Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
305TPI vs. a slug
Old Feb 28, 2007 | 11:07 AM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
305TPI vs. a slug
Who's gonna win?
Am I going to break into some stock L98 1/4 mile times with these mods? *It's an auto*
Hooker super comp shorties
3" y pipe
! cat
3" catback
TPI airfoil (wooopdeeee)
gutted airbox
4th gen 10 bolt with 3.42's
Obviously I'm doing bolt ons for right now until I can build a mean L98 block for the car.
Old Feb 28, 2007 | 11:39 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Maybe...
Friend of mine in hs had a 86 305tpi auto iroc with pretty much the same mods that just could not keep up with my 89 l98 in totally stock form.
Of course youve got a better cam, but his was a hardtop.
How well the ol' boatanchor has held up over the years will make a big difference obviously.
Old Feb 28, 2007 | 11:57 AM
BlueZee28's Avatar
Originally Posted by rocluvr0013
Maybe...
It's held up great actually. It's about to turn 89,000 miles in a few days And it's got a bad rear main seal, but other than that it's a great runner. It actually beat my old '89 IROC-Z that was a 305tpi/auto, and that car was a hardtop if that tells you anything.
*I race my old car with only a cut out, air foil, and gutted air box. I haven't bought the headers and exhaust yet...soon though.
Old Feb 28, 2007 | 11:59 AM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Originally Posted by BlueZee28
Who's gonna win?
3" y pipe
! cat
3" catback
gutted airbox
This is the G92 IROC we're talking about, right? Those mods against a stone stock L98 should make for a good race.
Old Feb 28, 2007 | 12:45 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
You'll be lucky to hit a flat 15 quarter with those mods. I don't think you'll be at stock L98 times.
Whats the slug your racing??
Old Feb 28, 2007 | 03:05 PM
atc3434's Avatar
Car: 1986 Camaro SC
The G92 305 was only 15hp shy of the L98 stock for stock, I would think with headers and full exhaust that you'd have a very close race.
Old Feb 28, 2007 | 05:34 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
If you pay close attention you'll see that even in the L98 community there is almost a full second range for modded cars. Some good advice would be to get long tubes and a nice 3in exhaust, or dual 2.25/2.5's with a flow through style muffler, heat and raise the lip on the air box a bit, and get a good tune in the car. I'm not sure what the hot ticket for a 305 tune is but the ARAP bin worked amazingly well for me. Perhaps if you drop it down to 19 pound injectors it will work?
P.S. The hot *free* ticket for these cars is fully porting the base and siamesing the plenum/radiusing the runner entries you could also try siamesing the base a bit. I believe it was Madmax that did this and gained power all around on his 305.
Old Feb 28, 2007 | 07:17 PM
BlueZee28's Avatar
First off I'm referring to the convertible, cuz I said it's an auto. The IROC is a 5spd.
I forgot one other thing that someone mentioned here. I was planning on having my buddy port the plenum and base, and siamese the runners. Then I would need to get it tuned at the local Fbody shop. I better break into the lower 14's when it's all said and done.
Old Mar 15, 2007 | 08:05 AM
MidnightBlue07's Avatar
Car: Z28 / GT
Engine: TPI 5.0 / 3V 4.6
Transmission: A4 / M5
Axle/Gears: 3:23 / 4:30
I can see you in the 14s right now with your mods.
also...I''m not trying 2 be off topic but similar to BlueZ28 car, would a 86 Iroc 305 TPI be onpar with a L98 with the mods below
- Edelbrock Hi-flo Intake
- Edelbrock Hi-flo runners
- Comp Cam Magnum 270H. 0.50 . 224/244 Dur ..470/470 lift
- Comp Cam 1.5 rockers / kit
- TPIS airfoil
- 2055 hooker headers / Y-pipe
- 3in custom catback exhaust
- 3:23 gears
Old Mar 18, 2007 | 12:59 AM
Jeremy Z28's Avatar
Car: 92 Z28
Engine: LB9
Axle/Gears: 10 bolt/2.73
- TPIS airfoil
- 3:23 gears
So long as it's tuned I'd say it'd be a good race.
Old Mar 18, 2007 | 02:27 AM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
My G92 91 Z28 runs 14.5 1/4 mile times with just cat back exhaust and some drivetrain mods. Changed gears from factory 3.42s to 3.73s. Now can't hook up in first gear, runs 14.7s. Should keep up with a L98
3.8TransAM
Sep 17, 2015 02:16 PM
Jk_Under
Sep 8, 2015 08:13 AM
86iroczwv
Sep 3, 2015 06:21 PM
jbd1969
Aug 17, 2015 07:06 PM
Stell1579
Aftermarket Product Review
Oct 11, 2000 10:47 PM
