Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Damn pop-ups!
Old Apr 15, 2002 | 08:00 PM
TA Terror's Avatar
Damn pop-ups!
Well it was just a matter of time, damn passenger side headlight motor went. Does anyone have any tips on replacing them? Also, I still need to find a good used one. GM still has some new units available (at $300!), and Paradise Alley is always a last resort.
Old Apr 15, 2002 | 08:38 PM
nblanchard's Avatar
I heard of someone selling metal gears for the unit... what do you need?
Old Apr 15, 2002 | 09:03 PM
IROCKER's Avatar
Well I've got your TFbM card here. With that your motor wouldn't be that much from GM. Keep in mind that anything from Paradise Alley is used.
Old Apr 15, 2002 | 10:03 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
If I can remember where I saw it, there was a tech post on rebuilding the gears inside.If I think of where I saw it,I will post it.
Old Apr 16, 2002 | 08:06 PM
TA Terror's Avatar
I read on the tech boards that some guys just took the motor apart and cleaned the contacts and that fixed it. Maybe this weekend I'll have a chance to pull it out and open it up.
thanks guys
Old Apr 16, 2002 | 11:35 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Hey Nathan,I saw that on a link from someones site. The cost is $300. They would never need replacing.
Old Apr 23, 2002 | 08:42 PM
TA Terror's Avatar
Tried them again today, AND THEY WORKED!? What gives?
Old Apr 23, 2002 | 08:47 PM
Snowracer's Avatar
Maybe it's not the motor? did you check the ground?the relay? just a thought..........SR
Old Apr 23, 2002 | 08:52 PM
trigger GTA's Avatar
Car: 92 TA vert
the day it did not work was it realy cold out? you most likly have a bad ground like snowracer said
Old Apr 23, 2002 | 10:11 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
....bearings......?
Old Apr 24, 2002 | 08:03 AM
TA Terror's Avatar
It was kind of a cool damp day.
Old Apr 24, 2002 | 09:29 AM
IROCKER's Avatar
I would just hold off till the next rainy day and see if it does it again. Perhaps moisture is getting into the motor?!?
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
Cornholio7979
Sep 20, 2018 02:31 AM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
Ragtop Man
Sep 12, 2015 12:23 AM
