Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
needed 350 block for rebuild
Old Apr 21, 2010 | 11:20 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
Machine shop says my block is toast. i need a block for rebuilding for my 1987 iroc tpi. i have crank rods pistons etc, just need block.
LMK must be 2bolt 1 peice rear main
Old Apr 27, 2010 | 10:08 PM
andyiroc88's Avatar
Car: 88 IROC
Engine: Stock 91 305 TPI
Transmission: world class t-5
Axle/Gears: 95 LT1 rear 3:23's
Re: needed 350 block for rebuild
I have some blocks. Where are you located and do you need a standard block, 30 over, 40 over etc.
Andy
Old Apr 27, 2010 | 10:19 PM
Car: IROC Z
Engine: 5.7
standard bore, passenger side dipstick, located in barrie. 4 bolt main is ok but has to be 1 peice rear main
lmk if you have and what you want for it.
Old Apr 28, 2010 | 07:27 PM
andyiroc88's Avatar
Car: 88 IROC
The only standard bore 1 piece block I have is a 4 bolt but I don't have the main caps for it.
Andy
Old Apr 28, 2010 | 10:02 PM
Car: IROC Z
Engine: 5.7
hm i have a guy im meeting with this friday with a block with endcaps. if it falls through ill let you know
just out of curiosity, what you want for it?
Old May 1, 2010 | 10:00 PM
andyiroc88's Avatar
Car: 88 IROC
PM sent
Old May 7, 2010 | 07:52 AM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I've got a 1978 high nickle block, just needed a hone and hot tank. I'll sell it with a complete overhaul kit for 650. 2 bolt main.
Old May 7, 2010 | 08:25 AM
Car: IROC Z
Engine: 5.7
found a block. thanks all who helped
IROCZ1989
Jan 24, 2016 03:55 PM
Reborn756
Sep 4, 2015 03:42 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
BBSDesigns
Aug 11, 2015 07:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
