Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
L98 questions.
Old Oct 30, 2002 | 09:17 PM
turismo's Avatar
Car: 1989 Trans Am GTA
L98 questions.
what's a proper way of checking if your engines actually getting a spark?
I was talking to my mechanic today as I was getting an oil change for my crown vic.
I told him that my gta stalled on me and that it isn't running right now. I told him exactly what happened and he thinks it's basically not getting any spark. so how do I check?
he said something about briding it with a screw driver.
thanks.
simon.
Old Oct 30, 2002 | 09:38 PM
ClarionedCanuk's Avatar
Just pull any plug, put the boot back on and press the thin little L shaped thing (on the end of the plug, across from the tiny cylinder shaped thing) against a clean ground (a clean spot on your engine, chassis etc) get someone to turn it over and you should see a spark, if you dont, then check another cylinder or two to be sure.
greg
Old Oct 30, 2002 | 09:48 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yeah, put the screwdriver in the wire. Then lay it against something metal and you should see an arc.
Course you could take a wire off witht he motor running, if you get shocked, it's working right.
Old Oct 30, 2002 | 10:03 PM
turismo's Avatar
I'll wear some thick rubber gloves so I don't fry my ***
ok so I think I got it.
screwdriver to wire to clean ground must see arc
Old Oct 30, 2002 | 10:12 PM
Err ya sorry the driver in wire test sounds better/quicker. My test is too see if your plugs are firing alright as well. But if I remember correctly they way your car broke down it wouldnt be the plugs...
greg
Old Oct 30, 2002 | 10:21 PM
turismo's Avatar
I'm going to visit the car soon. It's at the farm right now sleeping
they have a charger there so I hooked it up so the battery should be fine but I had to leave before I got a chance to see if with the full battery she would start.
something I neglected to mention is that the car had stalled once before.
I went to east side marios with my girl for dinner. about half an hour. we drove through the parking lot because she wanted to go to a store for some clothes. we came out and I tried to start the car and there was nothing. the engine wouldn't even crank. dash lights came on though. I poped the hood and let the car sit for about 3 minutes. after that I didn't have any probs for a long time.
Old Oct 30, 2002 | 10:36 PM
turismo's Avatar
another question.
before this **** with my car started to happen I heard a buzzing sound coming from the spark plugs or in their direction. even my buddy said so because we where looking under the hood like the monkeys we are.
it's sounded basically like a cut wire of some kind. buzz buzz buzz
I dunno. bah!
Old Oct 31, 2002 | 11:31 AM
nblanchard's Avatar
I would rather use the sparkplug against ground test... a screw driver may put too much strain on the ignition system?
91chevyz28
Feb 10, 2022 07:58 PM
FormulasOnly
Jul 23, 2018 08:47 AM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
raymondandretti
Sep 27, 2015 06:43 PM
