Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
would a be able to beat a LT1 or LS1 w/350 with 400hp and same torque ?
Old Nov 18, 2001 | 04:26 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i plan on buildin up a 400hp/torque 350-355 this summer
and i was wonderin what it would b able to beat
cuz i gotta friend that has a 94 z and i am hopeing to be able to hang or beat him
im also gonna get a posi with either 3.73 or 3.42 gears and a 2500 stall or so
thanks
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Hooker Cat-Back
Old Nov 18, 2001 | 07:43 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I am building a similar 400+ HP 350 this winter and were all pretty much the same weight, so I think we'll be able to kill them.
Maybe even take a newer corvette...?
Old Nov 18, 2001 | 12:02 PM
chevySS's Avatar
I would say you could take the newer LS1's if you got your cars tuned and running right, just remember, the 325 HP or whatever rating they have is B.S. They have closer to 340-350 HP at the flywheel. But you should be able to take them. A race with a C5 would be pretty close I dunno, you could probably edge him out.
Edit: Oh he has an LT1? A pretty quick car, but you would take him pretty bad if you have 400 HP.
Teal Green 91 Camaro RS
305, Automatic Tranny
Stock for now
[This message has been edited by chevySS (edited November 18, 2001).]
Old Nov 18, 2001 | 12:59 PM
dtpmike's Avatar
You need to upgrade suspension so you can hook up also. I think the newer cars have that advantage over us too. They can hook up better.
Old Nov 18, 2001 | 01:00 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
If you really make that much hp yes no problem but, how do you plain to make that kind of hp? I can take the new ls1 vetts to 3rd gear but, thats when they finally pull up. I have 300+ rear wheel hp and tons of torque I for got my numbers but will find my dyno results yet again. If I had 100 more hp I would walk them. no question
Old Nov 18, 2001 | 01:05 PM
Engine: ls1, LB9
and the lt1 will look like a gokart
Old Nov 18, 2001 | 05:57 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
what suspension things work the best?
i was gonna get sub frame connectors but i didnt know if they would help much or not
but they lift bars seem like they have a good idea but i was talkin to my friend that has the 94 Z and he said that all that does is just push the wheels down more and they still break lose
now that could just b his guess...is he right or wrong...and would you recommed getting those or are there ground clearance probs with them?
and i plan on doin this with the System max 2 system from holley
here is the link to it
http://www.holley.com/HiOctn/ProdLin...K/300-503.html
or you if you the new jegs catalog it is on page 61
the guy that is doint most of the work on my engine said that it should b able to get the same specs as that but i doubt it cuz i dont wanna start gettin big headed bout my upcoming motor
Mods-
K&N Air filter
Hooker Cat-Back
Old Nov 25, 2001 | 10:11 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
BTT
Old Nov 26, 2001 | 11:07 PM
rezinn's Avatar
<font face="Verdana, Arial" size="2">Originally posted by chevySS:
</font>
LS1s have much more than 350 horsepower at the flywheel, more like 370-400 depending on the model. Some camaros dyno at 300rwhp stock, newer corvettes have closer to 350. With 400 horsepower at the flywheel you will not be able to beat newer corvettes.
You can take LT1s easily, they are high 13/low 14 second cars stock, while you could get in the low 13s and possibly high 12s with that much power.
Old Nov 26, 2001 | 11:10 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
And what kind of tranny will be backing this up. Neither a stock 700R4 or T5 will handle that power for long.
2 Tickets to game= $250
Gas= $20
Sitting 20ft. from MJ= Priceless
'86 IROC T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK HEADERS Hooker CatBack
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 26, 2001 | 11:28 PM
ws6formula89's Avatar
I don't see how a new LS1 will have 400 horsepower at the flywheel, when most of them dyno at 290-300 rwhp stock. 340-350 I would believe some could produce, but come on, look at the drivetrain loss factor...that's over 25%! If the motor has 400 horse, and the drivetrain robs it of 25% power, and then it would dyno at 300 rwhp.
Not flaming, just saying that 400 is a little unrealistic.
-Todd-
Old Nov 26, 2001 | 11:47 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
what would i have to do to my 700R4 to b able to handle the power?
Old Nov 27, 2001 | 12:42 AM
Violate 3.8's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ws6formula89:
I don't see how a new LS1 will have 400 horsepower at the flywheel, when most of them dyno at 290-300 rwhp stock. -Todd-</font>
I used to have a video of a stock ls1 dyno, and it was 407 hp at the flywheel. I couldn't believe it, those motors are crazy.
Old Nov 27, 2001 | 12:55 PM
Dano 00TA's Avatar
Car: 00 Trans Am/89 IROC
Engine: LS1/L98
Transmission: 4L60/700R4
If you can hook 400 ponies you'll kill LT1's and probably beat or be real close to a stock LS1.
2000 NHRA Edition T/A
Pewter Metallic
A4 3.23 Gear w/GSC's
Whisper lid, MAF Ends, Ram Air Kit, Exhaust C/O
Nitrous Express 150hp kit
60ft:1.94 na
1/8th:8.381@86.03 na
1/4:12.963@108.44 na
1/8th:7.87@94.30 n20
1/4:11.99@120.08 n20
1989 IROC-Z 5.7 Dual Cat
Auto w/3.27 gears
Jet Stage 2 chip
Modified Air Box&MAF
AFPR&Air Foil
Old Nov 27, 2001 | 01:36 PM
Ragin'87's Avatar
if you can hook and are making a true 400hp at the flywheel. Back it up w/ a worked over 700R4, get some 3.73's, good tires, LCAs, LCA relocation brakets, adjustible panhard rod, and SFC's. You should be able to walk LS1's in the 1/4. You have to make sure your **** is tuned up. If you're going to use the stock Carb, that'll rob you of some power if you don't get it built right. If you're gonna go w/ the Holley carb, cut the computer out, and have fun. It's doable, don't get too ****y too fast. There's ALWAYS a faster car around the corner.
