Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
1/4 mile help
Old Sep 24, 2011 | 02:57 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
1/4 mile help
Ok so the Car went 14.197 @ 97.25 MPH...2.035 60'...9.151 in the 1/8th @ 76.64 MPH.....I know The car was leaning out in the big end...I have a set of Edelbrock Big tube runners for it, and am thinking of pumping up the FP....The car weighed in at 3650 pounds with me in it...Any thoughts on how to hit 13.99???? Car has headers, and dual cat exhaust (minus cats) no pollution stuff..Shift kit, and was running good tires....I thought for sure it would hit 13's with no problem..I even took a helmet...Thanks for any advice....Tom
92 Z28 350 TPI, 700R4.......
Old Sep 24, 2011 | 04:45 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Re: 1/4 mile help
I guessing you raced it in TX and I'm sure track temps were hot. It would probably run 13's in cooler temps. Looks like you had plenty of traction, just need more power. 1.6rr's would really help.
Old Sep 24, 2011 | 05:02 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: 1/4 mile help
It was cool last night...I do have a set of 1.6 rolllers, and the big tubes, do you think that would do the trick if we also fool with the FP, it is around 70 now I think..Thanks for answering me..I almost cried when I saw 14's...On three runs the car was very consistent....Might even drop a couple of pounds im the back tire, i was not getting a full patch.....Also think some smaller tires up front might help...........THANKS
Old Sep 24, 2011 | 05:14 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: 1/4 mile help
I bet if you kept it as is, and run it more, you could get the 60 ft down a tenth or two, and you would get your 13.9. A set of DR wouldn't hurt, nor would skinnies up front. Depends on where you want to put your money.
My first time at the track I ran low 14's all night, with 1 random 13.7 run. That is with Heads, Cam, Intake and all supporting mods. with 2.2's all night. I kept going to the track, and same setup... I eventually ran a 13.1 with a 1.8. With NOTHING changed. The 13.1 was a few weeks before I found 3 broken pistons. I was itching for high 12's with the setup really bad too. Now with the bigger cam, I am looking for mid 12's.
Old Sep 24, 2011 | 05:35 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: 1/4 mile help
once again thanks, and congrats on the 13....
ran it on mickey thompson drag radials 275 50 15's on 10 inch centerlines.11 inches of tread....gonna slap my msd on it, the the edelbrock tubes, the 1.6's and play around with the FP, and timing....3.23 posi gear.....want skinnys up front really bad, but do not have any, altho i have 2 10 inch centerlines, i would trade for some narrower rims.....i think it was putting out about 263 hp, need 293 to hit 101 mph......Guestimate..... ...think i have a chance with those parts added???
Old Sep 25, 2011 | 08:46 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: 1/4 mile help
Maybe try going to a 3.73 gear. that will put you in the 13s for sure
Old Sep 25, 2011 | 01:11 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: 1/4 mile help
Thanks much, think 3.73's might be a little steep for the TPI....Might look into 3.42's................Anyone else want to chime in?????
Old Sep 25, 2011 | 01:48 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Transmission: 700 r4
Axle/Gears: 342
Re: 1/4 mile help
not that mine is any better but its running a 9.103@1/8 the 60 is @1.9 if u could get your 60 lower it could run a 13 my guessing ive also got 342 gears
Old Sep 25, 2011 | 03:50 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Re: 1/4 mile help
How many miles on the car / rearend? If high miles, I would rebuild the rear and add 3.73's. If low miles, just keep the rear stock.
Old Sep 25, 2011 | 09:05 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: 1/4 mile help
106000 miles more, or less....
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Stryker412
Sep 7, 2015 09:11 AM
