Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
What do think my setup can do in the 1/4
Old May 3, 2007 | 11:08 PM
355tpiz's Avatar
Car: 1987 iroc z28
Engine: 355 vortec HSR
Axle/Gears: 3.45
my set-up is a stock suspension 87 iroc
355 fully ported vortecs/holley stealth ram
crane cam part # 109831 lift 509/528 adv Duration 284.0 °/292.0 °
full length headers
24# lt1 injectors
roller rockers
58mm tb
3.45 gears for now
jim
Old May 4, 2007 | 07:37 AM
JCL91TRANSAM's Avatar
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
Re: What do think my setup can do in the 1/4
I would have to say mid 12's.
Old May 5, 2007 | 07:46 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
without suspension and tires thats doubtful.
Sounds more like a low 13's car to me.
Old May 5, 2007 | 02:39 PM
1989formula355's Avatar
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
Old May 5, 2007 | 04:42 PM
Car: 91 Trans Am
Maybe low 13's right now but his engine has the potential to hit into the 12's. Hey rocluvr0013 small world, you live 10 minutes away from me.
Old May 7, 2007 | 11:04 AM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
I am going to say 13.0-13.2
Old May 7, 2007 | 11:21 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
What tires are you going to run?
Old May 8, 2007 | 12:00 AM
355tpiz's Avatar
Car: 1987 iroc z28
Axle/Gears: 3.45
Im not sure yet, what drag radial should i go with?
Old May 8, 2007 | 12:09 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
drag radial??? forget those.. you have a stick.. sticks dont like drag radials.. get some e/t streets or hoosier qtp's..
EDIT: you see all that smoke in my sig? thats pretty much what drag radials do.. they just spin.. btw, i run drag radials.. 275/50-15 MT ET radials.. never got them to hook.. only can get low 1.8 60ft's..
Old May 9, 2007 | 11:54 PM
355tpiz's Avatar
Car: 1987 iroc z28
Axle/Gears: 3.45
What do you think it will take to hit low 12's high 11's, I thought there was many HSR Vortec headed cars running these numbers easy.
Old May 10, 2007 | 05:15 PM
Engine: 350 tpi
More gear a prepped auto a nice converter and slicks does wonders for a drag car.
I dont think there are many hsr vortec cars that are in the 11's n/a.
I could certainly be wrong though
Agreed ...
And i live in California. I think thats more then 10 mins away.
Last edited by rocluvr0013; May 10, 2007 at 05:16 PM. Reason: Automerged Doublepost
Mark_ZZ3
May 24, 2018 01:02 PM
tmellott89
Oct 14, 2015 02:06 PM
88CamZ
Oct 8, 2015 10:29 AM
tattmann
Sep 27, 2015 05:20 PM
