Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
93' lx 302 vs. 89' formula 350
Old Mar 6, 2005 | 05:58 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
alright, this kids got a bone stock 93' lx 5 speed, with a stock rear, (2.73's i think) with possibly a cat back, i have a
full edelbrock exhaust, including street legal headers, and 3" all the way back to the muffler, no cat. #23 injectors, chip, newly machined 305 heads, stock posi rear (2.73's) and a 700R4 with a shift kit, and a B&M rachet. we'll probably race as soon as his cars on the road... who do you guys think will get smoked?? i think eventually he's putting in 3.73's and an aluminum driveshaft... but thats after the first race. lemme know what you guys think, thanks
Old Mar 6, 2005 | 06:15 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
You're toast
Old Mar 6, 2005 | 07:35 PM
25thmustang's Avatar
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
I think you should take him. His gears are gonna kill him!
Old Mar 6, 2005 | 08:35 PM
bigchief's Avatar
haha thats funny, the guy w/ the fbody says im done and the guy with the stang says ill beat him.... anyone else have a say???
Old Mar 6, 2005 | 08:44 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
if your car will win. (unless you don't have it running right)
Old Mar 6, 2005 | 08:46 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Pending you PROM is dialed inyou should beat him. The stock TPI will seriously hinder your top end on that motor though.
Old Mar 6, 2005 | 08:51 PM
bigchief's Avatar
i'm thinking of getting the high flow edelbrock base and runners.... any idea of how much taht will help my high end???
Old Mar 6, 2005 | 09:05 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Go with a stealth ram or mini ram. Any aftermarket long runner TPI set-up isn't much better than stock.
Old Mar 6, 2005 | 09:32 PM
TPI-454's Avatar
Car: 1989 Trans-Am
Engine: 454-Motown SBC w/HSR
Transmission: 6-Speed
HSR
Old Mar 7, 2005 | 12:52 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Ahhhh Just thought I'd get things going. But seriously thought, like someone mentioned if you have you're set-up in tune and running up to par you shouldn't have a problem (that's if he's a pretty much a stocker). Happy sailing
Old Mar 7, 2005 | 05:10 PM
bigchief's Avatar
hmm well i think i have a pretty good chance.... how much of a better chance with a 5 speed or a 6 speed manual???
Old Mar 7, 2005 | 05:15 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
the 5 speed will keep you in your upper powerband better with that extra gear, the six speed wont make any difference unless its a richmond close ratio.
Old Mar 11, 2005 | 02:18 AM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
I don't know of any 5 speed 93 LX Mustangs with 2.73 gears 3.55 maybe. Do you have 1.6 rockers? If you don't get some your gonna need that extra hp your cam has a pretty low lift. That LX is light very light an you have a auto which makes you alot heavier. Only thing I can say is make sure your tire pressure is a little low so you can hook up better. Because if he gets the kick this race is over. I'll be PRAYING FOR YOU!
Old Mar 11, 2005 | 02:52 AM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
I think you should save the money you will spend on the intake and buy some gears like a 3.42 or 3.73 with a posi. i gained almost 4/10's of a second from a 3.23 to a 3.73
Old Mar 11, 2005 | 10:45 AM
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
If he has stock gears he most likely has 2.73s. Most came with 2.73s, the stick cars had the option of 3.08s, and the autos could be had with 3.08 or 3.27s. But from what I have seen the majority came with the 2.73s, whether auto or stick!
Old Mar 11, 2005 | 11:04 AM
bigchief's Avatar
well, this ended up being a much more interesting thread than i originally thought haha... anyway, i think his cars gonna be ready next week, and once its on the road, the race is on. Ill be sure to lower my tire pressure. any other helpful hints??
Old Mar 11, 2005 | 12:50 PM
Car: 87 IROC
Take out your front sway bar for the race an put it back after.
