Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Can I beat these cars?
Old Mar 14, 2007 | 09:18 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Alright, there are a few cars around that I would like to know if i can beat.
My car is a 1985 Trans Am, mods:
1.Freshly rebuilt 350 .040 over
2.Edelbrock 600 carb
3.Hooker Competition Shorty Headers
4.Edelbrock Performer RPM Intake
5.Fresh Rebuilt 700R4 trans with 2500 stall and Transgo Shiftkit
The cars I am wanting to know if I can beat are:
1.2000 Honda Civic 1.6 VTEC 5 speed (stock)
2.Mazda RX8 (stock)
3.1998 Mustang GT 4.6l 5 speed (stock)
4.1997 Mustang GT 4.6l 5 speed (may be slightly modded, not sure)
5.1985 Chevy Camaro Iroc-Z 305 (stock)
6.1994 Pontiac Trans Am LT1 (Ram Air hood and exaust)
Any help would be appreciated. If anyone would like to tell me how much horsepower my cay might have I would appreciate that as well.
Old Mar 14, 2007 | 09:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
my opinion is
1.maybe
2. probably not
3. no
4. no
5.yes
6. no
assuming you have a factory stock 350, stock cam/compression ect, and having no idea what year engine, comp ratio or anything about you motor its hard to tell. a standard new GM 350 is around 205 horse.
Old Mar 15, 2007 | 10:34 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
2.Mazda RX8 (stock)
My opinion;
1) yes
2) Drivers race
3) no
4) no
5) yes
6) no
Old Mar 15, 2007 | 12:25 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Your heads and cam arn't mentioned, and those are key to whether or not your setup is gonna be real quick. I'll leave my guess's until you post that info up... right now I think you'd beat all but the 94 LT1 car, and the RX8 IF the guy can really drive, that car takes a lot ot really get the most out of it.
Old Mar 15, 2007 | 06:01 PM
85T/A350's Avatar
Engine: 350 Vortec
The heads are 305 heads. Do not know the castings. They have been machined but not ported or polished. The cam is new but not much or at all bigger than stock. Would I really have that much trouble out of a stock 4.6 Mustang? To the one guy, Im pretty sure my motor makes more than 205 horsepower. Just a guess tho. Also,my car has 2in true duals an glasspack mufflers if that means anything.
Old Mar 15, 2007 | 06:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i would think that 2" duals are restricting the engine a bit
Old Mar 15, 2007 | 08:17 PM
85T/A350's Avatar
Engine: 350 Vortec
Anybody else got an opinion?
Old Mar 15, 2007 | 10:22 PM
atc3434's Avatar
Car: 1986 Camaro SC
Well, glasspack mufflers blow, that was my first through. 2" each on the duals should be ok.. Stock cam and heads, I'd bet you're around 220hp, with a pretty generous amt of torque. You didn't mention your gears, I'll assume non-posi 2.73's, which arn't doing you much good. The 4.6L stangs you mentioned arn't rocketships either, but with the 5spd and good driving should launch as well as you, and pull on the top. The LT1 Camaro will certianly pull you. The '85 Iroc should be a nice race, and the Civic and Rx8 could both be drivers races, those cars both require good technique to pull a solid launch, so from a dig is your best bet, the Rx8 will certianly pull you on top, the Civic is probably about even from a roll, but you should easily out-launch him.
Old Mar 15, 2007 | 10:31 PM
85T/A350's Avatar
Engine: 350 Vortec
My rearend is a non-posi 3.08. One of the Mustang drivers cannot drive his car hardly at all.
Old Mar 17, 2007 | 08:39 PM
coreybear08's Avatar
Car: 85 Camaro z/28
Engine: cammed 355
Transmission: th350 with shift kit
1.WIN...NO DOUBT!! they ARENT that fast...
2.id say a close race...
3.win...not the DOHC 4.6 ur fine
4.close race again...especially not knowing what mods are done...
5.close race...but i think you will win since your 350 is built up a bit
6.call me foolish, but if you know how to really drive your car...im gonna say close race! i know the lt1 ram air is a quick car...but your not exactly stock either...and i think that someone estimation of 250hp on your motor is a bit low...especially if your heads arent stock...but your cam specs would help more as to find out what you are exactly putting out...
