Vortech Heads, Cam?
Old Jun 26, 2002 | 11:45 PM
89_RS_Mike's Avatar
Vortech Heads, Cam?
What cam is everyone finding to work best with the vortech heads? It will be put in a daily driven 305 TPI 5spd with SLP runners, vortech base/heads and full hooker exhaust
Also can you just add new valve springs to get more lift or do you have to machine the heads to get them to fit?
Old Jun 27, 2002 | 01:16 PM
tpi_roc's Avatar
I believe 3.8TransAm is running a hot cam vortec heads and Scoogin base with good results
Old Jun 27, 2002 | 01:54 PM
BP89IROC's Avatar
Is there an official lift number on the vortec heads?
Old Jun 27, 2002 | 06:00 PM
89_RS_Mike's Avatar
At sdpc2000.com it says .450" lift for the vortech heads. They also say they sell ones with more lift but you have to phone for details.
I was wanting to run the hotcam but it needs .525" lift with 1.6 rocker arms. I think I'll contact them and see about the Vortechs with more lift.
TPI_ROC is 3.8TransAm running a 305 or 350?
Old Jun 27, 2002 | 06:48 PM
tpi_roc's Avatar
well he would be the appropriate person to talk to...
But its a 350
Old Jun 27, 2002 | 10:21 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
You need to machine the valve guide diameter and height to run more then .450 lift with the Vortec heads. The diameter needs to be machined to allow the use of aftermarket springs that can operate with more then .500 lift. If you don't machine the guide diameter the spring dampers will bind on the guide and fail. The guide heights need to be machined to make sure you don't have retainer to guide interfearance.
Old Jun 28, 2002 | 01:51 PM
iroc22's Avatar
The Ram Jet crate motor uses 99 L31 springs and I'm pretty sure the Vortecs are completely stock 99 castings. And it has .490" lift.
Old Jun 28, 2002 | 06:18 PM
89_RS_Mike's Avatar
Bjankuski how much did it cost to have the machining done to your heads? Also did you have a custom chip burned for that cam when you made that run in your sig or is it on the stock chip?
Old Jun 28, 2002 | 09:23 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I don't know what the machining cost was because I bought the heads with the machining already complete. The run in my sig was with a custom chip but the stock chip was almost perfect to start with. The custom chip only picked me up 4 HP over the stock chip. The ET and MPH in my sig was with the stock chip.
Mickeyruder
Sep 2, 2015 02:45 PM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
