Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
throwing this idea out there..
Old May 29, 2003 | 09:05 PM
STIFFLER's Avatar
I have been thinking alot about building a 302.. I know you need a 283 crank wtih 4.00in bore block.. Now could I use one of those cranks in a 87-up roller motor? Or would the journals be to small or big?or can I buy a crank from someone?
STIFFLER's Avatar
oh ya and what kind of cam would I need... could i use the XR270 I already have?
Old May 30, 2003 | 01:21 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Diff journal size and rear seal
Daz
Old May 30, 2003 | 05:37 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Hay Stiffler .... Palric has been searching for that stuff as well ...maybe talk to him ....he can probably help
Old May 30, 2003 | 03:24 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
I've heard that you can use the crank that came in the "baby LT1" 4.3 V8 that was available in Chev Caprice's. I remember reading an article that came out a few years ago where Chevy built a one off 97 Z28 that had a 302 LT1 motor in it. I remember reading that they used the LT1 block, with the crank from the baby LT1 motor, and they got 302cid. Might be something to look into at least.
Old May 30, 2003 | 05:39 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Find a complete 283. Have the block bores sonic tested.
If, any of the bores don't pass the sonic test they can be sleeved.
Then bore the motor to 4.00" Use 302 pistons.
Engine builders used to build this before GM got the idea to build a Factory 302.
You're much more likely to find a good 283 core than a 302 crank.
Old May 30, 2003 | 07:39 PM
85rocker's Avatar
- use 88-92 4 bolt 4 inch bore roller sbc
- use L99 crank from '94-'96 Gen.II 4.3 liter V-8 (single rear seal)
- use L99 rods from '94-'96 Gen.II 4.3 liter V-8 (5.94 inch)
- use LT4 pistons
- use flame retard paint
Makes a 302 roller block. easy to find parts, journals fit, pistons at the right height. The flame retardent paint is what you'll use when all the peckerheads who don't know sh*t flame you for building it and not a 350.
Old May 31, 2003 | 01:04 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
- use LT4 pistons
You'll also need that wacky harmonic damper that the L99's used, I think. I'd rather build a 383 but the 302 would really have the cool factor nailed.
83 Crossfire TA
Jan 3, 2016 01:26 PM
GouldyGTR
Sep 7, 2015 09:05 PM
IROCZ1989
Sep 4, 2015 11:54 AM
mrdevontay
Sep 2, 2015 08:04 PM
greenyone
Sep 2, 2015 03:39 PM
