Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
How do i compare to an 04 Mustang?
Old Apr 26, 2007 | 11:59 AM
hectre13's Avatar
Car: 1984 15th Anv. T/A
Engine: HO 5.0
Transmission: TH700r4
Axle/Gears: not sure yet!
well lemme see,
this guy my girlfriend works with is a real jerk, he just bought a stock 04 mustang with the 4.6L non supercharged and stickshift, he keeps talking crap about my car, and I havent said anything back to him, well my car aint even running yet, but i was wondering how much of a chance i have against him if i decide to race him.
83 Sports Coupe
5.7L L98 V8 - Carb'd (aftermarket intake & carb)
performance ignition system
stock 700r4 trans
3.23 open diff
stock exhaust manifolds
y-pipe and cat, nothing past it
i dont wanna talk crap if i cant back it up ya know?
-Jeremy
Old Apr 26, 2007 | 12:19 PM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Re: How do i compare to an 04 Mustang?
open diff stock exhaust manifolds and stall are killing you right now.
Address those issues and i dont think youll have too much of a problem assuming it runs right.
Old Apr 26, 2007 | 01:32 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Originally Posted by hectre13
well lemme see,
...., well my car aint even running yet,......
-Jeremy
hectre13's Avatar
Engine: HO 5.0
well, i got a little better than stock torque converter, but nothing amazing.. but yea, i can understand... so you think he'll stomp me?
lemme restate that.. do you think he will stomp me after i get my engine swap finished?
Old Apr 26, 2007 | 01:36 PM
gta31's Avatar
Car: 87 gta
Engine: l98
no not at all u need some headers though the stock ones suck if u are doing a swap u should have seen thoses pieces of crap i would change those for some more breathing
Old Apr 26, 2007 | 04:40 PM
matt3383's Avatar
Car: 2000 Camaro SS
Transmission: t-56
Axle/Gears: 4.10
Well basically a stock l98 with 3.23s and a stockish converter, you should be running low 15s high 14s. He should be running in the low 14s range. If you do some headers and some other boltons it would be a close race.
Old Apr 26, 2007 | 09:15 PM
superGMman's Avatar
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
an L98 with an open diff?!??!?&$$&!? You'd lose before your car would actually move forward!
Jk. But really besides getting your car running without traction an L98 is useless.
Old Apr 27, 2007 | 06:26 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Stock L98 running 15's? Mine pulled a 14.7 on it's first run out before ANY tuning with a 2.73 open diff and a stock stall. His is also carbed so it should be a hair faster than a TPI car if he gets decent gears under it. Get 3.42's or 3.73's and a posi ASAP. The way things stand now you will get axe murdered. Also the header comment is dead nuts on. That was the only real mod I had done to my L98 when it pulled the 14.7. I bought a cheapo set of Flowtech shorties that I later replaced with Hedman long tubes (hint: buy the good headers right off the bat!). This same motor now does 13.5's with 3.27 gears, Th350 trans and a 3k stall.
Old Apr 27, 2007 | 09:41 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Just jumping on the bandwagon here. I ran a 14.8 with a bad 2.28 60 ft, leaking injectors, 2.77 rear, old ignition system, and it was stock.
Old Apr 27, 2007 | 06:03 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Well i ran 14.0 so there. lol
almost stock L98 with 3.23 posi, 1.9 60 ft.
PurelyPMD
May 5, 2016 04:57 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
ndndndnd
Sep 28, 2015 08:00 AM
okfoz
Sep 22, 2015 03:37 PM
