Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Info on these sounds!
Old Apr 16, 2002 | 09:33 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
I already posted some weird DISH BRAKING, TOOL BOX RUMMBLING noises from the front end of the car. The car sounds so lameeeeeeeeeeeeeeeeeeeeeeeee with this!!!
I hate it, I swear its so retarded sounding... sounds like "its a pos"...
what is it? has anyone had this probleM????!!?!??!!!
Also my engine runs and never siezed when the Engine ran out of oil.. but now I might start the car.. it would go to the normal RPM and just drop to 0 agian... But if I add some gas it starts up fine. At the normal RPM and stables at 650 I belive.. or 600 whatever it is.. it also makes a weird noise I dont know how to describe it really... its like a "clunk" noise.. like "clunk... clunk.. clunk.. clunk"
any ideas?
Old Apr 16, 2002 | 10:25 PM
johnyIROC's Avatar
Clunk from inside the engine could be spun berring. Does the frequency of the clunk speed up when you go faster?
Old Apr 16, 2002 | 10:36 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
dave, if we find someone who figures out our toolbox sounding cars we should give 'em a prize....I'm still hoping it;s shocks.
Old Apr 16, 2002 | 11:26 PM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
Check your front brake pads, If you can wiggle your padsback and forth, or up and down, they will need to be tightened up. If you have a large set of lock-jaw pliers, you grab the top tab and the bottom tab and gently squeeze them onto the caliper.The tabs should have done when the brakes were off the car,there is also an anti-rattle clip that is located on the inside brake pad that goes back into the caliper piston. This could have broke, or rusted out.The only way to access those is by removing the pads, which means pulling the caliper off the rotor.Good luck, I hope this helps.
Old Apr 17, 2002 | 12:07 AM
Snowracer's Avatar
"it also makes a weird noise I dont know how to describe it really... its like a "clunk" noise.. like "clunk... clunk.. clunk.. clunk" "
Did you ever check the pulley that you said was rattling in your origional post?? If a bearing or bushing is going bad (or really bad) it will make some godawful noises. If you suspect that might be it Take off your belt and start it up and see if that makes it go away. If so that find's your "clunk" and you will know where to start to fix it.
I still think the "toolbox" sounding noise is front spring /shock They make horrible noises when they lose their charge.
If you don't know how or don't have an easy way to get your car on stand's to check it yourself, take it to a Midas or Speedy muffler etc and get a free frontend inspection. ( You don't have to get them to fix it but then you would know what it need's) Then you can likely find someone to help you fix it..............SR
P.s if you do take the belt off to check for noise it might give you a check engine light (code) just disconect the battery for a few minutes to allow it to reset
Old Apr 17, 2002 | 08:00 AM
IROCKER's Avatar
I'll let you know the next time I'm out in Hamilton so I can listen to it in person. Should be within the next week or so. Did you get the oil leak fixed? You didn't drive it long with no oil did you?
Old Apr 17, 2002 | 12:13 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
IROCKER
Hey IROCKER
that sounds great man.. Thats exactly what I need right now!
Btw what was the stuff u soaked your signal light covers in?
the polish u did is still looking sharp on them.. im not getting into the doing up stages.
Old Apr 17, 2002 | 01:39 PM
IROCKER's Avatar
I used Simple Green and rinsed it with a lot of water. It worked out ok and got rid of most of the stuff, but it's not the most perfect method.
Old Apr 17, 2002 | 06:25 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
well IROCKER...
I used ur method..
and shall I say..
DAMmmMNn
NIceeee
Old Apr 18, 2002 | 09:46 AM
IROCKER's Avatar
Nice! Of course you could've bought mine already finished! hehe *just buggin ya*
92firebirdguy
Sep 1, 2016 07:53 AM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
Nick Locking
Car Audio
Sep 30, 2015 04:24 PM
cstrobel65
Sep 16, 2015 11:54 AM
Blue419
Sep 10, 2015 01:03 PM
