Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Another "what will she run" post :)
Old Oct 6, 2005 | 08:49 AM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Well like the title says...
1991 Corvette block bored .030 to a 355. Aluminum L98 vette heads ‘113’ casting with slight bowl/blend job and beefier springs to handle cam. Running MAF with a custom chip...
- LCA's, Panhard bar, Subframes, strut tower brace, poly engine and tranny mounts.
- Vigilante 2800 stall TQ converter w/ transgo shift kit in tranny, with B&M tranny cooler
- Stock 3.23 posi rear
- 1.6rr with Lingenfelter (i think Superram cam)
- SLP 1 3/4 headers, Random tech Cat and Catback
- TPIS big mouth manifold, Ported Plenum, and for now stock runners and TB w/ Airfoil and K&N filters running through the stock air cleaner. (52mm TB and AS&M runners coming for the spring).
- Sitting on Bridgestone p245/50ZR16’s.
She is probably a heavy girl as she has power everything, T-tops and all…
So what do you guys think? 13’s? LT1 territory… Even LS1 territory? Fill me in…
Old Oct 6, 2005 | 09:24 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What are the specs on the cam and what sort of tuning have you done? Without those two factors your car could run mid 14's or 12's.
Old Oct 6, 2005 | 10:25 AM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Cam specs are: 211/219 duration @ .050 .530"/.560" with 1.6 rockers
had the chip done by fastchips. Still need to Time and set the fuel pressure (have a Crane AFPR on the car).
That help at all?
Old Oct 6, 2005 | 10:41 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Assuming it has headers and its been tuned right, I wouldn't expect anything worse than low 13s if you can launch it right.
Old Oct 6, 2005 | 11:23 AM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
high 12s with a kickass 60'
Old Oct 6, 2005 | 12:01 PM
Car: 1997 Corvette
Old Oct 6, 2005 | 12:11 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Can I post what I have and see what you guys think I will run?
I do not have cam specs right now, but when I get off work I will.
If you don't want me to post in this thread I will make another. Thx
Old Oct 6, 2005 | 01:44 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Id say low-mid 14's. If youre lucky, youll bust off a high 13.....maybe.
Old Oct 6, 2005 | 02:16 PM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
84L69TA
Really low to mid 14's? I would think she would at least have a 13.99 in her. But I guess thats a trip down the track to prove or disprove isnt it.
Thanks guys for all the insight, I am hoping to get her back from the place thats putting on the headers and cat for me by tomorrow or Saturday. I'll probably be pondering this question the whole winter because the new engine hasent even seen 250 miles yet. I dont want to kill her during the break in period.
I am just hoping to see a 13.xxxx something wouldnt care if it's .99 or a .00 Coming from a 15.9 @ 85mph 305 this will seem like a dream...
Old Oct 6, 2005 | 04:13 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
That should be an easy 13 second combo. How much tuning did fastchips really do? Did they have access to the car for dyno tuning or was it mail order?
Old Oct 6, 2005 | 04:22 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
I say 13.2-13.4, doubt it'll run in the 14's.
Old Oct 6, 2005 | 06:54 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
mid 14s is what a stock 350 TPI should do. your combo (if the tune is good) should put out a high 12 or so with mph in the 102 - 105mph range providing you dont blow the launch
Old Oct 6, 2005 | 09:07 PM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Now those are some responses I like to see.. So the majority feel 13's is pretty safe to say. Thank ***! Maybe when I actually learn how to launch and such and throw some slicks on she could hit the 12's ..... Someday
Old Oct 6, 2005 | 09:09 PM
superGMman's Avatar
Engine: 22R-E
Axle/Gears: 4:??
I seriouly doubt that even a bad driver can do worse than a mid 13 in that car, looks like a good combo.
Old Oct 6, 2005 | 09:19 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
You're kidding right?
Old Oct 6, 2005 | 10:51 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Low to mid 13's wouldnt be unreasonable at all
Traction is going to be your biggest enemy for sure.
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Linson
Sep 21, 2015 01:08 PM
Strick1
Sep 6, 2015 02:21 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
