Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
O2 sensor
Old May 16, 2006 | 10:43 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
O2 sensor
I just installed Edelbrock headers and have a problem.
The O2 sensor is located on the bottom of the header (driver side) instead of the top manifold close to the plug.
Since theres only a few inches of cable is there anything I can do to the cable like cut and use another wire to extend or is there an extension wire I can get?
Old May 17, 2006 | 11:27 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
If it was like mine they should have given you a small bit of wire with the appropriate ends on it to "extend" the wire. It was in with my "kit" many years ago.
DK
Old May 17, 2006 | 09:19 PM
transamice's Avatar
Car: 87 GTA t-top
I didnt get any extension, thats why Im asking to find out what I can do.
I called partsource to see if there is an option to buy such an extension and was told its just a wire, that I can cut the wire and use any wire to extend it.
Thing is Im not too sure if that will work...
Old May 18, 2006 | 12:39 AM
Eric2ndGen's Avatar
Splicing your own wire in will work- but you want to solder it and make sure the connections are weathertight (i.e. shrinkwrap or the like- not electrical tape). Voltage levels from 02 sensors are so small- any f-up in the connection will cause grief to the ECM/tuning. Call Edelbrock and see if maybe your box was mis-packed and there should have been an adapter/extension.
Old May 18, 2006 | 11:53 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
I am not 100% sure about this, but don't think splicing the actual O2 sensor wire is a good idea. I remember something about it being a special type of wire on some units that has something to do with the calibration of the unit. T
hat being said, just extend the factory harness, it is regular wire.
I have done LOTS of engine wiring and always use this method...always solder every connection, even in the weatherpacks. Along a wire for a splice coat the joint with RTV (silicon), then use shrink wrap over top to seal it. The RTV should squeeze out of the ends of the shrinkwrap.
I would get some high temp wire sheathing to cover it with and tie wrap the harness out of harms way as it will likely be in the airstream under the car now.
Old May 18, 2006 | 10:59 PM
Eric2ndGen's Avatar
I guess I should've mentioned to cut/splice the factory wire. Some 1-wire 02 sensor wires have some sort of thin heat shielding on them to protect the wire's internals from resistance buildup as temperature increases (most 3- and 4-wire sensors have a plug on them- no wires at all so you have to modify the car's wiring).
Old May 19, 2006 | 08:02 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
I would say just call Edelbrock...and say yoru kit didnt come with it...they should send you out one free if its a new kit, or if not I am sure they will send you out one of the leads for a minimal charge. I have heard something similar to 6-speed...probably best to jsut spend the couple $$ and be done with it...its also a hell o fa lot better than trying to splice and then shrink wrap down there.
DK
Old May 21, 2006 | 01:22 AM
transamice's Avatar
Car: 87 GTA t-top
I made a connetion from the sensor to the ecm wire, real ghetto for now but not throwing codes for o2 sensor.
Car runs like crap, engine shakes bad and there seems to be less power, although Im getting a code 22 I wouldnt be suprised if the o2 signal is messed as well.
Old May 21, 2006 | 09:10 PM
Eric2ndGen's Avatar
If you only had stock manifolds on the engine before the headers- you need to re-tune everything and go from there.
Old Jun 27, 2006 | 03:27 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
when i installed my edelbrock headers, mine came with it so i would call edelbrock.
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
