Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
View Poll Results: Who do u guys think will be faster
formula
69.23%
camaro
30.77%
Voters: 13. You may not vote on this poll
Who do you guys think will win? Formula vs. camaro
Old Oct 22, 2008 | 08:46 PM
Seanmay1's Avatar
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
Supposed to be racing a friend of mine
I have a 89 Formula, 305 TPI w/ 5 speed. Its supposed to be rated at 230hp/300tq. I have the 9 bolt 3.45 posi gears, WS6 suspension, magnaflow catback (sucks), throttle body coolant passage bypassed, delco plugs, K&N air filter, some kind of aftermarket chip. I think thats it, its just like it was when i bought it, I have only done the bypass, new plugs, cap & rotor, and removed smog pump/air lines in manifolds. Also i have the Federal SS595 tires, they seem to grip pretty good
EDIT: My car also has the bolt on subframe connectors (planning on getting a set of weld in ones), and i think it has the airfoil in the throttle body, not sure exactly what it looks like, but there is something extra there so im sure thats what it is
His is a 87 Camaro w/ olds 307 and 700R4 and 3.23 gears. 5A HEADS,
K&N Air Cleaner, 670cfm Holley, Msd 6al, COMP CAM 268H .454/.454, Edelbrock Intake. He has a set of headers and 3.73 gears but i don't know if they will be installed before the race, and im not sure what kind of tires he is running
So who do you guys think will win? Im new to f bodies and really have no clue what my 305 will do in the 1/4
Old Oct 22, 2008 | 11:20 PM
jimmyj2000's Avatar
Car: 88 Formula 350
Engine: l98
Axle/Gears: 3.23 9-Bolt
Re: Who do you guys think will win? Formula vs. camaro
You know, the bolt-in subframe connectors can be welded in once mounted. Just take out your carpet and take it to a muffler shop or something and have them weld them to the frame and floor pans.
Old Oct 22, 2008 | 11:23 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
We have a welder, i thougt about that actually. I just didn't know if it would be as strong, i guess i will get my uncle to weld them in when he gets a chance
Old Oct 22, 2008 | 11:50 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Olds 307?? That's just weird. Just no telling what could be modified in there...
Who puts Olds motors in Chevys?
Old Oct 23, 2008 | 12:08 AM
chaoz28's Avatar
Car: 87 formula/69 beetle
Engine: 355/2.1
Transmission: T.C.I streetfighter th350/5 speed
Axle/Gears: 3.73 lsd/
olds and chevy 307's are both sbc's... but on a side note i would take a 442 motor and put it into an f body in a heartbeat
Old Oct 23, 2008 | 12:35 AM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
Olds 307s are not a sbc, the vin 9 442 307 had 180 hp, the regular 307 had 160 or 170 i can't remember
Old Oct 23, 2008 | 12:40 AM
chaoz28's Avatar
Engine: 355/2.1
well i guess ya learn something new every day. all i know is there is a 74 cutless or some type in my dads scrap yard with a numbers matching 307 and while i was tearing it apart it made absolutely no difference from an sbc. is the olds motor your talking about a different design motor?
Old Oct 23, 2008 | 01:07 AM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
the olds 307 was only built from 1980 through 1990, its is a different motor than a SBC. It was probably a Olds 350 in the 74 cutlass
if you want to know a little about Olds 307s you can check out this link
http://www.442.com/oldsfaq/ofe307.htm
I just started playing with F bodies, I have always been a Olds man lol. Had to sell my cutlass i had been building and got a great deal on my firebird. Trying to learn about them now
Old Oct 24, 2008 | 02:49 AM
Quasi-Traction's Avatar
Car: 1986 Camaro Berlinetta
Engine: 4 bolt 355ci
Transmission: Borg Warner T-5
Axle/Gears: 3.73 Posi Disc Rear
His cam isn't bad, but the Olds 307 isn't near as effecient of a design as an SBC (I.e: Heaver, doesn't perform as well with equal mods).
If his heads have any work beyond stock, it'll be a close race, and he might have you. If he beats you out of the hole, you'll reel him in slowly but surely. I think you'll edge him, but by close to moderate margin.
Old Oct 24, 2008 | 06:09 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Olds 307 is a boat anchor - probably as bad as a Chevy 307 and not as good as a 305. Olds 442 did have 307 Olds in the 1980's - wonder why they stopped making them?
Jorlain
Aug 24, 2022 05:11 PM
TreDeClaw
Jun 22, 2021 08:21 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
