Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
The winter build-up begins...
Old Oct 27, 2002 | 07:31 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
I picked up some 3.73s this week-end. Got them for a reasonable price no complaints. Probably won't get them in till spring time so they will sit in the trunk for a few months.
Anyone know where you can get the list of VSS tranny gear codes ? I'll need one for the upgrade from 3.42s. Oh yeah the 3.42s will be for sale real cheap.
Next on the list -- new clutch and tranny work. Checking out a Ripper for the Borg-Warner as well.
adious,
RP.
Old Oct 27, 2002 | 07:34 PM
johnyIROC's Avatar
3.73 is a nice gear...
Don't you have a 9-bolt? I thought you did for some reason.
Old Oct 27, 2002 | 08:16 PM
palric's Avatar
nope
Nope I count 1...2...3...4...5.... 10 bolts. Yah know I never checked before I bought the kit -- just assumed it was 10 bolt ?!?!?
Yah I really like the 3.73 with the T-5 around town. Should help in the 1/4 as well.
RP.
Old Oct 27, 2002 | 08:57 PM
STIFFLER's Avatar
3.42 to 3.73 let me know how it works out.. I have thought about that swap, but not convinced it would be a worth while swap. but maybe. there's a guy with a 92 camaro on the TPI board that put 3.73's and he dynoed at 209rwhp but I don't think he was G92.
Still going with the 305? or 350 now days?
Old Oct 27, 2002 | 09:04 PM
ClarionedCanuk's Avatar
I was gonna say 3.73s would be too much for a tpi, but with a t-5 you should get some nice launches .
I am going for a fourth gen 3.42 rear this winter... Just a year since my dif rebuild and its already been a peg leg for over a month and starting with the funny sounds again! Not to mention the passenger side disc is sticking and warped. The whole things getting scrapped, and replaced with 12 inches in the back with any luck .
Old Oct 27, 2002 | 09:22 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
How much for those 3.42's?
Old Oct 27, 2002 | 10:01 PM
16th owner's Avatar
Hey Richard, just curious if your sure you have the right gears for the car. There are a number of different 10 bolt rearends.
7.5 & 7.625, 3 carrier ..... 7.5 & 7.625, 2 carrier. They show different part numbers.
Just thought I'd ask, cause if you don't install them for a couple months and they're the wrong ones, you may not be able to exchange them.
Martin.
Old Oct 28, 2002 | 09:50 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Dibs on the 3.42's. I will have some 4.10's available this winter.
Old Oct 28, 2002 | 11:58 AM
darbleinad's Avatar
Car: 84 Trans Am
i got dibs on the 4.10s.
Old Oct 28, 2002 | 01:10 PM
johnyIROC's Avatar
WTF... I thought for sure you had a 9-bolt. What is going on?
Old Oct 28, 2002 | 03:59 PM
palric's Avatar
talked to Summt
Martin.
I had a long talk with Summit Racing seems they have one solution for 7.5 and 7.6 -- atleast in Richmond Gears.
I have a 3 carrier so got an 11-41 in 7.5.
Thats all for now,
RP.
Old Oct 28, 2002 | 05:35 PM
palric's Avatar
a secret
Originally posted by STIFFLER
...Still going with the 305? or 350 now days?
I ain't talking about it till next dyno day which I expect will be spring 2003 ?
adious,
RP.
Old Oct 28, 2002 | 05:57 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
The GTA has a 9 bolt. The Z28 has a 10 bolt with 4.10's which would render the car useless for anything more than burning tires.
Old Oct 28, 2002 | 05:58 PM
darbleinad's Avatar
Car: 84 Trans Am
sounds like you want to sell me those 4.10s
hehheeh...how much do you want?
Old Oct 28, 2002 | 08:04 PM
16th owner's Avatar
Should be the right gears Richard. I believe the 7.5 & 7.6 use's the same gear. Just the housing size and cover plates are different.
If you have 3 carrier gears and that's what the car has, they should fit regaurdless. The 2 carrier use's different one's.
Sorry, didn't mean to cause you any grief. Wasn't sure if you knew about the 2 & 3 carrier sizes.
Martin.
Old Oct 28, 2002 | 08:37 PM
copperchick's Avatar
Car: 1984 Z/28
Engine: 383 stroker
I am contempleting a swap to 3.73's. I'll stay tuned to see how you like yours.
bjpotter
Oct 15, 2015 11:07 AM
tmellott89
Oct 14, 2015 02:06 PM
meeklay812
Oct 1, 2015 03:46 PM
Formula8r89
Sep 22, 2015 04:24 PM
86White_T/A305
Sep 21, 2015 05:28 PM
