Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
started gear/posi swap and header swap
Old Aug 27, 2003 | 11:13 PM
darbleinad's Avatar
Car: 84 Trans Am
i had a chance to get my car into my best buddies father's shop and get started on installing my posi and 4.11s and swapping my flowtech shorties for hedman long tubes. he is a great guy and lets me use his hoist and what tools i dont have. i got the rear end drained and all ready for the new parts. i also got the old headers off.
tomorrow, he is gonna help install the new gears and posi, cause i really dont have any iddea how to setup the new gears properly. i cant wait to test out the new stuff at the track.
i am thinking i may upgrade to some drag radials or some M/T ET streets or ET drags. any thoughts on which a better? for the drag radials, the word seems to be that nittos last longer than the BFGs, but the BFGs hook better. as for the M/Ts....anyone know how much better the ET drags hook than the ET streets?
i dont mind swapping tires at the track, but i suppose swapping the tires at home right before heading to the track would eliminate having to take a jack and another set of tires to the track.
any info on the tire situation would be great.
Old Aug 28, 2003 | 11:57 PM
darbleinad's Avatar
Car: 84 Trans Am
well tonight i got the headers in. thank *** i had a hoist to use. with the plugs out, the drivers side goes in from the bottom with alittle twisting and encouragement and of course some swearing.
the drivers side is a whole different matter. get the plugs and wires out and way and then remove the starter and the belly pan/inspection pan (the pan the covers the flexplate and torque) converter. with this done, it is now somewhat possible to put the header in from the top. this will take alot of encouragement and a hell of alot of cursing. once you get it set in there, put the starter back on while you have a chance, because you wont be able to with the header bolted up. i had to clearance the edge of the starter around the outside bolt so that the header would sit in properly and allow me to bolt the header up. spark plug access is okay as long as you have an offset wrench, and i have the large 13/16 plugs.
Old Aug 29, 2003 | 01:00 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
so when should I drop my car off for you guys to put a pair of hedmans in for me?
Actually Id just like to see em on your car asap so I can decide if they're good for me or not. Got any free time?
Old Aug 29, 2003 | 06:18 PM
88 IROC BOB's Avatar
If you're going to swap tires at the track I'd go with the ET Streets. No real advantage to going with the Drags. The streets are plenty sticky. And if you're runnin at Sparta you know you need all the help you can get hooking up (especially with the 4.11's).
I have run Nitto's and can't consistenly hook with them. I've only been once with the streets and there is no problems.
I have 26x11.5x16 but probably could have gone with the 10.5's.
Bob
Old Aug 29, 2003 | 06:54 PM
darbleinad's Avatar
Car: 84 Trans Am
yeah man i will have the car in london as soon as it is done likely thursday. i will be free early thursday evening.
Old Aug 29, 2003 | 06:56 PM
darbleinad's Avatar
Car: 84 Trans Am
Bob
thanks for the help, Bob. what did those ET streets set you back? i would imagine the 15 inch ones are slightly cheaper.
Old Aug 29, 2003 | 07:19 PM
Yeah, I think the 15's are a bit cheaper. Mine were $400 US installed at Discount tire in Detroit.
If you're using the 15x7 camaro wheels I think I would use the 10.5's. The 11.5's might be too wide.
Bob
Old Aug 29, 2003 | 07:28 PM
darbleinad's Avatar
Car: 84 Trans Am
wow. i knew they were expensive, but holy ****. aww well, its worth it if it drops my ets. thanks again, Bob.
Old Aug 30, 2003 | 06:02 PM
No problem.
Not sure if you're near a US border.
I avoided all taxes by bringing over my rims with me and having the tires mounted over in the US. Came back across and told them I went to the strip. No problems. Saved me almost $100 tax (15% on Can$ value).
Bob
Old Aug 30, 2003 | 06:08 PM
darbleinad's Avatar
Car: 84 Trans Am
that is exactly what i had planned to do. save yourself tons of money.
Old Aug 30, 2003 | 07:02 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
I'm thinking I saw the 10.5" 's today for $157 in scoggin dicky catalog when I was just browsing...
Old Aug 30, 2003 | 07:03 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
and just to add a friend and I are planning on taking a trip to summit racing in a couple weeks...
Old Sep 2, 2003 | 06:30 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Bob
Your not kidding on that, Sparta's REAL bad for traction.
Old Sep 2, 2003 | 09:46 PM
darbleinad's Avatar
Car: 84 Trans Am
sparta is the worst track ever.
Justin,
when are you going to summit? could i tag along with some rims?
Old Sep 3, 2003 | 02:34 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Justin,
Possibly next weekend... just gotta see how my schedule works out but for sure you can come for the trip.
Old Sep 3, 2003 | 07:22 AM
darbleinad's Avatar
Car: 84 Trans Am
solid. let me know asap so i can modify the work schedule.
Old Sep 5, 2003 | 09:16 AM
darbleinad's Avatar
Car: 84 Trans Am
well gentlemen, i have a huge dumbass grin on face today, let me tell you.
i finished the mods on my car last night. feels great to be driving her again.
also........4.11s and a posi are (ala Will Ferril in Old School) AWESOME
anyway....the car is a blast to drive, plus i picked up a few ponies, via the long tubes and the addition of an h-pipe to my existing dual exhaust.
1984HO
Mar 19, 2021 11:59 AM
InfinityShade
Aug 22, 2015 08:00 PM
sreZ28
Aug 14, 2015 07:48 PM
mizz0313
Aug 12, 2015 06:45 AM
drathaar907
Aug 6, 2015 04:20 PM
