how bad would i loose?
My car is not even done yet. but theres a kid with a "stage 2" srt-4 and hes always saying how hed beat my old shitty camaro. i have a 350 4 bolt mains .40 over, 292 comp cam .501 lift, some old ported and polished dart torker heads, edelbrock performer intake, edelbroke 650 carb. 5 speed with 3.08 gears. i dont know what a stage 2 entails, but from my undersgtanding those neons are quick. i mean even if i lost the kid is still driving a dodge neon, so whos the real loser? lol Im kidding but i was just curious. the previous owner of this motor said it made 400 crank horsepower with a different carb.
Car: 92 RS
Engine: 5.slow
Transmission: 5speed
Re: how bad would i loose?
Dont know if your familiar with the SRT8 Chargers,but my nephew had an 05 neon srt4 with stage 2,and his friend has a srt charger,the neon would run with the charger from a roll.From a dig they have serious launching problems.I wouldnt take him too lightly if he can drive.He had to do some serious power shifting to keep up with the charger but he did it.By keep up I mean MAYBE half a car length back.My nephew traded the neon in on a srt8 Jeep lol.The neon was fun but too many problems.
ok im just getting an idea. im gunna say i have well over 300rwhp. but this kid is a 17 year old smartass and im sure i can drive better. i just dont wanna be that guy talking **** and his little srt4 walks past me. i knew a kid that had a pretty serious one with barely any mods, figured id ask. so a stage two neon is like a low 13 high 12s vehicle?
Car: 92 RS
Engine: 5.slow
Ehh,maybe.They have serious issues hooking up at the track unless u put some slicks on and aftermarket axles.If you have 400 horse then you probably will win.RUN FROM A DIG!!! you will walk away im sure lol.
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
You already won, he drives a neon.
Car: 1992 RS B4C
Axle/Gears: 3.23 10 bolt limited slip
http://www.dodgeboy.net/news/neon/index.htm
Pretty much has every little detail. Stage 2 has about 265 HP . Wonder what that does for its already decent 5.9 sec 0-60. Curb weight 2950
Car: 88 trans am
Engine: 350sb
Transmission: t400
Axle/Gears: 7.5/2.73
My buddy has a 2004 srt4 with bigger injecters, a aftermarket baby turbo, bov , headers w/ cutoff valve, and a stage 2 clutch. His is fast but I beat him with my 350 sbc 4 bolt main with 190cc heads, 750cfm carb, .488 lift cam, stock crank rods and pistons, 255gph fuel mechanical fuel pump w/ a regulator @ 5psi , t400 tranny and 2.73 rear end w/ custom aluminum driveshaft.
But his is still fast and the baby turbo helps him spool faster so hes at max boost the whole time
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
I owned a 2004 srt-4 which i put stage 2 on if he runs hom high octane mode and is a good driver the car on street tires should run low to mid 13's from a dig he should be able to catch you and from a roll forget about it i now own a 89 formula l98 and it would not even be close the srt would walk me good luck
Engine: gone
Transmission: gone
Axle/Gears: gone
I think in a race like this you'd do whatever you can to embarass him. its just not good enough beating him by a nose.
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
you will need the 100 shot to have a chance i know thats not what you want to hear but if he can drive the srt will move good luck hope you win
Car: 88 trans am
Engine: 350sb
Transmission: t400
Srt-4 stock power is 230 and they aren't that light, so he would need a considerable amount of upgrades to beat a good built 350. Stage 2 would be intake, headers, exhaust, stage 2 turbo/bov, aftermarket downpipe , aftermarket intercooler, and I'm pretty sure for it to be considered stage2 it needs a new cam, that might be stage 3 though.
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
stage two only consist of bigger injectors inter-cooler sprayer different computer and hom (high octane mode) which increases your timing and makes a pretty big difference, stock exhaust and stock turbo. on street tires on stage two i could pull 2.0 to 2.1 60ft times and on drag radials 1.8 so that is not to bad for front wheel drive also you can take those turbos all the way up 19lbs of boost no problems on stock clutch and trans if you guys race please post results good luck man hope you take him
Car: 88 trans am
Engine: 350sb
Transmission: t400
