Free mods.... Which to do, Which to leave out
Old May 9, 2002 | 11:56 PM
iroc_cragg's Avatar
Hey
I have seen that alot of people have cut down the 1/4 mile times by .4 to .8 seconds with the free mods. I am looking to cut some time of my 1/4 mile. Which free mods should I consider doing. Which free mods work the best without screwing somthing up in my car. Which free mods should I say aways from totally.
http://camaroz28.cardomain.com/id/56424
Old May 10, 2002 | 01:41 AM
Bort62's Avatar
Don't Gut your MAF.
Old May 10, 2002 | 01:22 PM
TBurke's Avatar
Cut the bottom of the air filter housings out.
Old May 10, 2002 | 02:00 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Originally posted by Bort62
Don't Gut your MAF.
I second that. You can remove the screens, at least the one on the engine side (why it's there I could never figure out), with out affecting it. But I always felt that there was a reason that Bosch put those heatsinks in the MAF. And if you slip even once and cut the hot wire you're screwed.
Old May 10, 2002 | 09:32 PM
BOTTLEDZ28's Avatar
Transmission: A4
1. cut air boxes
2. grind down the casting walls in the plenum.
3. advance timing a bit 10 degrees BTDC
4. remove front sway bar( track only!!!!!)
5. better yourself at the track with your car. being consistant helps. your car might run 14.2 all day long. give it Even Smith and he will run 13.8 with it. its all on how you drive
Old May 13, 2002 | 10:13 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
There is also the TB coolant bypass. It cuts off the coolant from running through the TB.. therefore not heating the air. It should be in the tech articles.
Old May 13, 2002 | 12:58 PM
johndo1707's Avatar
what does taking the front sway bar off accomplish?
Old May 13, 2002 | 01:16 PM
TBurke's Avatar
It helps with weight transfer. Allowing the front end to rise planting more weight on the rear tires. this should help with traction. Also, it drops about 30 to 40 lbs of weight off the front end.
Also, any other weight removed will help et.s . Drop the spare and jack/ extra stereo equipment. If your A/C doesn't work anymore remove it/Smog pump(if you want to get away with this).
You can drop a good amount of weight. Also, for the track if you can get some light "skinny : front rims slash tires it will help.
Old May 13, 2002 | 01:32 PM
Omega's Avatar
Engine: LS1 / LS3
Taking the front sway bar off allows faster weight transfer to the rear wheels, therefore better traction (plus a little weight reduction at the same time) This is mainly used in drag racing only. I don't recomend taking it of when a draily driver.
Old May 13, 2002 | 01:47 PM
johndo1707's Avatar
yeah, thats waht i thought it was for, didnt think the think weighs that much,lol
Old May 13, 2002 | 05:09 PM
5SIZ's Avatar
Car: 1987 IROC-Z
Where the TB meets the plenum, there is a bit of restriction there, you can grind down the restrictions to get better flow, as well as port the plenum, runners, and siamese the base 2 inches in. Make that baby breath
Make a ram air setup, it's not free but it'll only take about 20 bucks out of your pocket.
Old May 14, 2002 | 07:44 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Transmission: rebuilt 700R4
Originally posted by BOTTLEDZr28
1. cut air boxes
That Evan Smith is a BAD ****.
Old May 14, 2002 | 10:07 PM
realfst383's Avatar
Just be SURE when you cut the bottoms out of your air boxes that you dont cut the lip in which your filters sit. I've seen that done WAY too many times.....
Old May 14, 2002 | 10:17 PM
bigals87z28's Avatar
Car: Check The Sig
what is a good tool to grind down the walls in the plenium? will a dremel do?... aight peace
Old May 15, 2002 | 01:20 AM
5SIZ's Avatar
Car: 1987 IROC-Z
A dremel tool will work fine
just get good tips
Old May 15, 2002 | 06:57 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
DP
Old May 15, 2002 | 06:59 AM
Car: 1988 IROC-Z
i did the i the air box gut and boy does it help out alot. i picked some power up top(w/K&N's). does that tb bypass really help??? or it helps theorectically? i've been thinking about doing it but i dunno..?
Old May 15, 2002 | 06:00 PM
ir0cz's Avatar
Car: '89 RS
Engine: 9C1 w/ TPI
Why not do it anyways....it couldnt' hurt anything....if you do it and get some power...great, if you do it and dont gain any power, oh well, you haven't lost anything....the only purpose of the coolant running through the TB is to keep the blades from freezing...and you live in TX, so you dont have to worry about it.
PurelyPMD
May 5, 2016 04:57 PM
gta892000
Sep 16, 2015 12:37 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
TheExaminer
Sep 7, 2015 08:34 AM
masonta
Sep 1, 2015 06:40 PM
