TPI questions
Old Jun 21, 2002 | 06:04 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
TPI questions
ok here is the deal I have an 84 Z and want to convert it into a TPI set up I would like to put a 350 in it. so naturaally I have some questions that need answered.
1. my speedo is cable driven, what all needs done to make it work with the cable? and will my cruise still work?
2. what all will need done with the wiring? just the engine comprtment or is there more that I need to change? is there a big bulkhead connector that I can just change the under hood harness?
3. will my AC still work ?
4. I have an auot trans and I was wondering what all needs done to make it work propperly with the new set up?
thyank you in advance for the help any would be greatly appriciated
I just want the all mighyt TPI :hail: but I dont want to get another car
Old Jun 22, 2002 | 07:35 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Re: TPI questions
Depends what year TPI system I guess. Later TPI used a VSS or Vehicle speed sensor to tell the ECM how fast the car is going. I have a 92 speed density in my 89 RS which uses a mechanical speedo. I have a dual VSS sensor on the tranny, sends the signal to the ecm and has a hook up for mechanical cable. Don't remember were I bought it.
Several companies make harnesses. Painless sells a stand alone. Other companies can make you a custom harness that will plug into your existing stuff.
Sure, as long as you get the brackets for the TPI set up.
What kinda tranny do you have? TPI ecm will be looking for a lock up torque converter.
Check the tech articles and study them. This will help you come up with more defined questions.
I wouldn't call it "all mighty". It's a decent system.
Old Jun 22, 2002 | 09:45 AM
jd13's Avatar
Sorry this is off topic.
Rob P, I noticed you had the SLP cold air intake. Do you think it was worth the money? Any gains?
Old Jun 22, 2002 | 06:01 PM
meridius's Avatar
I like the system and I would like to know how hard it is to convert my car into it again thanks for any help guys
Old Jun 22, 2002 | 06:33 PM
Rob P's Avatar
Engine: ZZ4TPI
No, I cannot claim any gains. I did have a homemade cold air, 3inch pvc with a K&N filter under the driver side battery box. The SLP seems much neater and I only paid like $100 for it used. I like neat.
Old Jun 22, 2002 | 10:17 PM
Morley's Avatar
Re: TPI questions
Nothing
Yes, might have to mod and or reroute the cruise cable though.
You'll have to remove all the wiring associated with the ECM. Best bet is to start at the ECM and work your way towards the engine bay. There is a large bulkhead connector on the pass side that it will all go through. Good luck getting a GM harness cheaply though.
Yes. if you wire it all up with the new harness.
You should have a 700R4 so all you'd need to do is connect the harness connector to the trans.
Old Jun 23, 2002 | 10:56 AM
meridius's Avatar
thank you morley for the help, my main concearn was the cable driven speedo I thought the TPI computers were all set up for an electronic spooedo set up I just dont want a check engine light because it isnt getting a speed signal again thanks for the help
Old Jun 23, 2002 | 12:01 PM
Morley's Avatar
Not all, just the later ones.
Old Jun 23, 2002 | 06:47 PM
lopoetve's Avatar
Do you know what year started that? I have a 87 TPI with the speedo dead and the ECM throwing a code 24 (VSS toast).
Old Jun 23, 2002 | 07:52 PM
meridius's Avatar
ok now I would like suggestions as to what year of a donor car I should get that will give me the least amount of hassle, I know I am full of stupid questions but I am not sure what will happen when I go to do this thank you once again
Old Jun 23, 2002 | 09:26 PM
Morley's Avatar
Your 87 should be mechanical, the VSS signal is dead because it mounts behind the speedo and "counts" the revolutions of the speedo head. If your cable broke your speedo and VSS would both be dead.
Old Jun 23, 2002 | 09:29 PM
Morley's Avatar
If you can get a 90+ speed density system that would be best, BUT you will need a custom prom to disable VATS (or know what value resistor you need to bypass it)
Other than that, go for an 86-89 MAF system, the parts are plentiful and no VATS.
Old Jun 23, 2002 | 11:34 PM
lopoetve's Avatar
Excellent. Will start with cable replacement (please please work.)
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
