Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Who wins ??
Old Feb 7, 2006 | 02:48 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Who wins ??
A 05' RX-8 ; 5 speed vs. Me ? As far as i know the Mazda is stock. Test your racing knowledge. lol
Old Feb 7, 2006 | 02:59 PM
SleeperFromHell's Avatar
Car: 92 RS Vert, 86 Iroc
Engine: Blown 350
Transmission: Slushbox
They're 15 flat cars. Should beat him
Old Feb 7, 2006 | 03:11 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
It will be close, but i think you got it.
Old Feb 7, 2006 | 03:15 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
race is really between the drivers however you have the advantage.
i say f-body wins
Old Feb 7, 2006 | 06:45 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
f-body
Old Feb 7, 2006 | 07:05 PM
stu's Avatar
stu
The RX-8 has a more reliable and generally better motor than the third gen RX-7, but they're much slower. I think you've got this one.
Old Feb 7, 2006 | 07:06 PM
Car: ws6
Engine: ls1
Transmission: m6
Now if it were the newer RX-7 it would be a different story.
Old Feb 7, 2006 | 08:04 PM
twobirds's Avatar
Car: 1987 GTA 350
Transmission: 700R4/2400 stall
Axle/Gears: B/W 3:27 posi disc
What they said already.
Old Feb 7, 2006 | 09:09 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What is done to your car? What is in that "350" of yours and what induction is on it? Without knowing that info your car could still be in the 16's.
Old Feb 7, 2006 | 09:20 PM
Car: ws6
Engine: ls1
Transmission: m6
He has a 350. opps I saw RS and missed the 350 in his sig. .
Old Feb 7, 2006 | 09:37 PM
redcamaro1989's Avatar
Car: 1989 rs RIP, 96 grand marquis, 92rs
Engine: LO3, 4.6l, L03
Transmission: 700r4, AODE,700r4
Axle/Gears: 2.73, 3.08, 2.73
it says tpi in his sig. i belive you would have it. my uncle has one and im really not that impressed with it
Old Feb 7, 2006 | 09:42 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
TPI on what engine though? Stealth ram, super ram, mini ram, ported OEM TPI, wide mouth base, etc etc. These are all "TPI". If you put a stock OEM TPI system on a 150hp '76 350 truck motor he will probably lose. If he has an worked L98 with a dyno tuned TPI set-up (take your pick from the above) he will win.
Old Feb 8, 2006 | 02:58 PM
Car: 92'Camaro RS
Engine: a loud one
The TPI set up is just a OEM set up.All i really know about the motor is it's a 350 targetmaster comp. motor.(roller cam)
Old Feb 8, 2006 | 03:02 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Do you have a link so I can check out the specs?
Old Feb 8, 2006 | 04:46 PM
Car: 92'Camaro RS
Engine: a loud one
I wish i did. I wanted to find out that info myself. All i know is a friend of mine bought the engine here..http://www.atk-engines.com/
Although i couldn't really find anything on the targetmaster motor on the site. I know the papers i got w/ the engine said targetmaster comp. But there were no specs with the engine.
Old Feb 8, 2006 | 05:11 PM
lilbowilson's Avatar
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
I think it might be a close race because I'm not really seeing anything special that would put his car in the 13's. Well maybe low 14's so I guess david roush will win.
Old Feb 10, 2006 | 12:23 AM
Car: 92'Camaro RS
Engine: a loud one
Well you all know your stuff on this board...I won.
Old Feb 10, 2006 | 06:20 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Details?
Old Feb 10, 2006 | 07:24 AM
fastfbody's Avatar
Car: 1989 GTA trans am
Engine: L98 350 tpi
Transmission: 700r4 built
Axle/Gears: 3.45 4th gen 10 bolt
a buddy of ours has a low miles targert master 350 .it runs perfest but i have never seen a motor scream im a stock 350 more .hes got long tubes duels and air gap intake and a 650 holly with a trick sift 350th. it wont spin the tires of the line and its still like blah.i dont know if your motor is the same way but he got the 240hp model i think . to my understanding they didnt make any stronger then that.it is a 350 so at the end of the day it can be bada$$ maybe yours is.
Old Feb 10, 2006 | 03:14 PM
Car: 92'Camaro RS
Engine: a loud one
Well i have a 5 speed TPI so in first gear the car will spin till it wants to kick out sideways,definitly burns the tires off in second for about 10-15 ft,and even can chirp/spin third a little sometimes w/ stock 3.08 gears. Not that it's the baddest motor around, but it has no "get up and go" problems.Well at least not to about 3000-3500 rpms.
Anyways i am not really huge into street racing but i was traveling the interstate the other day and it was wide open. This kid came flying up beside me while he was in the slow lane(I guess where he belonged)and just hung right at my door. So we slowed down to about 30 mph to start. I really never saw him beside me after i hit 4th gear but when i looked at my speedo i was around 95-100 mhp and he was about 15-20 car lenghts behind. I don't know when he gave up but he did. Turns out he knows a guy that works for me. He told his friend he was pi$$ed and wants to sell his car now.
Old Feb 10, 2006 | 04:07 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
on the 15-20 car lengths behind.
Old Feb 10, 2006 | 06:26 PM
Car: 92'Camaro RS
Engine: a loud one
More??????
Old Feb 10, 2006 | 06:37 PM
Nate86's Avatar
Engine: 4 cylinder
The length of 2 1/2 average sized cars is probably about a bus length. So essentially what you are telling us is that you beat the kid by at least 6 school buses? If he was even remotely trying to race you, I don't think you would put that many lengths on him, especially not when you shutdown at around 100 MPH.
Try again.
Old Feb 10, 2006 | 07:03 PM
stu's Avatar
stu
Try again indeed. Reading again.
Old Feb 10, 2006 | 07:34 PM
Car: 92'Camaro RS
Engine: a loud one
Thanks Stu.....comprehension is everything.
I was giving Nate the chance before i threw up a at his .
Old Feb 11, 2006 | 12:35 AM
Car: 87 IROC
Isn't that the sweetest thing to hear when you spank someone! Sounds like you got yourself a nice little mean machine. If you ever come to Greensboro NC let me know I would like a peice of that Target Master!
Hotrodboba400
Dec 10, 2019 07:07 PM
Nervous2
Oct 8, 2015 10:53 PM
Angie Coots
Sep 23, 2015 07:42 AM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
