Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
car doesnt start!!! why??? help!...
Old Sep 3, 2001 | 01:33 PM
liquidinferno's Avatar
the lights turn on... so i dont think its the battery...
89 IROC-Z 5.7L
bone stock for now...
Old Sep 3, 2001 | 02:26 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Does it crank(turnover)?
92Z28
89GTA
Old Sep 3, 2001 | 04:30 PM
no... its starts most of the time... but other times it doesnt work at all... the light all work so i know its not the battery so what could it be? the starter was just recently rebuilt could that be why?
89 IROC-Z 5.7L
Old Sep 3, 2001 | 08:00 PM
trigger GTA's Avatar
Car: 92 TA vert
help us help you man. more info. whats the car doing or not doing the more info the better to help you with.
Old Sep 3, 2001 | 10:22 PM
Paul_Hughes_87 T/A's Avatar
Car: Chrysler 300c
Engine: 5.7L Hemi
Transmission: 5spd auto
Axle/Gears: 2.89
are you paying your girlfriend cash or check?
Old Sep 4, 2001 | 12:28 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
<font face="Verdana, Arial" size="2">Originally posted by Paul_Hughes_87 T/A:
are you paying your girlfriend cash or check?</font>
Uh-ohhhhh, lol........ I remember when I got my first car. It was a 1977 SE Trans Am. That first summer was full of trips to the parts store, and the bank
92Z28
89GTA
Old Sep 4, 2001 | 09:03 AM
well that doesnt count till i get my car on the road... im just tryin to fix everything before i start drivin it... cuz it aint got no plates...
-more info???
all i know is the car is all fine except for that problem... it starts 99% of the time but now and then it doesnt wanna start... all the electrical **** works but the engine DOESNT turnover... the fan comes on and all the lights work but i dunno... maybe bad wireing to the starter?
89 IROC-Z 5.7L
Old Sep 4, 2001 | 10:48 AM
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
GREMLINS
Old Sep 4, 2001 | 01:01 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
GREMLINS</font>
Sounds like Leprechauns to me Actually you may want to check the starter solonoid.
92Z28
89GTA
Old Sep 4, 2001 | 02:46 PM
what the POO is that!?
89 IROC-Z 5.7L
Old Sep 4, 2001 | 03:38 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
Does your car have VATS?(not sure if it was available in '89) If you have a chip key then your car has the Vehicle Anti Theft System. On occaision my car will refuse to start. When you go to turn on the car and it will not start, the security ligtht will stay on(Located on the instrument panel). This means that VATS has dissabled the ignition system for about 20 minutes.My car has done it twice, once my wife put the trunk key in the ingition and it refused to start, once it just wouldn't go. The resistors in the ignition and key will sometimes wear out causing this problem. You can bypass the system. If your car has VATS and you think this is the problem, do a search on the electrical board on how to bypass the system if you don't want to spend $400.00 bux to fix it.
1990 Iroc convertible,305 tpi,Black with black leather interior,lowered,Taylor 8mm wires,K&N's
Old Sep 4, 2001 | 04:52 PM
johnyIROC's Avatar
If it doesn't crank every now and then, it's something to do with your starter... either the solonoid is sticking, or you have a bad connection. If you can here it spinning inside the housing.. it is sticking.
Old Sep 4, 2001 | 09:19 PM
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
<font face="Verdana, Arial" size="2">Sounds like Leprechauns to me </font>
how did you know i was irish?
Old Sep 4, 2001 | 09:32 PM
Ratchet's Avatar
Sounds like a bad connection at the starter or even the battery. If it is not a bad connection at one of these places it could be a bad battery. Sometimes one of the plates will come loose when a battery gets old and it will lean over and short out on one of the others. Just getting in and out of the car could cause it to move. (it could happen) if not one of these it is probably a bad ignition switch.
White bone stock 87 RS
Old Sep 5, 2001 | 05:06 PM
Car: 92 TA vert
it sounds like your starter. next time it happens take a hammer and tap the starter with it. you mite have a dead spot in it. a very common problem with them. it could also be a bad ground that would let every thing work but under a large load (high curent)during starting become resistive and not start. however if it is this you should still get something when you try to start it. i would check the starter first
Old Sep 5, 2001 | 11:20 PM
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
if you cant do something simple like turn your headlights on then why would even think about starting the car
Old Sep 6, 2001 | 04:35 PM
Car: 92 TA vert
if you cant do something simple like turn your headlights on then why would even think about starting the car </font>
were did he say that his headlights would not work?????????
liquidinferno said in several post that the lights would turn on and the electrical sys. was working
never mind i just read his other post.
[This message has been edited by trigger GTA (edited September 06, 2001).]
Old Sep 6, 2001 | 04:50 PM
ihateallmustangs's Avatar
so you have no plates eh?..i guess those earlier posts about you cruisin around in your third gen were just made up..but then how can you cruise around in a third gen when you dont even know how to turn on your headlights
.......[i didnt know 3rd grade kids were members of thirdgen.org].......
Old Sep 6, 2001 | 07:14 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
UHHHHHHH-OOOOOOOOOHHHHH Maybe he was out touring with the old magical 10 day permit of happiness.