Old Mar 17, 2007 | 09:49 PM
R4][N_M4l{3R's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 383 Stroker
Axle/Gears: 7 1/2 Inch 3.23
Your details are pretty vauge. No one can say for sure with that little amount of information.
Old Mar 20, 2007 | 05:00 PM
CleanRS's Avatar
Car: 1990 LX hatch
Engine: 5.0
Transmission: t-5
Axle/Gears: stock
Re: Can I beat these cars?
you can probably beat all of them except the trans am
Old Mar 20, 2007 | 06:36 PM
abyliks's Avatar
Car: 02 Mustang
Engine: 3.8 about to be punched out to 4.3
Transmission: 4R70W
Axle/Gears: 3.73 Detroit true trac
if you can beat teh 305, you can get the stangs, my 02 stang used to pull my L03 when stock, and it pulled on NPI stangs stock
civic: rape
RX8: they are handeling cars, not really all that fast in a straight line, i think you have em
only thing i think u have problem with is the LT1
Old Mar 21, 2007 | 03:13 PM
87LS's Avatar
Car: 87 Camaro LS
Engine: LG4
Transmission: T-5 World Class
Axle/Gears: 3.08 Open baby!!
The ricers no prob...
The mustangs will kill you though...
We need mroe info on the car...
Spend $225 and put a freakin cam in it!!
Then there will be no mor questions
Old Mar 23, 2007 | 11:06 AM
1990_RS350's Avatar
i just performed an engine swap in my camaro... my 350 has just about all the same crap as his and i got the bigger edelbrock cam and lifter kit... but i don't have a carburator i'm using the original 305 TBI. same trans and all... bored .40 over... headers... uh... vortec heads... when i got it from the guy he said it had "performance pistons" in it, whatever that is... he showed me a pic of the engine open with them in it... can i kick these cars asses? can i beat the guy who started this thread just cuz of the cam? i got the same trans but no shift kit... would that really help me out? would posi traction help me out alot too? about how much horsepower gain could i get from posi and a shift kit on my trans... thanks
oh and i wanna turn it into a 383 stroker... about how much is this gonna cost me once i got the 400 crankshaft... does it really add on a large amount of horsepower also?
would a holley carb help me out...
sorry so many questions, i know i'm ramblin' on lookin' stupid... just lookin' at my options... seeing what are good choices.... thanks for the help anyone
Old Mar 23, 2007 | 02:38 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Carb will help you, posi and gears will help you, shift kit will help you. Do those before you spend any more money on the engine internals.
Old Mar 23, 2007 | 03:19 PM
atc3434's Avatar
Car: 1986 Camaro SC
More reading, less talking.
In all seriousness, TBi without a tune on a larger bore cammed motor is probably leaving a vast amount of power on the table. I wouldn't do a thing until it was tuned. Then gears, posi, shiftkit, and converter - those won't increase your horsepower a bit, but they'll help make the most of it. A carb might be easier than TBI, and ultimately can be tuned easier, and support higher power levels w/ less $ invested.
Old Mar 23, 2007 | 08:33 PM
Engine: 383 Stroker
It will add more torque than horsepower and probably cost you upwards of 1K.
Old Mar 24, 2007 | 12:02 AM
85T/A350's Avatar
Engine: 350 Vortec
I appreciate you jacking my thread. Anyway, the guy with LT1 Trans Am and he also owns one of the Mustangs in question sold them both and bought a 4th gen Z28 LS1. I am not going to even ask about that.lol
Old Mar 24, 2007 | 11:17 AM
86birdHT's Avatar
Car: 2004 Pontiac GTO
Axle/Gears: IRS 3.46
If the civic is just a stock Civic, non Si, than you should be able to beat it no problem.
Just a SOHC VTEC motor....my acclaim from back in the day beat one, so no doubt a T/A can.
I just love how someone said you'd beat the rice like it was a rape.
Obviously they havent been to their local dragstrips recently....
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
