Stock TPI times
Old Aug 11, 2002 | 01:40 AM
tpi_roc's Avatar
Stock TPI times
What are some of the faster stock TPI times at the track? (Stock Base Stock runners, stock plenum stock TB) WIth mods, the more the better.
I want to see if my times this friday are good or not considering the limitations of my tpi setup
Old Aug 11, 2002 | 02:08 AM
Boxeat2469's Avatar
I just ran last week. I had a best of 13.85. I ran a best of 13.56 using my G-Tech, but couldn't get the car running as well at the track.
Old Aug 11, 2002 | 02:09 AM
tpi_roc's Avatar
Sounds comparable to me and my car
Old Aug 11, 2002 | 02:12 AM
Boxeat2469's Avatar
How far did you siamese port the intake? I tried using a siamese ported intake that was ported almost all the way through. Had maybe 1.5 - 2" left. My car slowed down quite a bit. Had way more top end power, but lost all low end torque. By switching back to a stock intake, the car went over a full second faster.
Old Aug 11, 2002 | 08:10 AM
ThirdGenZ28 92's Avatar
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
Stock L98/base/runners/plenum/tb/manifolds I managed a 13.521 on a 1.77 60ft Nov of 2001 in good weather at Englishtown NJ. On street tires I managed a 13.782 on a 1.905 60ft at Atco in NJ earlier this year...
Old Aug 11, 2002 | 12:41 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Best time is in my sig. My average is a 13.5 @ 102 mph. I replaced the block/heads/cam when the stock engine died. Still haven't had enough money to upgrade the TPI yet.
Old Aug 11, 2002 | 01:04 PM
tpi_roc's Avatar
I siamesed the manifold in about 2 inches or so...
That seems odd that you GAINED time with an unsiamesed manifold...
Did you change anything in the prom when you went siamesed?
Old Aug 11, 2002 | 02:50 PM
Boxeat2469's Avatar
I tried running the stock PROM. Then I played around with the spark advance table and power enrichment settings to no avail. I even tried out my old Hypertech chip. Times were not different by more than a tenth when switching between custom PROMs and stock. I pulled the siamesed intake off and got a full second faster on my 0-60 times. Then tweaked the PROM and got another .5 sec quicker. I went from 2.4 60' times with it siamesed, to 1.9 60' times with a stock intake. 15.45 @ 92 with siamesed intake, 13.56 @ 105 with stock intake. Maybe the siamese porting thing works for some setups, but the proof is in the pudding. My car got slower by porting the intake.
Old Aug 11, 2002 | 05:45 PM
IROCZ88's Avatar
I ran a 13.50 @108 on my G-Tech, however I haven't had it at a real track yet since motor swap. I have stock plenum, runners, base, and basically stock heads. I do have another cam in it plus a fully balanced bottom end with 9.73:1 full floating forged pistons. That ET is also with 2.73 gears. I also have SD and burn my own proms which knocked 8 tenths off once I got it properly tuned.
Future plans include AFR heads and a giant cam.
BTW, I see everybody else with 13.50 ET's are running 105 mph. I wonder why my G-Tech consistently says 107-108? Maybe it has something to do with my 2.73 gears?
Old Aug 11, 2002 | 06:29 PM
tpi_roc's Avatar
Damn I need to stop screw'n around and install the LT1 intake, I knew most of my missing time was hiding in the stock/siamesed intake
Old Aug 11, 2002 | 07:01 PM
Boxeat2469's Avatar
IrocZ88, its not your gears. G-Tech will consistently read 3-4 mph over what an actual dragstrip timeslip shows. G-Tech actually shows the speed at the instant you hit the 1320' mark, where the track takes the average speed from the last 60'. It says right in the G-Tech owners manual about that. Every pass I do at the track I have G-Tech running. Its ALWAYS within a tenth on the time, and 3-4 mph higher on the speed.
Old Aug 11, 2002 | 10:51 PM
IROCZ88's Avatar
Thanks, I was thinking it could be something like that. I'm glad to here that the ET is within a tenth.
Old Aug 19, 2002 | 02:20 PM
kvu's Avatar
kvu
Do you think you lost all your intake air velocity?Your siamese job might work better for a larger displacement engine.
Old Aug 19, 2002 | 02:45 PM
tpi_roc's Avatar
Its certainly soft down low, then you hit a sweet spot and its like a switch, goes off like a rocket, unfortunatly it doesn't leave enough rpm range to turn it into a quick ET.
Its all going to be passed tense pretty soon anyways, I'm focusing on that lt1 intake I've gotta have some fun with it before the rainny season comes again
Old Aug 19, 2002 | 09:57 PM
MdFormula350's Avatar
i am slow, i need some mods!!! times in the sig..
Azrael91966669
25
Jun 20, 2017 04:04 AM
NBrehm
Aug 25, 2015 11:49 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
marcusaw
Aug 10, 2015 08:13 AM
Thirim
Aug 9, 2015 06:19 PM
