Hydraulic lifter question
Old Apr 25, 2002 | 02:16 PM
89Irocker's Avatar
How can I find out if my engine has hydraulic lifters or not?
Old Apr 25, 2002 | 02:43 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
If it's the stock motor you can look up the specs for that year; the engine code is under the consol lid with other RPO codes.
I believe '89 F-bodiy LB9 & L98 had hydraulic roller lifters with roller rockers too.
Old Apr 25, 2002 | 02:47 PM
89Irocker's Avatar
Thanks for the info
Old Apr 25, 2002 | 02:48 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
all TPI's from 87 - 92 had roller cams with hydro roller lifters..
all have standard ball/rocker arms.
Old Apr 25, 2002 | 07:50 PM
z rider's Avatar
yo i put some hydraulic lifters on my 74 caddy, it was hoppin like a ****. Then your momz jumped in and did some more hydraulicin'. Now i'm doing a camaro RS with a TURBO!!!!!
Old Apr 25, 2002 | 09:34 PM
Swapmaster's Avatar
Your engine will have hydraulic rollers in it.
Old Apr 25, 2002 | 09:44 PM
Bort62's Avatar
__________________
I can do this sometimes
________________________________ _ _ _ <chirp>___
Ahh!
l33t!
Solid lifters havent really been used in factory equipment since the early 60's to the best of my knowledge.
Old Apr 25, 2002 | 10:05 PM
Swapmaster's Avatar
The last engine with solids was the 70 Camaro Z-28.
Mickeyruder
Sep 2, 2015 02:45 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Cameeeero
Aug 20, 2015 03:06 AM
redmaroz
Aug 16, 2015 11:40 PM
