ok so my friend is buying this fox body and I want to know what I will need to give me a chance
-302 (.030 Over)
-E303 Cam
-True Dual Exhuast, No Cats
-BBK Shorty Headers
-BeCool Radiator System
-Dual Electric high powered fans, Switch controlled
-K&N Airfliter cone
-Holley 750 Double pump, mechanical, 4 barrel carbarator.
-MSD Spark plug wires
-MSD Ignition System
-RPM Airgap 4 Barell Intake
-Ebiach Drag Suspension
-4:10 Gears
-Steeda Short Shift Kit
-Cobra 17" Rims
-Nitto 555R Radials (Rear)
-Steeda Alloy Clutch Quadrant with adjustable cable
-Aluminum Ford Driveshaft
thats all the performence stuff but it has no ac or heat no radio or speakers also and full interior and gauges
my car is a stock 92 z with a vortec 350 a auto trans g92 rear full power options and magnaflow duals.
what would be the best and cheapest mods to keep up
-302 (.030 Over)
-E303 Cam
-BBK Shorty Headers
-K&N Airfliter cone
-4:10 Gears
-Cobra 17" Rims
89formula350b2l
close
100 shot of laughing gas?
well I thought of that but I don't want to but that much pain to the bottom end and its daily driven so I don't want to blow the engine so is there anything else..
1991CamaroRslow
close
- Join DateOct 2005
- LocationCincinatti OH
- iTrader Positive Feedback100
- iTrader Feedback Score(3)
- Car1991 L03 700r4 RS
- Engine1987 WS6 Trans AM Lb2
- TransmissionTh350 red neck Performance 3k stall
- Axle/Gears95 Mustang 8.8 built with 3.73s
- Liked:0 Times in 0 Posts
How to put this lightly.... no.
Quote:
ok so what would it take to keep up with out the gas and forget the cheap part.
Jproz1167
close
- Join DateFeb 2003
- LocationCalifornia
- Car1982 Trans Am & 1982 Corvette
- EngineL-98 with LO-3 induction. 350 CFI
- Transmission5 speed and vette has 700r4
- Axle/Gears373's in T/A .. vette unknown
He's going to slaughter you. I had a 93 5 speed GT once all stock and 350 f-bodies have to work hard to beat it was never a easy win for them, and it only happened off the line. With his mods pray for engine failure on his part to win LOL .... I'm not a big ford fan by no means. But in all honesty you have to give them mustangs credit they are quik for what they are actually wish I had one with some nice mod's.
well since his is a stick I might have a chance cause I know he can drive but when he is nervous he misses shifts.
so any ideas of what it would take?
Jproz1167
close
- Join DateFeb 2003
383 with 4:10 gears, some headers, cam, aftermarket TPI system, better question would be what won't get me the win LOL ... You are in need of serious combination of stuff simple as that.Sorry guy but a .49 cent taco ain't gonna work you need the big enchilada ... or just drop a taco bell on your car LOL.
a 100 shot will not hurt your bottom end any more than boltons + heads/cam would. youre going to need either to beat your friends setup, or possibly both
1991CamaroRslow
close
- Join DateOct 2005
So true, I hammer my engine with big shots of nitrous all the time and it still loves me. There is one possibility for a win, hope he runs on street tires and you get yourself a nice set of sticky drag radials, then run him in the 8th and pray before and during the run.
Quote:
-302 (.030 Over)
-E303 Cam
-BBK Shorty Headers
-K&N Airfliter cone
-4:10 Gears
-Cobra 17" Rims
Firstly if you wanted to keep up for cheap well then nitrous is definitely the way to go. If your afraid of nitrous:Originally Posted by david068513
ok so my friend is buying this fox body and I want to know what I will need to give me a chance-302 (.030 Over)
-E303 Cam
-BBK Shorty Headers
-K&N Airfliter cone
-4:10 Gears
-Cobra 17" Rims
Well you already have a vortec headed 350... a camshaft headers more stall and intake manifold(of choice id go hsr b/c of price) would be a good start. Then slicks and id say it would be a good race.