Anthony
previous ride: 87 Camaro LT
350, A4.Comp Cams 268H, Edelbrock Preformer intake, Hedman Headers and y-pipe, gutted cat, No AIR/smog pump. 14x3" Open element K&N, Q-jet w/ D hanger and DA rods, adjusted AV spring tension and quick can.
Current ride: 1992 Camaro RS, K&N, Flowmaster, 305, T5, Black, T-tops, 84k miles.
Old Nov 27, 2001 | 09:56 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah im gonna try and disconnect the computer from the motor but keep it to the tranny
and i will b runnin a 750 double pumper holley with vacuum secondaries and dual feed
so i think i will b good
and im gonna get headers after i drop in the motor
and im not gonna get big headed about this motor i just want something to put me into the 13's!!
Mods-
K&N Air filter
Hooker Cat-Back
Old Nov 27, 2001 | 10:19 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Stock ls1s' do not come with over 400hp at the flywheel.
383 86 Camaro Z28 ---1/4 mile e.t&gt;12.89@108.8mph,,
10.5:1compression Dart Pro 1 Aluminum heads 215cc&gt;2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,4.10 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
Old Nov 27, 2001 | 10:38 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
heh if all you want are 13's from a 400 horse motor you wouldnt even need traction goodies. 400 horsepower has 12's written all over it.
Old Nov 27, 2001 | 11:07 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
well see that is what i was hoping for
cuz i dont have all the money in the world
im tryin to do this swap on a 16 year old $7/hr job
lol
im hoping i can build up the tranny some and just put in the engine and then downt the road when i want faster times i will do all the goodies
lol
Old Nov 28, 2001 | 01:45 AM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
What everybody keeps forgeting is; whatever you do to your TPI car(mods) the LT1 or LS1 guy, can do as well. Chances are the LT1/LS1 cars are also modified. Kind of sucks, eh? You are playing pointless catch-up, no?
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear.
Dealer instaled:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(50), Harwood fiberglass hood.
Flowmaster 3" Cat-back exhaust,TB coolant bypass,B&M Ripper shifter, Centerforce dual friction clutch, Ported & Siamesed Plenum matched to SLP Runners w/Edlebrock Base, March Power/Amp Pulleys, Richmond 4.10 gears,265/50/16 BFGoodrich rear tires.
Old Nov 28, 2001 | 11:00 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
my car isnt TPI
its CARBED!
and dont worry im not keepin the stock carb
im gettin a 750 holley
and i live in a town of a population of like 1800 people
we only have one brand new trans am running through town and its not like i wanna b able to beat him to show off to him
its just that i want to b able to be as fast as him.....cuz i have seen them get on it b4 and man those look quick!!
lol
Mods-
K&N Air filter
Hooker Cat-Back
Old Nov 30, 2001 | 04:39 PM
Perry93TransAm's Avatar
Car: 97 WS6 T/A
Engine: LT1 383
I have a 93 but I have less than 400 hp at the crank and am knocking down 12.39s at 111. Havent seen too many LS1s naturally asperated stay even clost to me. The third gens suspension is very simular to the 4th gens (in the rear anyway) so if you can plant it you'll smoke em good.
Perry
Old Dec 1, 2001 | 09:53 AM
Car: 97 WS6 T/A
Engine: LT1 383
As some reccomendations for the motor, I would run all your money into the heads. get you some good heads and have them ported. The cam I would use would be a cam with 220 int .050 dur and 230 exh .050 dur about 520 lift on both sides and 112 degs lobe sep. Run a 3000 stall and some 3.73 rear gears with a 26 inch tall tire. Get a stand alone controller for the tranny to give you the ability to lock it up as you please, independant of the factorty computer. if your car is weighing around 35 to 3600 race weight , and you hit 380 to 400 hp you'll smoke em good.
Perry
Old Dec 2, 2001 | 12:26 AM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
yah i am gonna use this system from holley called the system max 2
it comes with the whole setup
just go to www.holley.com and check it out
it said 425hp and same torque but i was guessin 400 cuz nothing ever seems to turn out perfect when i try and do soemthing to my car
lol
i already have 3.73 but i need a posi, i have 245/60R15's
and i was gonna get that manual lock up but with a 2500 stall instead
thanks for the post!
Old Dec 3, 2001 | 09:52 AM
Car: 97 WS6 T/A
Engine: LT1 383
Those are some good heads, what I would do with them is smooth them out in the bowl area even more (not remove alot of material just blend into the seat) this will help some, not sure of the specs of the systemax cam but if its making 425 horse on a 10.0:1 motor its probably pretty good. remember your heads flow the air its just the cam that holds the valves open, i.e. more heads take less cam to flow the same amount of air to make the same power.
Perry
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
abray1
Sep 10, 2015 04:53 PM
L0tuS
Sep 4, 2015 11:16 PM
