What oil is best in my car???
could you guys tell me what oils you use in your cars?? i was going to run mobil 1 synthetic but damn its expensive!! so i was wondering what oil you guys use and what wieght oil, also what brand oil filter, i have always used FRAM but ive heard bad things about them........Thanks -Don
let me the first to say this here.....USE ANY BRAND NAME OIL AND AN ACDELCO FILTER AND CHANGE IT EVERY 3000 Miles and you should be set for over 150,000 miles....
I use 10w-30 Castrol GTX in the summer and 5w-30 Castrol GTX in the winter. JUST CHANGE YOUR OIL AND FILTER EVERY 3000 miles......I can't stress that enough.
I use 10w-30 Castrol GTX in the summer and 5w-30 Castrol GTX in the winter. JUST CHANGE YOUR OIL AND FILTER EVERY 3000 miles......I can't stress that enough. Basically keep chaning oil in filter, or in my case (b/c i am an AMSOIL dealer) I run amsoil 10w-40, and SDF-25 heavy duty filter, and that oil will last me all summer, no need about changing it all, oil pressure is great, amsoil is the way to go..i use it for everthing, tranny, rear end, 2 cycle, its great, you can go longer on it if you just change the filter
Aj
Aj
I put mobile 1 synthetic 5w-30 in my 92 Z when I first got the car, it had 76,000 miles on it then. Now it has 147,000 miles and still runs strong and no smoke from the motor.
I have run it down the drag strip about 80 time in the last 3 years also.
I do change the oil and filter every 3000 to 3500 miles.
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
i did use mobil 1 10w30 for time and it worked great but now my dad is an amsoil dealer also so he forced me to use the 10w40 high performance oil
it is a very good oil and for the price ( i get it for wholesale ) it is great
I'll have to agree, Mobile 1 synthetic is the way to go. I use 10w-30 in the summer and 5w-30 in the winter and change my filter about every 100o miles and change the oil about every 4000 miles. I use a ACDelco filter, STAY AWAY FROM pensoil and valvoline TRUST ME
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
Originally posted by Don_89Iroc
you guys talked me into it what do i have to do to change my car over to synthetic oil from regular???
just change your filter
Car: 87 IROC
Transmission: 5spd
Originally posted by BD3
If you start to notice oil leaks go back to what you were using.Mobil 1 will break down any build up that might have been preventing leaks.
BD3
BD3
if you have proof for what you say let me know i would like to read up on it.
i still say if it leaks you had problems before. i mean the only place for it to leak is front and rear main seals which have the crank rotating in it so there is no way for something to build up. then the oil pan gasket which is rubber and reuseable so there is no reason why it would let something build up since if it leaks then its a bad gasket anyways since its rubber. same for the rocker arm cover gaskets. then you just have the timing chain cover which seals well anyways and some use rtv sealant and if it leaks its because it wasn't put on correctly just like the front and rear of the intake. then the intake gaskets but they have vaccume on them so stuff can't clog them and the the head gaskets have pressure on them so that nothing will build up there because you'll blow a gasket before the oil will seal anything.
Andrew
yep...i put in 15w-50 Moble 1 to help stop oil conusuption and the oil that did consume wouldbe less visable...this was on a BEAT 130,000 miles engine.....BEAT....i had the money and i put it in a just kept adding oil as it used it for about 3 months. Now the trans went as per sig.....(i take car of good cars the way they should be.....see my first post above)
Synthetics supposedly use stronger/more detergents. They're great for removing gum/gunk from your engine but at the same time that gum/gunk can be around the inner edges of your gaskets, when thats broken down if you have small or possible leaks they're now alot more likely to be externally visible.
If you're positive your gaskets are 100% sealed synthetics are the way to go.
I USE MOBIL 1 IN MY 1991 FORMULA 350, AND FRAM SURE GRIP OIL FILTER. EVERY 3000 MILES, NOT 6000 MILES AS MOST OF OUR BOOKS SAY. I USE MOBIL 1 BECAUSE THATS WHAT GM CARS USE I BELIEVE. MY DADS 2000 MALIBU CAME WITH MOBIL 1 IN IT AND HAD A STICKER SAYING USE MOBIL 1 PRODUCTS.
