ZZ9 cam in L98
Old May 15, 2002 | 01:15 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
ZZ9 cam in L98
Anybody got any specs or hp/trq ratings with this combo. I just got a L98 with this cam in it. Don't know much about what kinda numbers it can put out or if it is a good cam or not. Thanks.
Old May 15, 2002 | 01:22 PM
tpi_roc's Avatar
If i recall thats a fairly heavy cam, which would be out of place in an otherwise stock engine.
If you got a cam made to flow and an intake/exhaust that isn't you're not helping anything out, in fact only decreasing performance in the ranges the engine used to have at least a little bit of pickup.
Old May 15, 2002 | 01:27 PM
eatmydust's Avatar
Car: 1986 IROC-Z28
I'm getting headers, new high flow cat and cat back. The guy I bought from said he had some work done to the heads also. That should make a difference right?
Old May 15, 2002 | 01:29 PM
tpi_roc's Avatar
Should
Work lots on the intake too, if not going aftermarket
Jorlain
Oct 8, 2015 01:57 AM
scottmoyer
Sep 7, 2015 07:06 PM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
masonta
Sep 1, 2015 06:40 PM
