Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
2001 civic vtec vs. stock 88 GTA
Old Sep 21, 2001 | 01:02 AM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Brand new 2001 civic si vtec w/ intake and a few other mods, stick too.
I think he will give a good race against my 88 GTA.
It's an auto, bone stock 350, runs great.
Any thoughts, power/times for these things?
* 88 Firebird, 2.8, auto
* 88 GTA Trans AM, 5.7, auto
Old Sep 21, 2001 | 01:22 AM
mss's Avatar
mss
if your a good driver youll win , he is in the low 15s probably , you should definatly be able to be there , if you know how to launch your car , then you should definatly kick his ***
Old Sep 21, 2001 | 02:28 AM
uno's Avatar
uno
i would say that civic is running between 14.6 and 14.9
but i think if your car is running good you should still win
what gears do you have? 3.23's or 3.42's
like mss said, if you know how to launch you'll win.
1989 307 RS, soon to be 350.
1995 Red T-Top Camaro, 3.73 gear, F.I.P.K. K&N,Flomaster Cat-Back, Gutted Cat...Very soon, Centerforce clutch and 100 shot of Nitrous
1998 Ford Ranger 3.0 Cold air intake and flowmaster exhaust.
Old Sep 21, 2001 | 02:46 AM
Car: '89 GTA
I think it's 3.23, how can I be sure and what diff. does it make?
I think my launch style is pretty good, i'm quick on the trigger and I roll into the gas so I don't sit and spin on my brand new ZR Yokohamas'. I'll need all I can get, I hear those imports, let alone sticks are quick off the line as well.
Old Sep 21, 2001 | 04:34 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
U will win, I really don't think they are in the 14's, 15's yes.
89 RS
STILL Looking For:
An 87 IROC-Z28 350 TPI
Old Sep 21, 2001 | 07:28 AM
SPOOM's Avatar
There is was no "Si" model in 2001. They will probably be available again as a 2002 or 2003, but they quit producing them in 2000.
Assuming that your friend's car is actually a '99 or '00 Civic Si, he'll probably run a low-high 15, totally dependent upon his driving skills, or lack thereof. He may or may not be a decent race, if this is the case. I have seen a very, very few Si's with minor mods bust out a high 14, but these are very rare occurances.
Assuming that your friend's car is actually a 2001 Civic with VTEC, there's little chance for him without nitrous. The top VTEC engine in 2001 Civics only made around 127 hp (vs. 160, for the earlier Si's)...even with basic mods, you should beat him like a drum.
SPOOM
92 TSi fwd
Old Sep 21, 2001 | 12:31 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The easiest way to figure your rear gear ratio is if you have an auto stay in 3rd gear and do 70 mph. What ever your tach is reading that is the gears you have. For example if you are doing 3230 rpms then you have 3:23 and so on. The lower the gear ration (numerically higher) the faster your acceleration will be in most cases to a point and it will decrease your top speed.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 21, 2001 | 01:17 PM
Car: '89 GTA
Thanks for the tips.
As for the Si I misquoted, it's a `00.
He said it was a brand new one so i assumed it was `01.
So he's got about 160hp + any mods he's done?
I can't remember exactly what, better intake and exhaust parts.
Old Sep 21, 2001 | 02:38 PM
Blazin91Z28's Avatar
You should be able to win. I raced my friend in his 01' civic 5-speed, and he ran a 17.4. I crushed him w/ a 14.7 in my basically stock 91' 5.7L Z while having my rear discs rubbing and enigne troubles.I'm willing to bet a v-tec w/ some mods would probably run high to mid 15's.
Old Sep 21, 2001 | 06:58 PM
NHcamaro's Avatar
If I were to put money on this..I'd put my money on you
1988 Sport Coupe 305 TBI
K&N
Flowmaster 80
Daily driver:
1988 K1500 5.7 4x4 shortbed flowmaster cat-back gutted cat.
AOL: RyanNH84
Old Sep 22, 2001 | 01:45 AM
DuffMan's Avatar
Car: '99 Cobra
Engine: 4.6 DOHC 32V
Transmission: T-45
Axle/Gears: 4.10
Keep in mind that the 160 horses won't hit until 5500 RPMS or so, and he has no low-end torque.
1987 Camaro IROC-Z/Z28
305 TPI - 5-speed
Full Competition Kenwood System
Duff Man says, "Oh Yea!"
Old Sep 22, 2001 | 03:21 AM
AntiVTEC's Avatar
You'll win. Stock Si's are bout late 15's. My buddy has a moderatly modded one (in and out, cam gears, pullies, stage something clutch and the signiture rice body kit) and still gets taken by SH preludes. He is a good driver too.
Another thing, even though those VTEC motors dont get their peak power till a certain RPM, then can still launch relativly hard if they know how to ride the clutch through. And also, bottom end power only works for you in the first 2 seconds of the race. For the rest of the race, you're running in the upper RPMS. So unless you shift at 3 grand when you race, bottom end power is not all that to brag about.
85 2.8L Sport Coupe 5-speed.
Mods: Hpertech chip and powerstat, MSD 6A-L, Crane fireball coil, Accel Cap and Rotor, Dynomax hi-flow cat and catback system with a dynomax magnum race bullet muffler on the i-pipe, K&N filterchargers, Gutted Air Boxes, 8mm Wires, Eibach Sportlines and Tokiko springs/shocks setup, Global west sub frames, Suspension techniqs front and rear sway bars, and good ole 88 IROC wheels with Kumo Ecstas on em!
"It's not the ricers, it's those damn V8's!"
Wins: 2000 V6 Accord, 69 302 Mustang, 2000 Auto VR6 Jetta, 89 Toyota MR2, 90 Civic Si, 76 350 Camaro, 2000 3.8 5-speed Camaro, ~68 Chevelle 350, 92 CRX Si.
Old Sep 22, 2001 | 07:14 AM
SPOOM's Avatar
"Keep in mind that the 160 horses won't hit until 5500 RPMS or so, and he has no low-end torque."
Also keep in mind that the gears are so tightly spaced in these cars that this really isn't as much of a disadvantage as you might think.
Street Lethal
Apr 30, 2019 12:14 PM
The_Phoenix
Feb 4, 2016 07:10 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
gta power
Aug 13, 2015 06:15 AM
