74 Formula VS 88 IROC
Car: 89 Formula
Transmission: TH 700R4
Here are the specs:
99% stock 74 Formula 400: 225hp, TH-400/3.08s. Heavy car--has a/c, pw, pdl. About 3800lbs
100% stock 88 IROC with the 170hp 305 TBI/700r4/2.73--most options, hardtop car. 3350lbs
Who do you think would win? what times?
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: 74 Formula VS 88 IROC
Car: '90 Mercury Grand Marquis GS
Engine: 5.0L Ford V8
Transmission: AOD
Axle/Gears: 8.8" Ford, 3.08:1
Cut out the catalytic converter if you have one and bolt in a straight pipe. Buy an Edelbrock intake and Holley 750 cfm carb. Don't forget to post the results from the race.
Car: 91 z-28 conv.
Engine: 350 vortec tpi crate
no cat on pre 75s.
a big yes on headers, duals, intake, and maybe the carb. i personally had a lot of luck with the quad.
i had a 75 TA with 400 and 4 spd and it was pretty sad til i put the headers, duals, and dominator intake. re-curved the distributor and juiced up the carb some. she was sweet then. cracked 140 with it.
a little goes a looong way with a 400 cube engine.
Originally posted by slohand.a little goes a looong way with a 400 cube engine.
Car: 89 Formula
15.8 for the Firebird and 16.2 for the Camaro.
Oddly enough the Camaro is faster off the line but acceleration falls off after the 1/8 mile. Thats where the Pontiac pulls ahead.
Guess the 3.06 first gear and the lighter weight do that. Not much low end in the Pontiac.
Car: 1989 GTA trans am
Engine: L98 350 tpi
Transmission: 700r4 built
Axle/Gears: 3.45 4th gen 10 bolt
my 2 cents
well its easy to open those pontic 400 up to some high numbers .unlike the l03 witch is a waste of money to modd.with under $1600 the 400 could be running with stock ls1s
Car: 87 Formula 350 / 89 Firebird
Engine: L98 / 2.8 V6
Transmission: 700r4 / 700r4
Axle/Gears: 9 Bolt 3.27 / 10 Bolt 3.42
Give that poncho some ram air heads, a healthy cam and longtubes. Then so smack around some ls1s.
Engine: L98 350 tpi
what???
how would you know all you have is a 2.8 and a l98 ???
have you ever seen a 400???
what kind of a stupid name is slinkoguy.i bet your some nerd working at a game store .why dont you go play some worlds of warcraft and leave us alone.
I agree GodSpeedGTA, but I also dont think the bird will have anyproblem at all killing an l03. Bird wins hands down, Iroc has no chance.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
mustangman65_79
Aug 11, 2015 03:17 PM
