Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
How fast is this going to be?
Old Oct 16, 2001 | 08:01 PM
Digger's Avatar
Its in an 82 Z28, the 350 was just rebuilt, heavily ported 882 heads, Gm151 cam, edelbrock torker intake, performer 750 carb, bout 8.75:1 compression, ( flat tops with 4 valve reilifs, with 76cc chambers), headman long tube headers 1 5/8 primaries, 3 inch collectors, then th 350 tranny, stage 2 shift kit, 2.73 out back, and for now no exaust system installed.
How fast will that be? Now what if I changed the rear to a 3.23 posi and compcams extream energy cam, EX-268, and a 2000 stall, then what would I be turning.
Old Oct 16, 2001 | 08:27 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
fourteens.
Old Oct 16, 2001 | 09:42 PM
HrdRockA4305's Avatar
I dunno much about those heads I'm not familiar with them, but with traction I dunno I'd say mid 13's but I'm not the best estimator in the world. I have the tendency to overestimate how fast a car should really be so take it with a grain of salt.
88 Camaro (The mighty LO3 SC!)
305TBI/700R4/2.73/123,XXX miles
14" Open Element and Flowmaster 80 seires
Next up: headers and gears
Old Oct 16, 2001 | 11:58 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
mid-high 14's why such low compression?
Old Oct 17, 2001 | 12:09 AM
Black92Z28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by unknown_host:
mid-high 14's why such low compression?</font>
I was thinking the same thing. You'll probably need to step up the compression ratio to fully take advantage of that intake/carb combo. I'm thinking more in the lines of 9.5:1 or higher.
-92 Camaro Z28, 350 TPI, flowmaster exhaust, MSD wires, Hypertech coil, K&N filters
Old Oct 17, 2001 | 12:26 AM
yep yep, and your 2.73's are hurtin you too. if you are doin a th350, shouldnt he be gettin some 3.73's or something?
Old Oct 17, 2001 | 09:59 PM
Digger's Avatar
Well I think its around that, I was shooting for 10:1, I told the engine builder to get me around 10:1 with the 76cc heads. He picked flat tops with the valve reiliefs, then he boared the engine to the piston specs. He said it should yeild 10:1 but with 76cc heads I highly doubt that. Any ways, what if I put a set of vortec heads on this thing? I also have a set of 302 heads from a 69 camaro, but I have those on my other camaro.
What do you think my other camaro runs, It has those 302 heads, flat tops, 4 blt mains, HP hydralic lifters , performer 750 carb, performer manifold. Unknown cam, stock exaust. Same drive train specified in my previous post. This car moves it has the 2.73's P275/60R15's on it Th-350 w/shift kit. Traction is ok, unless I brake stand it then I spin all over. But when it shifts form 1st to 2nd it leaves a strip 12 feet long. This is when left in drive and it shifts at 4000 rpm. Beats just about everything it has came up against. I know its not much info, but what do you think this one is running in the 1/4?
Old Oct 18, 2001 | 01:10 PM
fast iroc's Avatar
That will never run to it's best until you raise the compression.Or maybe put nitrous or blower on it with that compression.That woud wake it up.
85 iroc with 305 weind single plane intake, 650 double pumper, msd crap,holley mechanical fuel pump,cam is 230 duration 453 lift, 350 turbo tranny, 2400 stall soon to be 3000, 125 horse shot of nos, 4.10 gears, lower end is built and i shift the 305 at 6500, just for you 305 doubters pull up next to this 305 and get a little
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
