Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Supercharged 4.6L Stang vs my Vette
Old Jan 30, 2002 | 07:19 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
So a friend of mine in his turbo civic came across this Mustang while cruising one evening. Its the 4.6L GT coupe, with a supercharger. Unfortunately, thats all i know about it. The only other details he added were that it was loud, and when the owner popped the hood, lots of smoke came pouring out. He said it was comsuming oil. So if its up to my friends, theyll be challenging this Mustang for me. Before i go into battle for them again, i have to ask, do i stand a chance? What do you think these things run? By the way, in addition to the mods in my sig, ive recently added an airfoil, ported the intake plenum, a 160 degree stat, relocated my MAT sensor into the intake tube, and raised my base timing from 6 degrees to 10. Id have an updated track time, but my local dragstrip doesnt open until late Feb (just 23 more days!!!) Thanks.
Old Jan 30, 2002 | 07:23 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
sorry about the multiple topics, this just happened for some reason. I only posted once!
Old Jan 30, 2002 | 07:34 PM
mss's Avatar
mss
dont worry , i deleted the others
Old Jan 30, 2002 | 07:37 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Its the server. I think u might lose this 1.
Old Jan 30, 2002 | 07:40 PM
CobraKiller's Avatar
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
Depends on what year 4.6 stang. And with the details being pretty vague it's going to be hard to get a straight answer. I'm guessing if it's a 96-98 stang the best stock you'll see out of one of those cars is a high 14 to low 15 from what i've seen of them at the track. Add some exhaust work and a supercharger and I'd guess that it would be a close race with you if the car was in good tune but overall i think you would probably edge it out by a small distance depending on the better driver of course. If it's a 99+ GT and the car was in good tune with exhaust work and a supercharger I think that car will be pulling high 12's in the quarter to very low 13's with even a decent driver behind the wheel. I say go ahead and race and see what happens. Definitly nothing to lose.
Old Jan 30, 2002 | 08:26 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Its the 96-98 4.6 liter.
Old Jan 30, 2002 | 08:28 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
I agree with Cobrakiller 100%
Old Jan 30, 2002 | 08:39 PM
Nic's Avatar
Nic
Car: 1993 Ford Mustang
Engine: 5.0L
Kind of need to know how much boost it's running and if it's intercooled or not. That makes a huge difference. Some street kits make 5 lbs of non-intercooled boost, some make 14 lbs of intercooled boost.
Old Jan 31, 2002 | 01:06 PM
5.0mustang's Avatar
My guess is that you'll lose, because the average kit is running 9psi and with an exhaust and proper fuel system, that would put it in the 12s with a good driver. If I were you I would look at what else he has and then make your decision from there. Although if you race and win it would be really nice to say you beat a supercharged mustang.
Old Jan 31, 2002 | 03:40 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
I figured id probably lose this one, but if i can find him, ill race him anyway. You guys dont think the burning oil problem is going to be a hinderance? And you think that a low 15 sec car (remember, its the early 4.6 version) can shave a full 2 sec or more off his quarter mile time with a supercharger alone? Well, i got the same response from two Mustang guys, so i guess its true. Oh well, ill let you know how this turns out if i can find him. Thanks!
Old Jan 31, 2002 | 05:38 PM
5.0mustang's Avatar
You have to remember that I'm taking into consideration that a 9psi supercharger is like a 150+ shot of Nitrous. So there you have a now mid 13 second car. Then you take into account the better fuel injectors and pump, to not gain too much in 1/4, but should put him near low 13s. Then you said it was loud, so I think full exhaust and there puts him into the 12s with a good driver. The oil problem may come into play, but if he put the money into the car for the supecharger he will probably have that fixed. I still say race him and good luck.
FormulasOnly
Jul 23, 2018 08:47 AM
BDR
Nov 7, 2015 03:05 PM
-=Z28=-
Sep 24, 2015 10:21 AM
R13_Braz
Sep 18, 2015 05:00 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
