Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Jealousy?
Old Jun 2, 2003 | 07:50 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Jealousy?
Well I took my 'bird to work today for the first time since last fall. There are a few new guys there who hadn't seen them yet. One guy had just sold his 383 Camaro last week, I swear I thought he was gonna cry. lol
Anyway, I had popped the hood to show my brother how my fingernail actually marred my fuel rail (left a hole in my nail too). One of the other new guys, previously a mechanic, came over to take a peek. He seemed to be trying to force all sorts of odd suggestions as to what I should do with my engine. first, scrap the stock airbox and put a K&N directly on the TB. Sucking in hot air from there? Nope, he wouldn't hear of it. I don't even want a K&N to begin with. His second suggestion, replace the TB with a high-flow Holley unit. Overkill for a 305? Again, he disagreed. My suggestion of an AFPR? Worthless on a 305, according to him. I said I wanted a cam and chip from a 305/5 speed, he said to get a 350 cam. Uhh... Aren't they the same? It's like he was arguing just for the sake of arguing. I get enough of that from my brother... lol Whatcha think?
On the plus side, it's nice to have people walking on the street stop and watch my car go by, even if it is a measly 305.
Old Jun 2, 2003 | 08:01 PM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
Re: Jealousy?
Nothing wrong with a 305
Old Jun 2, 2003 | 08:17 PM
STIFFLER's Avatar
Nothing wrong with a 305 at all... I know alot of guys with there 350's say a 305 isn't as fast... but they think again after we race...
305's are a good engine.. I have had good luck with mine...
Old Jun 2, 2003 | 08:32 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
Seeing that you have a 90 LB9, the camshaft in your car should be the same as the camshaft in the 5 speed cars and the 350.I believe the 5 speed cars usually got the G92 which includes the dual cat exhaust which makes up for the hp difference between the LB9 auto and 5 speed. At least thats how it is in the camaro world.
Old Jun 3, 2003 | 05:39 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
<--------- 5- speed ....no G92
Old Jun 3, 2003 | 09:27 AM
Eric2ndGen's Avatar
Opinions are like a$$holes- everyone's got one and they're usually full of $hit...
Old Jun 3, 2003 | 02:57 PM
STIFFLER's Avatar
Just like you my friend!!
Old Jun 3, 2003 | 03:40 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Re: Jealousy?
Sadly, clowns like the guy that was offering you advice are the reason that the world is full of slow modded TPI cars.
Old Jun 4, 2003 | 06:08 PM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
So I'm not way off base in disagreeing with this guy, right?
He also frowned upon my TB coolant bypass, saying that it can still get too cool outside during the summer mornings. Uhh... Cold enough to freeze a throttle body? When I said that since it's a summer car those lines only serve to heat up the incoming air he just nodded and said yeah, as though it was a good thing.
As for the cam, last I heard the 305/700R4s got the crappy cam (peanut cam?) while the 305/5 speed and the 350s got a decent cam and a better exhaust. Of course, I have been wrong before.
Old Jun 5, 2003 | 01:37 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
TPI's have decent cams... TBI's use the peanut cam. Check the tech data section off thirdgens main page for cam specs.
Old Jun 5, 2003 | 09:08 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Oh I know all about the Peanut cam in the TBI's...but we are changing that
Old Jun 6, 2003 | 02:32 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
U are correct about the auto's. But not all 5-Speed got the good cam, Just ask Dan (D's89IROCZ).
I can get u the GM cam part #'s and spec's if U want them, I have the F-Body GM cam lists.
Old Jun 6, 2003 | 06:46 PM
icebird_1981's Avatar
lol i no i luv the feeling every time i am out every one just eyes my car not a day goes by where someone does not say nice car.
i luv it...lol
Old Jun 6, 2003 | 09:38 PM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
Is there an easy way to tell for sure what cam I have? It doesn't have enough guts to lead me to believe I have a decent cam, although I have never driven a 350 to compare.
Old Jun 9, 2003 | 08:41 PM
mikobu3's Avatar
take your car to the track , a good cammed 305 would be around 15 to 15.4 , peanut cammed cars are slow , 15.9 -16.1 ,
if you got other mods you do a little better
Old Jun 10, 2003 | 05:37 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
I HAVE the good cam Adrian ..... I did run a 15.1 ....... w/ 225'000 kms(stock) ...so I am assumeing it is the good cam
but when I take that motor out ....I give the numbers on it
Old Jun 10, 2003 | 07:54 AM
'89 superbird's Avatar
Don't know how accurate it is but in the tech data section it says that you can tell what cam you have by your tach. If it is yellow at 4500 and red at 5000 then you have the lesser cam and if it is yellow at 5000 and red at 5500 then you have the other. This might help
Old Jun 10, 2003 | 01:10 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Mine is at 5500 ...... I thought all the TPI 5- speeds had the good cam
Old Jun 10, 2003 | 02:41 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
either cam sux..why bother??
daz
Old Jun 10, 2003 | 02:48 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
daz
Amen. I wouldn't go any smaller than the LT4 production cam and even that is kinda small.
Old Jun 10, 2003 | 03:52 PM
mikobu3's Avatar
on a 305 tpi , i'm going with 212-218 449 456 112lsa ,
thats big enough for the we05
Old Jun 10, 2003 | 09:06 PM
Double chk your cam #'s with the part numbers I posted on the KWF site and u shal know. Your Tach is the right one for the good cam. I cant remember what all options were avail on the 89 I think u didnt have the G92, not sure, but i do know that the 88-89 350/305 5-Speed had the best cams of all the years. I'd have to look it up again, I got a memory thats as good as an alzhymers patient.
Old Jun 10, 2003 | 10:59 PM
Idlehands's Avatar
Car: 1985 Trans Am
what about the 85 T/A LG4.5 speed.?.....
Old Jun 10, 2003 | 11:08 PM
Idlehands's Avatar
Car: 1985 Trans Am
and which cam would be recomended for best output?...also nice sounding......little bit of ticking....
Old Jun 13, 2003 | 08:41 PM
SBlackfoot's Avatar
Engine: LB9
Axle/Gears: 2.73's
Yep, my yellow line is from 4.5k-5k and red from there. I guess that just about settles the cam issue...
Guys, not all of us need or want stupidly big cams. Granted mine is wimpy but I don't really need anything more than the better 305 cam. Plus with the chip to go along with it it would be a drop-in job, no pissing around with burning proms.
Oh and this former mecanic was at it again. He asked my brother if he adjusted the front or the rear torsion bars in his Pathfinder. I haven't seen anything with rear torsion bars since a Tamiya XR311. A mechanic should know better. He also said I should've gotten pulled over when I had my temp permit in the window, although he may be right about that one (plates still on, stickers then expired).
ZenShaman
Nov 13, 2012 09:48 AM
ZenShaman
Nov 11, 2012 10:25 PM
82TAracer
Southern California Area
Dec 9, 2010 04:30 PM
Andy Fanshawe
European Region
Aug 4, 2003 02:48 PM
Xophertony
Jun 10, 2003 08:37 AM