The only thing your friends mustang doesnt have is aftermarket heads it seems...
His car should only be somewhere in the 13s, not that hard for an Fbody to match, I sure hope. Get some DRs, converter, and go at it from a dig.
1991CamaroRslow
close
- Join DateOct 2005
Quick question, exactly what setup do you have on that Vortec 350? Did you swap the entire engine over into your thirdgen? Or did you swap a carb intake onto it?
its not all that hard to get a l98 z into the 13's were that stang is. theres a million mods.. start with exhaust, stall, gears, intake porting, cam, ,maybe some head work... pretty much the same mods the mustang has.. duh.
Quote:
its a whole engine from a 96 truck.Originally Posted by 1991CamaroRslow
Quick question, exactly what setup do you have on that Vortec 350? Did you swap the entire engine over into your thirdgen? Or did you swap a carb intake onto it? Supreme Member
1991CamaroRslow
close
- Join DateOct 2005
8T9 BANDIT it's easy to see why you're on probation. Yeah go ahead and port your Vortec heads so you can screw up the excellent flow they already have, then while your at it port out the composite intake you can do that with a nail file, I bet you can take .001in off of the .010in thick walls of it before you run into issues... duh. This guys combo is an oddball, and it's not all that easy to get an L98 into the 13's plus who's to say this mustang's running high 13's in the first place? I say go prepared for war don't count on assumptions. The engine in your car makes 250hp at 4400rpm and 335lbs at 2800 so it's a bit more powerful than a stock l98 but has alot more potential in it. How hard was it to swap all of the truck injection into the thirdgen?
I agree when I said 13s I did not necessarily mean 13.9... With those mods and a good driver middle to lower 13s on a street tire shouldnt be too difficult.
Quote:
hey jack@s* its easy to see youre a dopey hick. i read his avatar and thought his 92 5.7 had a l98 in it.. and if it did i would be exactlly correct on what i said...Originally Posted by 1991CamaroRslow
8T9 BANDIT it's easy to see why you're on probation. Yeah go ahead and port your Vortec heads so you can screw up the excellent flow they already have, then while your at it port out the composite intake you can do that with a nail file, I bet you can take .001in off of the .010in thick walls of it before you run into issues... duh. This guys combo is an oddball, and it's not all that easy to get an L98 into the 13's plus who's to say this mustang's running high 13's in the first place? I say go prepared for war don't count on assumptions. The engine in your car makes 250hp at 4400rpm and 335lbs at 2800 so it's a bit more powerful than a stock l98 but has alot more potential in it. How hard was it to swap all of the truck injection into the thirdgen? Quote:
stop fighting like kidsAlso I do not know how hard it was to swap it in but it doesn't have the fuel injection from the truck it has a TPI unit on it.
1991CamaroRslow
close
- Join DateOct 2005
A dopey hick? Please keep it up we really don't need idiots like you on the board. The mods will do their job soon enough, come up with another witty one genius.
Quote:
did you not read the above post please stop messing up me tread and fighting just drop it.Originally Posted by 1991CamaroRslow
A dopey hick? Please keep it up we really don't need idiots like you on the board. The mods will do their job soon enough, come up with another witty one genius. Senior Member
well heres my 2 cents.....my cousin has a 65 mustang with a 302 with the same running gear basicly....except he has some ford racing heads....my car is a balanced 355 with a carb.....i can spank his a s s in the eight......my advice dont race him in the quarter cause i can barely keep up in the 1/4.......although he is running 17s and will not be able to get as good tractions as a set of 15s.....hint hint......plus if you are runnin a auto you will have an advantage on the stick shift
My buddy has basically the same mods in his 88 notchback 5.0 and he's only in the mid to low 13's. Use some nitrus eventhough I'm against it and beat him, shouldnt be too hard his car isnt crazy fast.
