Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Race Car
Old Dec 4, 2004 | 02:08 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Race Car
Check this out. All the conversion work is already done. Not bad for 10K US only problem is I'd need a trailer and somewhere to store everything plus I don't think my V6 Ranger would have enough guts or brakes to haul it around.
1994 Formula
Suspension
Global West upper front control arms (installed winter ’03)
Ground Control spring height adjusters (600 front / 175 rear)
Extra springs 900 front / 225 rear
Bilstein shocks (fronts using Strano revalve)
LG Motorsports aluminum rod end panhard rod (new in box)
LG Motorsports aluminum rod end rear LCAs (installed winter ’03)
21mm rear swaybar (1LE)
35mm front sway bar (hollow Strano bar)
One of 2 sets wheels/tires will be sold with car for below price:
AFS (black) ZR1 style wheels 17x9.5” with Toyo RA1 275/40/17 tires (installed May ’04, used for 2 sessions)
AFS (black) ZR1 style wheels 17x11” with Goodyear ZRS tires 315/35/17 (installed Fall ’04)
Body and Chassis
C5 front brakes (spare set of rotors and Cobalt Friction GT VR pads)
Brake ducting
LG Motorsports subframe connectors
BMR shock tower brace
Rollcage done by Jim-Powski Racecraft (http://www.jim-powski.com/gallery.htm)
All safety equipment approved by NASA for American Iron for ’03 and ’04 season. Have logbook for Putnam Park race in May ’04 and Comp License school September ’03.
Corbeau Forza driver’s seat
Grant small diameter steering wheel
Battery mounted in passenger seat area
Fire system, out of car (have the tank and nozzles as well as activation cable, needs lines)
Fire extinguisher mounted on roll cage
Alan Blaine carbon fiber targa top to replace t-tops – bonded in place (installed winter ’03)
Percy’s Speedglass windshield - 3/16” thick (installed winter ’03)
VFN liftoff fiberglass hood (not painted or installed yet)
Factory hood was just removed this summer to remove engine and will come with the car
Front fascia has been opened up to allow front breather once tube front bumper is made
Transponder mounted (hardwired - installed winter ’03)
Factory t-tops and side windows are out of car but will come with it if wanted
Powertrain
Combination Motorsports 383 rotating assy (new in box)
Eagle crank
Eagle 6” rods
SRP pistons
Rings and bearings
LT1 block – bored .030” over, deck plate honed and line honed (machining currently being done)
2 bolt billet main caps (new in box)
Above engine parts are now with engine builder and work is continuing on building up short block. As work continues the asking price for the full combo goes up, unless the buyer is only interested in a roller and I sell the short block separately
All accessories and other engine parts removed from engine this summer (spun main bearing) will be provided with car if not bought as roller
Stock LT1 heads with EX612 Combination Motorsports valve springs, retainers, guideplates, etc. installed winter ’03 to go with XE224/230/112 camshaft. Springs are good to .600” lift.
Comp Cams pushrods
Spare LT1 short block (bought used for rebuild if needed)
SVO 30 lb/hr injectors (installed winter ’03)
52mm throttle body (installed winter ’03) – bored out new factory unit
Stock throttle body also available if wanted
SLP Jet Hot coated headers (Jet Hot 2000 in black)
Holley cold air intake
SLP throttle body air foil (bored out for 52mm tb)
Long air to oil cooler with Aeroquip steel braided lines (installed summer ’04)
BeCool radiator (installed winter ’03 along with new radiator hoses)
Spare water pump (used, but very low mileage)
Autometer oil temperature gage (installed summer ’04)
LG Motorsports underdrive pulley
Turn One reduced output power steering pump (installed winter ’03)
LS1 (aluminum) and factory LT1 (steel) driveshafts
Lou’s short shifter
T/A rear end girdle and stud mounting kit (not mounted yet)
Torsen T2R
3.73 gears
ECU currently programmed for XE224/230/112 cam with above fuel injectors. Made 340 RWHP on Mustang dyno at 5800 rpm.
Link to pictures of car Sept. ’03. ( http://home.comcast.net/~miketaylor68/GoinRacin.htm ) See above for what has changed since these pictures were taken.
Looking to get $5500 for the roller chassis and $6500 for everything I have as is. Until the car sells, work will continue on the car and it will likely be a track day car for me next year as I don’t see that I have the time to maintain and upgrade the car as needed for racing. I now have a 23 month old son and he’s my main interest. Maybe when he gets a little older . . .
As mentioned above, price for everything goes up as more work is done on the engine. Once engine is complete and back in the car in the spring I will be asking approximately $10,000 for the package (including upcoming ported heads and intake manifold for 383)
I do hope someone on this board will buy this car so it can be raced as it was intended. I'll miss it when it goes but it's time for me to do some other things in my life. Maybe when the '07 Camaro hits I might be a F-body owner again.
Email with any questions you may have at miketaylor68@comcast.net
http://frrax.com/rrforum/index.php?act=ST&f=6&t=3014&
Mike
'94 Formula
NASA AIX OH/IN region
Old Dec 4, 2004 | 03:50 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
George, you buy that car and a trailer for it and I'll put a hitch on my car and tow it :P Oh, but I get seat time too
Old Dec 4, 2004 | 06:25 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Lol.. Ok that's a deal.
It looks good with the 315s on all fours too. There's a GP on ZR1 rims at frrax that I was thinking about: two 9.5s and two 11s for about $550 shipped but there'd probably be difficulties with fitting 11s on the back of my car and I need to focus on getting a motor first. I like this car though and my wife thinks should buy it..lol. This car would solve a lot of problems. I wonder if it could be made street legal.
Old Dec 4, 2004 | 06:26 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Here's another:
Old Dec 4, 2004 | 08:49 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
After watching the AS race on speedvision this afternoon I often think I should have went the route of buying an already all out prepped car instead as well. Don't get me wrong, I love cruising and the whole fbody group scene but nothing beats racing in my blood.
That's awsome that your wife is saying buy it but I'm sure shes not thinking of the truck and trailer that must go with it as well eh. For sure it could be made street legal tho
Old Dec 14, 2004 | 11:50 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Thats not a bad price at all for all the owrk that has been done to it.
Old Dec 14, 2004 | 10:34 PM
Demon355's Avatar
Pretty cool. What's with the single exhuast though or am I seeing things.
Old Dec 15, 2004 | 06:01 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Nothing wrong with a single exhaust for that power output. Looks like it's about 2.5" and the car has no cat(s) as well. In racing you're better off running a cheap exhaust anyway as they tend to get ripped off the car.
Old Dec 15, 2004 | 08:07 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Yeah - the OEM style twin exhaust setups on our cars are sort of a crock IMO.
Since it's a single I-Pipe it would be better without all that bending that they have to go through to get the appearance of a dual system at the back of the car.
So, as far as I know, one pipe on the passenger side is actually a better system unless you have a true dual system.
Old Dec 15, 2004 | 11:17 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I run a single pipe on my 87. Three inch from y to tail pipe. The single outlet make more power than the crossflow style and who needs extra weight anyways?
Old Dec 15, 2004 | 11:28 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Something tells me you're going to be a problem next year..lol.
Terrell351
Jun 13, 2021 01:13 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
z28addict8490
Aug 7, 2015 08:48 PM
