How Bad do think i'll beat him
Car: 1983 z28
Engine: 383 .060=388
Transmission: th350
my 83z, 11.5:1 388 dart 230cc heads solid lifter cam, vic jr intake, 850 carb, th-350, 3500 stall, shift kit, 3.42 gears.subframe connectors and 8pt cage
guy thats says he whip me, 99z28 stock ls1 with exhaust a k&n filter, it's an auto tranny
both running street tires, he's actually considering racing for titles
heres some pics of my car
http://good-times.webshots.com/album/562648446zWPIWS
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Re: How Bad do think i'll beat him
Car: 1988 IROC-Z
yep. Anything could go wrong, and when there is so much at stake, it probably will. I think you would take him though.
Car: 1983 z28
Transmission: th350
hell I said nothing about racing for titles, he was talking big **** in front of his friends and said "hell i'm so sure I would win I'll put up my title" I WILL NOT race him for titles. lol my rear end is like a bomb waiting to blow behind my motor, with my luck it would go while racing him.
that rearend will last nearly forever with street tires on it.
both cars with street tires, its a toss up. if you can feather it, you should be able to outrun him, but a stock LS1 auto should be able to knock down an 8.80 or so, no problem.
why are you running 3.42's?
Car: 1983 z28
Transmission: th350
i'm assuming thats whats in here I have done nothing to the rear.
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
you probably have an open 2.73 rear lol...sucks but its the truth....o well just race and have fun. u ever run yours at the strip?
Car: 1983 z28
Transmission: th350
Last edited by camaronut79; Apr 4, 2008 at 10:50 PM. Reason: Automerged Doublepost
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Hell I shift my truck at 6800rpms
But I think you'll take him
Car: Pontiac T/A
Axle/Gears: Borg Warner 9-Bolt w/ 2.77 gears.
Go ahead and race him. If you get him off the line buy 2 or more cars you should win. Thats how we beat them here in Chi-town. And thats with a 355 and DRs. Its all in the first 330ft.
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Seriously, I wouldn't run for pinks no matter how much of a sure thing it might be. And this is a pretty sure thing. I would be pretty confident of 11's w/ good rubber at the track. (Assuming the rear end doesn't blow) I don't see a nearly stock LS1 touching that.
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
ever thought the guy could be hiding a 100 shot of nos?
Car: 1986 Camaro SC
Car: Pontiac T/A
If they are running street tires that would make the ls1 lose more traction. There's no way a almost stock ls1 with an average driver is going to run 11.s on street tires. Get some good tires and VHT then go out and getem for 2 0r 3 hundred.
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
so wat he got a nos emblem in his dash lol
on a side note
was it hard to have those guages drilled in the dash like that , ive been thinking about doing the same for a awhile now but i was worried i might damage some important wire in the bak lol
on a side note
Car: 86 iroc 92 rs parts car
Engine: 350 305
Transmission: t5 t5
Axle/Gears: 3:73, 3:08
that's funny I had a rear end that would disagree with you, all extra hundred pieces.
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
Car: Pontiac T/A
I don't know about that. My car I broke one but we got a built 92' rs with all the mods you can do to a 10 bolt and with about 80-100 passes, dynos and street races with drag radials it still holding up. The car is putting down 370rwhp and 375rwtrq. BTW he raced a modded 2000 LS1 in the eighth last night and beat him by a fender.
Car: 1986 Chevy Silverado
Engine: 350 Crate
Transmission: Turbo 400 w/ shift kit
Axle/Gears: dana60/corp14 4.10 gears
$%^& what everybody says. Put the slip up and spank his @$$!!! Why do we put $$$$$ so much money into our cars if not to use them for what they are for?
Trey
Trey
bolt-on LS1 cars have gone high 10's and 1.4x 60's with 10 bolt rears. and a bolt on LS1 car could be making around 370rwhp.
Car: Pontiac T/A
Car: Pontiac T/A
The LS1 he raced put down 400rwhp (I put together both cars) but the tune isn't right yet. His low in trq isn't what it should be. The RS got him out the hole by a car and held him off. They will race again on the 28th when both cars are right. I'll try to post a vid.
Engine: 350 305
Transmission: t5 t5
never, mind the fact that I was stupid enough to use my daily driver
. it may of been 1 in a million but still Murphy's law got me in the rear. Member
Engine: 350 Crate
Did you race this guy or not??? Don't listen to all these Camry drivers that somehow got into Camaro's. When you get called out to race it's simple.
2 Choices:
1) Get to the line get ready to heel toe your way to the finish line
or
2) be a big fat pu$$ and bow down.
If you are #2 then you should go to thew nearest honda/toyota/kia dealer and pick you up a car. Because that is the true "dumbass" You have a Hot Rod act like it.
That's Gospel!!
Trey
2 Choices:
or
That's Gospel!!
Trey
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
2 Choices:
or
That's Gospel!!
Trey
2 Choices:
or
That's Gospel!!
Trey
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
2 Choices:
or
That's Gospel!!
Trey
2 Choices:
or
That's Gospel!!
Trey
