Ford SVO injectors?
Old Apr 19, 2002 | 12:28 AM
jaycee's Avatar
Ford SVO injectors?
I just received my SVO 24# injectors from Summit. I had heard multiple times they would fit my 5.7L TPI. After comparing them to my old injectors I noticed that they are about 1/4" shorter and the locking clip groove at the top of the injector doesn't go completely around the injector. While these injectors fasten to my fuel rail and fit in deep enough into the manifold so they don't leak vacuum?
Old Apr 19, 2002 | 12:47 AM
Eighty5TransAm's Avatar
Hey, long time no see. did you ever get the bugs worked out of your car? I hope so, it should be fast now Ive got a whole new drivetrain in mine since that day at HPT including 30# svo's no leaks.
Old Apr 19, 2002 | 07:35 AM
BitchinCamaro's Avatar
I am running svo 24# and haven't had any problems, sealed up fine.
Old Apr 19, 2002 | 12:09 PM
Tyler-88's Avatar
i read a post about putting rubber washers with the injectors so they seal better.
Old Apr 21, 2002 | 03:45 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Yep, my 30# SVOs fit fine and don't leak.
Old Apr 21, 2002 | 09:45 PM
IROCThree8Three's Avatar
I had the same question, didnt put them in for a couple of days because i was so stressed, but they ended up sealing perfectly.
Old Apr 21, 2002 | 10:43 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Yep, theyll work just fine the way they are.
Old Apr 21, 2002 | 11:04 PM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
I'm using the Motorsport 19lb/hr injectors on my mildly modified '87 LB9 305. They have almost 15,000 miles already, and work great!
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
92-Formula
Dec 12, 2015 10:34 PM
webeeZ28
Sep 14, 2015 12:00 PM
