine: 377 LSX
Originally posted by FbodTrek
330? hardly, not to knock, but I don't see that happening with stock heads. HSR is pretty trick, but it's not that trick. I would guess hp closer to 280 at the wheels, if it's tuned right. Cars don't sem to dyno as high as people think. I seen a Ported Vortec headed, .500+ lift cammed, car with all the goodies dyno only 215...wasn't with HSR, it was with a amtched Intake and carb. i dunno, maybe I'm not giving it enough credit
Car: 91 Z28
Transmission: 4l60e
if i run pray i will have to change my spark plugs right? cuz i hear that u cant run platinum plugs with nitrous because it supplies to hot of a spark. is this true or will the spark plugs i have be fine with nitrous?
