Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
90 IROC vs 90 5.0
Old Dec 8, 2001 | 03:15 AM
Curse Z28's Avatar
90 IROC vs 90 5.0
Ok what do you all think the outcome would be?
My car is a 90 IROC, 350 TPI bone stock.
My friends car is a 90 Mustang 5.0 LX Hatchback 5 speed also bone stock
Both cars are within 2,000 miles of each other on the odometer.
thanks.
Old Dec 8, 2001 | 03:43 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Close race. If the performance data in the old articles section of this site is accurate, the IROC will edge out the rustang.
'87 Red Formula Firebird
-mostly stock LG4 w/cowl induction setup borrowed from '83 TA and T5 tranny
'85 Corvette
-stock L98/4+3 manual tranny
-z51 package
Old Dec 8, 2001 | 03:47 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
The IROC.
Old Dec 8, 2001 | 06:01 AM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
Probably the IROC...the auto will be simpler to launch and that's what will win the race between two cars so equal.
1989 Mustang LX 5.0 Coupe
13.29@106.66 - needs more gear and converter
1992 Mustang LX 5.0 Convertible
14.23 @ 95.something - 100% bone stock motor - it's been a while since I've ran this one
1993 LX 2.3L Hatchback - "The Ride to VCU"
Moderator Stangtec.com, SN95.com
Co-Founder, Tri Cities Mustang Club
Amelia and Nic's Twin Terrors
Old Dec 8, 2001 | 08:42 AM
12sMustang's Avatar
Driver
Old Dec 8, 2001 | 10:21 AM
karstenkurtz's Avatar
Really close. Biggest factors will be the drivers and who has there car in tune the best. If you haven't changed your spark plugs in a while and kept up little **** like that then you could easily loose. But so could he if his isn't running 100% to spec like when it was new. Your talking about two cars that brand new were about a tenth off each other and we all know how easy it is to make a small f*ck up to cost you a couple tenths.
Karsten
86 IROC-ZZ4... too much to list.
Old Dec 10, 2001 | 12:35 AM
Curse Z28's Avatar
well we ran, here's how the race went down...
We lined up and went from a 40mph roll...i immediately put a car on him from the get-go, and pulled him all the way until he let out at 110...i had three cars on him at that point and was still pulling.
We're gonna go from a dead stop next time.
Old Dec 10, 2001 | 02:47 AM
Garett92Z's Avatar
you should take him even MORE from a dead stop... the IROC just hooks up a little better, has more torque down low, and has better gears out back.
like mentioned, get your car tunedup to 100% then do a few of the 'free mods' in the tech section and get a catback and build a ram air.
then you'll be eating him alive. well, not alive. whatever.
garett
Old Dec 10, 2001 | 04:40 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I'm not counting racing from a roll. Going from a standstill heads up it's going to come down to driver. The Camaro will be easier to launch but the Mustang has a better gear ratio spread b/c of the 5-speed. The Mustang is also lighter. It's also possible that the cars have the same rear end ratio. Try and get a flagger to start the race and get someone to mark the 1/4. Also do all the free mods as suggested above.
Old Dec 11, 2001 | 01:18 AM
Curse Z28's Avatar
his car is a 3.08 car, mines a 3.23...im pretty sure it would be uglier from a stop.
Its not a driver issue, mine is just clearly the faster car.
Cleotiz
Jan 6, 2018 08:56 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
Thornburg
Aug 27, 2015 08:28 PM
mustangman65_79
Aug 11, 2015 03:17 PM
