7k to spend give me ideas
Old Jun 10, 2002 | 01:35 PM
SuperChevy's Avatar
alright my friend is giving me 7k spend on my car, i know what a great friend! anyways i have a near stock 88 350 tuned port iroc, im lookin at gettin spohn for suspension parts and possibly a rebuild on my tranny from pro-built becasue i've heard good things from them. but not sure on heads intake cam yadda yadda yadda so give me ideas on what else you think i should get and keep in mind this has to include labor im not that mechanically inclined to do this myself.
Old Jun 10, 2002 | 01:38 PM
86305's Avatar
Just get a crate motor.
Old Jun 10, 2002 | 02:41 PM
87transam5.7tpi's Avatar
man I want a friend like that. :-) no but seriously now, get a 4bolt main block. and get all forged rotating assembly and aluminum heads, and roller cam, and everything else.
Old Jun 10, 2002 | 03:46 PM
SuperChevy's Avatar
actually im not lookin into a crate engine im more into all the small details such as suspension but im looking at an aftermarket intake heads and cam but thats about it for the engine im more focused on rear end transmission suspension etc.
Old Jun 10, 2002 | 04:15 PM
IROCKER's Avatar
I would suggest some along the lines of an engine rebuild using a LT4 hot cam, 1.6 rockers and LT4 springs, Vortec heads, and something like a Superram or Miniram. This is just somethings I would like to do, but unfortunately I don't have any friends with that kinda money right now. Good luck though.
Old Jun 10, 2002 | 04:27 PM
AlexJH's Avatar
Engine: 5.7L V8
What do you want to do with this car? Drag, autocross, roadrace? There's some things that will help all of these (heads, cam, exhaust), but for suspension upgrades you'll need to make some compromises.
Old Jun 10, 2002 | 06:22 PM
TransAm87's Avatar
Heads, headers, cam, supercharger!!
Aj
Old Jun 10, 2002 | 10:09 PM
formula4dissent's Avatar
Buy a LS1 and T-56 and drop it in.
Old Jun 10, 2002 | 10:36 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Since you're not doing the labor, I'll assume you're not burning your own chips, making any kind of custom cold-air intake, or porting anything. Based on that and the money...here's what I'd do.
1)Take the stock heads and get them heavily ported (there's 2 posts around here about a guy who did amazing things with stock heads for less than new aftermarket)
2)Get a junkyard base & a set of SLP or ASM runners (I forget which have larger bores)....get the base siamesed about 3 inches in and then siamese your runners. Gasket match these runners to the plenum and siames it. Then fully port that plenum out.
3)Get the LT4 Hotcam and the 1.6 roller rockers.
4)Pick up a set of Hooker Longtube Headers, a CATCO hi-flo cat, and a Hooker Cat-back.
5)Pay someone to cut out the areas under your filters
6)Maybe toss in a 383 stroker kit from Eagle
7)Do all those suspension upgrades you think you'll need
8)Full MSD ignition with cap/rotor/wires
9)Set of AC Delco plugs
10)Take your car to Ed Wright at www.Fastchips.com and have him tune it for you on the dyno. This'll set you back $800 but is well worth it. (You'll need it with all these mods!)
11)pay somebody to polish your plenum and runners
WITH ALL OF THESE MODS YOU MUST START WITH:
A good set of Sub-frame connectors. These are a must-have item.
You'll probably out of money by now. But have fun with that torque monster.
Old Jun 11, 2002 | 10:01 AM
SuperChevy's Avatar
would the miniram bolt up to vortec heads? and yes im looking for a daily driven but mostly street racin drag racing kinda car.
Old Jun 11, 2002 | 10:04 AM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
Wish I had 7 grand to just "spend"
Old Jun 11, 2002 | 10:16 AM
tpi_roc's Avatar
Whatever you're doing make sure that car ends up with a T56 and some turbos
Old Jun 12, 2002 | 09:44 AM
Beefy89's Avatar
Amen brother!!!!!!!!!!!
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
mdtoren
Aug 23, 2015 12:52 PM
NinjaNife
Aug 23, 2015 11:49 AM
86IROC112
Aug 21, 2015 07:20 PM
mdtoren
Aug 16, 2015 05:45 PM