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
You can get a 5 gallon jug of Mobil 1 at Wal-Mart for $17.88. IMO, that's not all that expensive.
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I had heard the same thing about synthetic oil causing leaks in older engines and thought that was a bunch of crap . But my brother has a 1967 Charger and he was going to change the oil and I told him he should get the Mobil 1 because of it being an older motor that it might help it last longer . Well I dont know where it leaked from , probably the main seals , but it definetly caused it to leak oil ! He was pretty pissed because he is a penny pincher and it killed him to spend the extra money on the Mobil 1 just to have it cause leaks . We are talking about a 1967 engine though , the car is not an old junker , it is in excellent condition but the engine has never been rebuilt to our knowledge so these seals are OLD . I have run the Mobil 1 and Amsoil in my 1990 GTA with no problems , the last few oil changes I have used the straight 50 weight Valvoline Racing oil because with the heat here in Florida when my temp. gauge climbs my oil pressure gauge drops .
Engine: Inline 6
Axle/Gears: 3.13
Thats correct, synthetic oil has caused oil leaks in higher mileage motors that were not already accustomed to it when it had low miles.
Yea, I put Mobile1 in my wifes truck with 140k on it and it leaked like a sieve after a while. Kept filling it with the Mobile1 and it
finaly quit leaking and has stayed full for several months now.
That's what I was told it would do. Cause leaks from the cleaning
action then quit leaking after it softened the seals and gaskets
back up.
back up.
Engine: Inline 6
Axle/Gears: 3.13
I would try STP oil treatment for any first timers in high mileage motors for atleast the first 3 oil changes and then you can just you the synthetic with out the oil treatment. The stuff is only $3 so I would give it a shot to save hassles from leaks. It may or may not help.
Originally posted by derfrank
Tell me which wal-mart cause I'll be buying from them. I can't get a case for less than $30 around here in baltimore.
Car: 79 Monte Carlo
Engine: 406
Transmission: 2004-R
Axle/Gears: Phord 9 inch/3.90
First off:
The argument about the price of Mobil 1 oil. One guy is obviously talking synthetic and the other one isnt.
Second:
I will NEVER use a Fram oil or air filter. Any oil filters that come from the factory with paint flakes all over and in them are not going in my expensive motors. Now, about the Fram air filters. My buddy that races cars had his Fram(used in a pinch) come apart and cost him a race. When they pulled off the outerwear, the filter completely came undone, and it looked like someone stuffed it full of cotton.
:hail: Mobil oil with Wix or K&N filter
Second:
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Castrol 20W-50 for me in the summer, then come winter i'll use 10W-30
that's oil the motor has seen since the day it was rebuilt and will continue to see until someone proves to me that Mobil 1 is really worth it(ain't gonna happen, i know someone that wiped out 2 cams using mobil 1 in a TTA motor, went to castrol, hasn't wiped one out since)
all i can say is that if gm recommends mobil 1 on newer cars, then i am going to use it in my motor.
i dont think motor oil would have anything to do with motor's breaking, especially from mobil 1 to castrol, just bad luck i guess.
Hi,
I'm new here. I was just browsing and saw this thread so I thought I'd share my info about oil filters. The links below compare brands of oil and filters.
http://subtopics.freeyellow.com/Oil.htm
http://www.frankhunt.com/FRANK/corve...lterstudy.html
http://www.mbmopar.com/Hot_Topics/hot_topics.htm
http://www.89tta.com/oilfilter.htm
http://www.tech2tech.net/library/General/oilfiltr.htm
http://www.shotimes.com/SHO3oilfilter.html
http://www.mr2.com/TEXT/oil_filter_test.html
http://www.forums.vmag.com/suvmonter...ages/1941.html
http://www.go-synthetic.com/compare_...mpare_oils.htm
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
I second Fred91TA.... you can get a 5 quart jug of Mobil 1 at Walmart for like $17. Good deal if u ask me... that means you buy that and the oil filter for $3 and your grand total for a synthetic oil change is $20.... not to bad!
maroe624
Apr 16, 2017 08:29 AM
