305 build up?
305 build up?
I am going to look at an 86 TA tomorrow with a 305 4bbl H.O. I know 305's arent as good as 350's and whatnot, but he only wants $2200 for this car. If I put, say $1200 bucks in the engine, could I run mid 14's? I cant really put a 350 in it now cuz it has to be a daily driver and its my only transportation. I want this car to hang with stock and mild 5.0 fox bodies... can it be done?
you can actually get it low to mid 14's for around that (maybe a bit more)... Car Craft did a build up that cost about $1500 that got 325hp out of a 305... They got Vortec heads, an Xtreme Energy Cam, Edelbrock Super Victor Intake, and a Holley 750 carb. I've got the files saved on my computer, so if nobody can find the actual article online I'll upload them later.
for $1200 you can get a 305 well intothe 14's. just be smart about parts choices, 305's don't tend to like the super huge, max air flow stuff that 350's can take advantage of. what you can build is a nice little, smooth running, sleeper motor with tons of low end torque to rip people out of the hole with.
get a base line and let us know what it runs. i am sure enough people here have built 305's to give you the advice to get it runnign right.
the big key to being fast on teh cheap is knowing how much of the work you are willing to do your self.if you use a shop your money won't go half as far.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
lata
tim
14.209@95.46mph
Best 60' 1.917
man dont get TES headers thats all im saying...i ran a 14.4 @ 94mph w/o the headers and catback and a 14.4 @ 95mph with the headers and catback. ****ing pos edelbrock
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air
14.4 @ 94mph w/2.0622 60ft
FOR SALE! Email me for further info.
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Chevyss I would look for a Camaro with a 350 it's alot easier and less expensive to achieve higher hp than with a 305. With a 350 your options are wide open a with 305 you are limited.
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:234 dur at 050 488/488 lift,2500 stall converter,shift kit,3.42 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.
[This message has been edited by Big454blockchevy (edited June 30, 2001).]
383 86 Camaro Z28
you can grab a decent camaro w/ a 350 for around 2400- and a 91 or 92 for up to 5400 hell I just got my 89 RS for 1800 but it does have the 305 TBI on the upside of that its the 5 speed manual. I am however looking into putting a 350 into it. maybe Ill even get a 350 TBI from the American engine exchange here in salt lake and have them do some custom stuff to it for me.
Yeah Im really looking for a 350 TPI Fbody but I cant find any around here except a 91 Trans Am with 134 K miles, a bunch of dents on the hood(it wont pop) and a dent in the front fender, and the guy still wants 5 grand for it!
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
For $1200 you can buy a Goodwrench 350 rated at 250bhp. Just something else to consider.
Later, Rob
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Later, Rob
Mods
Future mods:
Cam change
Strut brace
Ram Air
1/4 14.74@100.2mph
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
135,000 miles on my little 305.
It does 14.04 @ 100.8 MPH, and I put $800 into the engine, $600 into the exhaust (Edelbrock TES
) and $150 into a Turbine Technologies torque converter.
It can be done, but you will need to do a lot of stuff yourself, like change your own torque converter, and port your own heads. For a couple hundred more, buy some aftermarket heads like the WP SR/305 castings.
Whooo ha! ha! Have fun!
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New!Full 1LE brake upgrade! Details at website above.
) and $150 into a Turbine Technologies torque converter. It can be done, but you will need to do a lot of stuff yourself, like change your own torque converter, and port your own heads. For a couple hundred more, buy some aftermarket heads like the WP SR/305 castings.
Daniel Burk
Car: 87 Formula Firebird/ 84 Trans Am
Engine: 305 / 305 H.O.
Transmission: 700 argh 4 / same
I got the 305 HO and I'm planing on getting around 250 hp out of it easy, with new Edelbrock RPM Proformer heads intake and Xtream cam and of course to the dismay of many... the tes headders!(already heve a 2 1/2" exhaust and gutted cat) I don't know what all the whinning's about my buddy got em on his LG4 maro and love's em and I love the sound he gets with his Comp cam and the TES's!
You put Mt. Dew in the gas tank!?!
Wow, look at it go!
Wow, look at it go!