92Z28
89GTA
Old Sep 7, 2001 | 11:12 PM
mjdoyle's Avatar
Liquid, some advice to you... buy a hanes manual for your car and read... do not be afraid to attempt to do anything yourself on your car but please read as much as you can first...read the posts in other sections of this forum.. learn hw to describe your symptoms as accurately as you can.. Describing a problem very very accurately not only makes it easy for others to help you diagnose your problem it tells them that they can skip the basics and get technical.. for example saying:
"all i know is the car is all fine except for that problem... it starts 99% of the time but now and then it doesnt wanna start... all the electrical **** works but the engine DOESNT turnover... the fan comes on and all the lights work but i dunno... maybe bad wireing to the starter?"
say... im having intermittent starting problems.. the car normally starts fine but once in a while i will turn the key and hear a buzzing noise but the car doesnt start (solenoid)... or i turn the key and i get clicking noises (Battery?) or i turn the key and the power to everything goes off and i hear nothing at all(Short??) I checked the starter and the connections are clean(No corrosion (green) on the wires?) and the wire from the battery to the starter looks fine..(Not burnt on the manifold) i had the battery tested and it can handle a load fine(Wallyworld will do this for free!!)
Search the site.. get a haynes manual and look up your symptoms in the trouble shooting section.. do all the obvious first and then ask for help with informed questions... Learning about these things at first isnt easy but take this approach and in a few years you'll be on here answering questions..
Just my advice to you..
Keep the Shiny side Up
Mike
Mike
88 Iroc-Z 350 tpi, Hedmann Headers, 3" Cat Back, MSD Ignition, K&N, AirFoil
Old Sep 7, 2001 | 11:21 PM
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
good advice Mike but the cars for sale now.
Old Sep 8, 2001 | 12:08 AM
mjdoyle's Avatar
Well the advice will still hold for any other newbie to this forum or to cars in general.... weve all been there and were all thinking the same thing... "my dad (or brother or uncle or fill in the blank) must have thought i was an idiot, i pray that i was never that naive" weve all done stupid things and learned from them, a lot of people have helped us along the way and we need to do the same....
I am a backyard mechanic... and we rock..
Hey its the beer :P
Old Sep 8, 2001 | 11:32 PM
no when i was cruisin i was cruisin in my moms blazer... and i dont have plates only a temp permit!
89 IROC-Z 5.7L
Old Sep 8, 2001 | 11:37 PM
hope fully in a year or 2 ill buy another one with less miles on it... cuz the insurance it too much right now... so i gotta sell it... and the frame ( i just noticed) needs new patching up...oh yeah and i already got $200 of tickets too! young males + fast cars = police trouble
89 IROC-Z 5.7L
Old Sep 9, 2001 | 01:17 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
<font face="Verdana, Arial" size="2">Originally posted by liquidinferno:
</font>
I have an equation for ya.....young males + made up stories = annoying. Sorry but I think we are all thinking this, but I could be mistaken
92Z28
89GTA
[This message has been edited by Acceld Z (edited September 08, 2001).]
Old Sep 9, 2001 | 04:21 PM
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
im 20 and have a fsat car and no police problems
Old Sep 10, 2001 | 12:01 AM
johnyIROC's Avatar
I'm 23, and I've been clean for two years (other than a tint ticket.. but that's just a tax for being cool).
johnyIROC 1983 Z28
"5.0 is way too slow"
Old Sep 10, 2001 | 07:35 PM
CobraKiller's Avatar
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
You may want to check for carbon buildup in the throttle plate. I had this happen to me and the car wouldn't want to start every now and then.
"Turn a 12 second dream into a 10 second reality"
Old Sep 10, 2001 | 09:33 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I'm wondering if Inferno isn't just some one line joker who gets a laugh out of posting questions about things like not being able to find the light switch in a vehicle with a generally standarized instrument layout. No one is that green.
I was going faster than I'd ever gone before but then I fell off.
Old Sep 10, 2001 | 10:41 PM
mjdoyle's Avatar
If not he's the most mechanically declined person the world's ever seen.. man.. how do i turn the lights on... give me a break!
Old Sep 10, 2001 | 10:46 PM
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
come on everybody we all know a blazer is a fast car and young men + blazers = police trouble.
Old Sep 11, 2001 | 08:33 PM
mjdoyle's Avatar
hehehe!
Old Sep 11, 2001 | 09:22 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
blazer? Anyways, I think this kids a troll.
92Z28
89GTA
Old Sep 13, 2001 | 02:12 AM
rezinn's Avatar
I'd like to thank you guys for amusing me in such a sad time.
Hey liquid, how did you notice the frame "needs new patching up"? Just cruisin around?
Old Sep 13, 2001 | 03:32 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
You are quite welcome
92Z28
89GTA
Old Sep 13, 2001 | 05:58 PM
karstenkurtz's Avatar
I don't find that hard to belive about the tickets.. In the first 4 hours of having my IROC on the road after this winter when I picked it up from high tech racing I racked myself up a $170 ticket and a $110 ticket. One week after that I got another $110 ticket. Then things died down for almost a month until I got yet another $110 ticket. Then I lasted almost two months until getting nailed going 100 in a 60 then 11 days later I got nailed doing 90 in a 60. The 100 in a 60 I got off by some miracle with just a warning but then next one for 90 in a 60 I got a $40 ticket because he reduced it. I'm 19, I drive a black 12 second iroc, and I talk to a lot of cops
Karsten
86 IROC-ZZ4... too much to list.
Old Sep 13, 2001 | 10:57 PM
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
i think we scared liquid off
Old Sep 16, 2001 | 11:20 AM
but none of you look like your 12!
Old Sep 16, 2001 | 11:27 AM
and about the rust... i didnt check it very carefully for rust before i bought her... there was one patch of rust on the floorpan and a spot behind the front right wheel... and the tickets were for not having insurnace and not haveing registration papers... and about the lights, i thought it was a button not a pulling thing... hope that explains everything...
89 IROC-Z 5.7L
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 8, 2015 12:07 PM
L98GTA87
Aug 5, 2015 11:02 PM