That will definitely take a couple of tenths off your time but goes around curves like crap! If you got a couple of hundred to spend a guy on ebay sells control arms and panhard bar for $159 and control arm relocation brackets for $59. Get your suspension tight lower springs helps also. If you haven't touch that intake do some mild porting to the plenum thats a cheap inexpensive mod you can do also. An be sure to take out the spare and jack and hope you don't get a flat on the way there!
Old Mar 11, 2005 | 03:22 PM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
I took off my front sway bar and i haven't really noticed much of a difference in normal driving. It still handles corners okay too. This helps the nose come up and plant the rear tires.
You can also swap in a fresh set of plugs and wires, run the gas tank low and keep it at 1/8 of tank of premium with a bit of octane boost too. With the good gas you can advance the timing a bit more maybe. A battery relocate to the trunk may help traction... Find out where you will be racing and go practice launching too. The first 60' will decide who wins this one. Make sure your motor is nice and cool before you run...
Old Mar 11, 2005 | 10:30 PM
bigchief's Avatar
sounds good boys, i dunno about taking out the sway bar lol but ill definetly try to take out some access weight like the spare and stuff. maybe ill get an air hog or something too instead of using that oem filter.... ill let you guys know what other little things i might think of, thanks a lot! keep the ideas comming if you have any others
Old Mar 12, 2005 | 07:36 AM
TPI-454's Avatar
Car: 1989 Trans-Am
..any other helpful hints??
Prayer. j/k
Old Mar 18, 2005 | 07:17 PM
Mustang5L5's Avatar
2.73's was the standard gear from '86 to '98. You could get optional 3.27's on automatics and optional 3.08's on 5-spds.
Saleens had 3.55 options during the fox years.
Old Mar 18, 2005 | 07:34 PM
bigchief's Avatar
what gears would you guys suggest over my 2.73:1 gears?? i was thinking 3.42:1 let me know, thanks
Old Mar 19, 2005 | 02:15 AM
2QUIK4U's Avatar
Car: 1991 Z28
Engine: 5.7 TPI L98
I suggest 3.73's with a 700R4. I have had 3.42, 3.73 and currently 4.10's. My car isn't my daily driver anymore so i like the steep gears. Im not on the highway much with it anymore.. With the 4.10's im at 2700rpm @ 60 or so. The 3.73's i think i was at 2350rpm. The car is almost 2 tenths faster with the 4.10's from 3.73's and 4 tenths from the 3.42's...
I think the 3.73's give you the best of both worlds.
Old Mar 19, 2005 | 11:50 PM
bigchief's Avatar
sounds good man.. ill get the 3.73's off summit as soon as i get the rear... i was gonna just get a junk yard rear and put gears in it, and rebuild it. my rear is pretty much not rebuildable b/c my dad tried to take it apart but he couldnt b/c he said the pin that your supposed to take out to dissasemble the rear was impossible to get out.... his diagnostic was too many burnouts lol... also the car has over 240k on it.. so whatever. anyway, thanks for the suggestion
Old Mar 22, 2005 | 12:22 AM
bigchief's Avatar
we raced tonight anddd i WON he had 3.73's, an aluminum driveshaft, and a cat back.... i had the injectors, the chip, and the cat back.... we raced 2 times, the first time he got a bad launch and i beat him by about 3 cars, the 2nd race his launch was a lot better, but i still beath im by about a car and we were pretty much even at the end of both races in acceleration, no one was really pulling on the other... it was awsomeeeeee
Old Mar 22, 2005 | 12:47 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
gratz on the safe kill.
Old Mar 22, 2005 | 02:16 PM
Car: 87 IROC
HELL YEAH!! Good Kill man!
Now I'm even more upset that my car still isn't running.
Old Mar 22, 2005 | 04:58 PM
bigchief's Avatar
haha yeah definetly, all i need to do now is put the headers on, and then ill be set until i decide to touch the heads which wont be for a while. i also want to do the rear this summer, we'll see what happens.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
okfoz
Mar 9, 2017 02:35 PM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
angel2794
Sep 8, 2015 06:22 PM
