Relays
Old Jul 14, 2002 | 01:51 AM
Morley's Avatar
Relays
I am all set to do my swap from 870-165 ECM's but the local parts stores don't list the MAF burn off or power relays. I THINK I remember reading several years ago that the fuel pump, MAF power and burnoff relays are inter-changeable, anyone know for sure if this is true or not? If it is I am all set and have the relays in hand already.
P.S. I'm talking pre 89 relays here.
Old Jul 14, 2002 | 02:45 AM
Blackened's Avatar
A relay is a relay. Any relay will work if you know how to hook it up. Especially if they're all automotive relays When I did the '165 conversion on my friends's 85 Z28 we used good old fog lamp relays for 3 bucks a piece.
Old Jul 14, 2002 | 02:52 AM
Morley's Avatar
Well no, not all relays are the same. What I am asking is if they are "inter-changeable" as in swap the FP relay and MAF burnoff relay and have them work correctly. While I am sure you could "rig" just about any relay with the correct switching to work, I am looking for a cleaner install than that would entail.
Old Jul 14, 2002 | 02:58 AM
Blackened's Avatar
Well doh... of course you cant just swap them and they will work. But if you know what the two coil connectors are and the the three "source" "on" and "off" wires are.... then it's JUST a matter of hooking the correct wire to the correct terminal. There's no "rigging" involved. If you have to ask about swapping relays then you're already "rigging" it. LOL
Old Jul 14, 2002 | 03:01 AM
Morley's Avatar
No, it isn't being "rigged", this will be exactly like the factory install, I already have the relay connectors and wiring and want to hook it all up just like GM did to keep things uncomplicated.
Blackened's Avatar
I'm not trying to be a wiseass but if you do a little research you can find out yourself.
Get out the schematics for your car, out of a chilton's book or somthing, and look at the FP relays and MAF relays. If the terminal numbers match (example: if the two coil wires are pins 1 and 3 on one relays and they're the same on another relays) then you can interchange the relays no problem.
Old Jul 14, 2002 | 03:07 AM
Morley's Avatar
If it were that simple I would have done that. The 870 system didn't have MAF power or burnoff relays, they had a module that did it all. My schematics are useless for this.
Old Jul 14, 2002 | 03:14 AM
Blackened's Avatar
Right... there's a webpage somewhere. I think it's Michael Davis's page that shows step by step what pins and what wires go where. Is that what you're going off of ?
Old Jul 14, 2002 | 03:39 AM
Morley's Avatar
No, I just have a paper that tells what pins come from where and where they go to for the 165 hook up.
Old Jul 14, 2002 | 06:35 PM
Randy M's Avatar
GM relays for the years 86 to 89 (MAF systems) are listed as -
1. Fuel Pump 14078915 (early) & 14089936 (late)
2. MAF power 10067925
3. MAF burn off 10094701
4. Fuel pump 14078915 (early) & 14089936 (late)
5. Electronic spark control module 16125261
Realize that when you go to the parts store for the relays by the numbers above, some will be physically these same with like numbers so you might be alright now. The difference between the late and early is simply the shape of the relay and not its function.
Old Jul 14, 2002 | 10:28 PM
Morley's Avatar
Thanks, I have the PN's for all of the relays but no one around here lists anything but the FP relay.
Old Jul 15, 2002 | 10:31 AM
felo72's Avatar
Man, I wish I would have seen this post earlier and saved you some of the arguing. I just recently changed all of my relays, when I called the dealer, they had to order both of them, so I did some research and all three relays are the same. You could use the fuel pump relay for either the MAF power or burn-off connectors. Hope this helps.
Old Jul 15, 2002 | 10:43 AM
Morley's Avatar
Yep, thats what I was looking for, a definitive yes or no, thanks lots.
Old Jul 16, 2002 | 04:05 AM
S10Wildside's Avatar
Woah! They aren't the same!
I've been doing some diagnostic work with my wiring and replaced the fuel pump and MAF power relay. According to my wiring diagrams (1987 T/A - Helm Manual), each relay is DEFINITELY different. I know from experience that if you hook the MAF power relay to the fuel pump relay's wiring, the fuel pump will run at all times.
Old Jul 16, 2002 | 07:14 AM
felo72's Avatar
Really, I've already done that and I didn't have any problems. The reason I know is because I thought I changed the MAF burn-off relay, and it was accually the fuel pump relay, and it still started and ran. Plus the pump still primed for 2 seconds and didn't continually stay on.
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
lanceflame44
Sep 25, 2015 12:28 PM
gta892000
Sep 16, 2015 12:37 AM
