Valve Springs
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
Valve Springs
Hey, I am looking at getting a new cam, most likely the LT4 Hotcam, but the kit is kinda pricey. The heads I have right now have been rebuilt ( 0 k's) and have 1.5 Roller Rockers and Z28 Heavy Duty Valve Springs. Now, with the 1.5 Rockers my lift will be reduced somewhat, I saw in a post somewhere by .030. I went and found the specs on the Z28 springs and it said that they were good for .550 lift. The LT4 springs are good for .525. So I should be okay to use the cam with my current parts?
Dustin
Dustin
If you're gonna go to the effort on putting in a new cam, the price of new springs is cheap insurance that you're not gonna bend a valve. If you're getting the LT4 HOT cam, then the LT4 springs should be fine. But I would not use old springs.
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
I think daz is correct with the .480 lift numbers....but like Irocker said.....change those springs when when you change the cam, is good insurance.
Car: 92 TA vert
.480 is the max for stock springs.
you could always pic up a good used hot cam for alot less. but no mater what replace your spring. its most likly they are worn out anyways
Car: 91 Z28 Vert
Transmission: TKO
BTW....since we are on the topic of springs etc, what will "worn out" or "tired" springs result in...I am not talking broken ones, but ones which maybe should probably be changed??
